Question about Konica Office Equipment & Supplies
I get error code C-2452 - Konica Office Equipment & Supplies
  • chard54 Oct 21, 2008
    I get error code C-2452 on my Konica bizhub 6500. This printer is connected a EFI Fiery. What is the error mean
    I receive error C-2452 on my Bizhub c-6500. This printer is connected to an EFI Fiery.
  • 6,487 Answers
This error has relation to the printer driver problem , so it will be better for you to update or uninstall and reinstall the printer software to your computer and that should correct the problem....
Posted on Oct 21, 2008
  • Konica Master
  • 2,794 Answers
It would help if I know what the model number of the printer is.  You could power the whole system down for now.  Unplug the fiery controller from the copier and see if that takes care of the error.  That way we can determine if the error is in the copier or the fiery.
  • Tim Babcock
    Tim Babcock Oct 27, 2008
    Unplug the Fiery controller and see if the error code is continuing.  If the problem goes away someone should take a look at your Fiery controller to see if something is going on with that
    This is not a driver related error with software.
    Scholar:
  • 84 Answers
Hi cat, even thought the unit my be new and have a "new" install disc, the information on the disc still may be corrupted, this is not uncommon, quite the contrary, I would suggest you update your printer drivers, try this, it should help:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
    Scholar:
  • 136 Answers
Unplug the device from the main power outlet and replug after few minutes and then try. it may reset and go.
  • ready2helpu Oct 21, 2008
    also mention your printer model number for further help if reset does not helps you.
    thanks.
Where is differential pressure sensor on audi a6 2010
G450 SENSOR IS BEFORE THE PDF FILTER.IT IS EITHER FAULTY OR PDF IS CLOGED.THIS NEEDS FURTHER CHECKING!!
Dec 11, 2014 | Audi Cars & Trucks
Marantz Legacy Series - no sound is getting to speakers from tuner or cassette.
It seams like the amplifer is not working and you are right but it certanly needs to be measured first.
Nov 28, 2013 | Marantz Tr 2242 Sb Legacy Series Pll...
Serial number photo shop cs2
1045-1089-3982-6347-2452-9722
Aug 02, 2010 | Adobe Photoshop CS2 for PC
I need a replacement battery kc 2452
Replacing batteries can be more difficult than it would appear. Unless your battery has a cover that is intended to be removed by the user, it is safer to take it to a watch shop and get them to do it for you.
One of the common cries is "I've just changed the battery and it doesn't work now!"
Jan 31, 2010 | Kenneth Cole Leather #KC2452 Watch for...
Its a 120v 670w motor for the ccp-510 I need the
Call them at this number and see if they can provide you with a source for the "replacement" motor.
The Helman Group, Ltd. 1621 Beacon Pl. Oxnard, CA 93033-2452. Phone: (805)487-7772. Fax: (805)487-9975. Tollfree: (800)217-1958.
Jan 15, 2010 | Nostalgia Electrics Helman Group CCP-510...
Iphone is disabled i forgot the password
plug it into the computer you sync it with, (MUST BE THE COMPUTER YOU SYNC WITH!!!!!) and it will reenable, with a small risk that the enable time will change to 2452 min (random bug)
Dec 13, 2009 | Apple iPhone Smartphone
Konica minolta bizhub pro c6500 error c2452
C-2452 When the developing motor/M
(M21) is ON, the maximum
detection value of TCR sensor/
M (TCRS/M) is the specified
value and the difference
between the maximum detection
value and the minimum
detection value is over the specified
value.
Estimated abnormal parts
Printer control board (PRCB)
Developing motor/C (M22)
TCR sensor/C (TCRS/C
Jul 07, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica minolta bizhup 6501 error c-2452
Something with your developer causing not enough toner. Maybe an auger issue in the developer or in the toner feed itself?
May 19, 2009 | Konica Minolta bizhub C250 All-In-One...
Refrigerator gas flame goes out when traveling, otherwise it's ok
It should have a little tin cover over it.
That should work just fine, but i've seen some people take high temperature insulation like for heaters and cover the vent so you don't have so much air movement, wont burn and its breathable.
Dec 28, 2008 | Dometic RM2652 Refrigerator
I get error code C-2452 on my Konica Bizhub 6500
You have a bad developer unit for magenta. Mite need to have the developer replaced, sensor at bottom of that unit, worse case image control board.
Oct 21, 2008 | Konica Office Equipment & Supplies
243 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Andrew Taylor
Andrew Taylor
richie46
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
