Question about Nikon Coolpix 5700 Digital Camera
Monitor and viewfinder flicker
Problem started several days ago when I turned my camera on. Monitor and viewfinder were flickering so much that I couldn't see the image. I played around with the controls (power on-off, zoom in-out, etc) until I thought the problem was suddenly fixed. Unfortunately it was not fixed. There is random unpredictable flickering which shows on the photos I take. Your help will be appreciated.
I don't have a solution, but do have the same problem. Mine is cleared by switching the camera off and back on again. Also the problem doesn't appear for long, clearing itself, on some ocassions. The problem stated when I was in a hotter climate, about 35degree celcius. I bought my camera about 3 months after release, I'd be interested to know the age of yours and if this is a common problem. Have you had your camera fixed?
Posted on Sep 05, 2006
  • Chris Berg May 13, 2014
    Eventually problem was solved by Nikon, there was a design fault that got repaired F.O.C. and now all is great again.
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
A few months ago my LG Flatron L1900R monitor started flickering when I boot up my computer. It has become worse, to the point where it now flickers constantly.
From the information desribed, this means that your CRT monitor is going dead. Unfortuntly, there is no way to stop the flickering unless the monitor was replaced. I hope this has helped
Jul 05, 2011 | LG 700M 17" CRT Monitor
Flickering and loss of colour
Problem now solved. I switched the camera on and off a few times and took several test photos. After a few minutes the problem resolved itself. I suspect the cause was condensation, but cannot be sure.
Jan 12, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Monitor flickering
Monitor flickering can be one or several problems.
Depending upon the age of the unit and value, you should decide weather to repair it or replace it.!
More than likely, it is a problem in your power supply.
The capacitors in the supply will leak and most often crown.
If when you start unit after sitting for a while, it shows good and then after a few minutes it starts flickering, you can bet it is one or several capacitors in the supply.
This monitor is a 17 inch and not really worth the time and investment to repair, unless you have the technical skills to remove and replace electronic components.
Nov 05, 2009 | AOC 177Sa 17" LCD Monitor
Samsung SyncMaster 226bw 22inch flickers/blinks on startup
Solution = Sledgehammer. My 226BW has been taking ages to warm up for a while and now it is a permanent dull flicker.
Aug 26, 2009 | Computers & Internet
D200 focussing brackets in viewfinder flicker and jump around
I had something similar - it could well have to do with which AF mode you've got selected. Look in the menu.
May 05, 2009 | Nikon D200 Body Only Digital Camera
Hi, my monitor started to flicker 3times/second persistantly.
its the monitor its the main board may stuff up tomorrow may stuff up next week or in a years time hard to day as its only flickering take in for a check up
Apr 04, 2009 | LG FLATRON L1970HR LCD Monitor
Dark fuzzy/flickering screen - Cannon PowerShot A75
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jan 25, 2009 | Canon PowerShot A75 Digital Camera
Monitor started to flicker then went blank
I have a envision professional series and I love it, but I will get to the point.
I recent ly received a Envision EN9410e monitor, had the same problem (flickering screen then turned on, then off then on then blank). The problem is bad capacitors. There are 7 electrolytic capXon capacitors that will need to be replaced. You should see if the caps are bulging or leaking, if so replace. As known by many replace with the same capacitance and voltage. There are a few incidences that the capacitors where replaced and the problem wasn’t solved; this is because the cap problem wasn’t taken care of and damage occurred to another part of the monitor. The back light is a Royer oscillator (cool things) and it uses two smd mosfet transistors. They are on the green side of the circuit board near a big control chip (they each look like a off rectangle black square with eight pins) you need to see if there is any carbon or chard residue between the pins or burning smell from them, if there is you need to remove the transistor and do some board repair then ether put a new transistor or try the old one. No offence to the people at Envision but not smart putting the drain, gate and source so close to each other under the chip where there is such high voltage! Hope this helps.
Dec 24, 2007 | Computers & Internet
Gateway Flat Screen FPD1830
Well, this problem is going to only get worse. You can probably send it back to the manufacturer if you still have a warantee, but if you can't just buy a new monitor.
Nov 13, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
Nikon Coolpix 5700 Digital Camera Logo
184 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
