Recording problem on VCR
Daily I have to record on the VCR for security reasons. I am recording things outside with a Swann Nighthawk system. I have the tape set to SLP for 9hrs of recording, but after 3hrs the whole VCR shuts down. When replaying the video it comes to a point where it says on the screen - Unreadable Signal - and I am assuming this is when the system shuts down. After the Unreadable Signal message the tape shows stuff that I have previously recorded. What could be making the system shut down?
    Champion:
  • 221 Answers
Try cleaning the heads in the vcr. also use a new tape at least once a week.
Posted on Oct 23, 2008
My Swann cctv recorder is only recording from 5am what do I do so it works all the time
Go to setup or setting and look for record setting or schedule for recording.
Change the setting to your requirement
IP CameraNVR DVR Surveillance System Best secuirty system HD CVIHD TVIAHD...
Apr 28, 2016 | SWANN Home Security
After rebooting swann security how do you get it to start recording? When you push replay it says no files
Make sure that the DVR hard drive is not defective, if it is in working order go to schedule recording and select your recording based on motion, alarm or continous
May 25, 2014 | SWANN Home Security
I have a Zenith DVD/VCR and I am recording a tape
unless the security camera has a setting for recording the date stamp you probably can't. The camera probably has a setup tab to enable embedding the date stamp on the video.
Nov 14, 2009 | Zenith XBS448 System
Recording vhs to pc via swann pci tv tuner card sw-n-tvtc. Picture is fine sound is totally garbled
check the output audio cable of VCR. if it is correct, may be with ''recording software'' problem. please tell me what software you are using
Sep 20, 2009 | Computers & Internet
VHS recording
While setting up your timed recording, scroll through the date, daily or weekly should appear, make your choice then enter the rest of the info.
Jul 22, 2009 | LG RC897T DVD Recorder/VCR Combo
Timed recording with cable (new)
If you're referring to programming your VCR for recording, that works just like it did before the cable box was installed, but with two major differences.
The first difference is that the VCR must always be programmed to record on the converter box output channel. Usually this is channel 3, but may also be channel 4. The cable box selects the channel from the cable system, but it's always outputting to your TV on the same channel. That channel is what the VCR needs to record from.
The second change to programmed recording is that you can't program your VCR to record programs on different channels. The reason is because, as mentioned above, the VCR is actually recording from the cable box which is always on the same output channel. Unless you are home to change the channel on the box, you're stuck. For example, if you want to record a show at 10PM on channel 8 and another at 11 on channel 26, those are the cable channel numbers. The box output is channel 3 (or 4) in both cases. The VCR can't switch the box for you. It's only going to record the program on the channel you selected before you left home. You also need to leave the cable box turned on, but the TV can be off. This is probably the thing most people find confusing about dealing with a cable box.
Now having said all that, some brands of cable box do include a timer feature of their own that allows you to program the box to switch channels. This feature is used in conjunction with timer recording on the VCR. You still always program the VCR to record on channel 3 (4), but now the box can be programmed as well to switch to the channel on the system you want to record. This allows you to get around the limitation described above. If your box offers this feature, it will be accessed through its setup menu using the remote control. Ask your cable company if this is available if it's not clear from the setup menus or instructions the installer left you with.
May 12, 2009 | Emerson Televison & Video
Vcr timed recordings
I'd be pretty certain that every VCR made these days (and of the last 10-15+ years) can be set to do a timed recording. They can be set for a one time recording, weekly or daily record. Whether used with a cable/satellite box, or outside antenna, you must ensure proper hookup. I'm not real familiar with recent cable/sat receiver boxes, but older ones had to be set to the channel you wanted to record, as the VCR will only see that channel. On older cable (no cable box) & outdoor antenna systems, a VCR could tune in and record any channel, while you watched another one. Anyway, check the capability of the cable/sat box, and follow suggested hookup. You will likely need to set the box to the channel you want to record before you retire for the night.
Sep 26, 2007 | Televison & Video
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Electro Med Services...
