Question about Linksys Wireless-G WRT54G Router
Home network problem.
Can't connect my two computers ( desktop & laptop) to my network. Both computers work well, connecting thru WRT54G router, internet access.. but cannot "see" one another. Both computers use Windows XP, both in same workgroup "MSHOME", named correctly, Could this be an issue with the router setup?
  • carl6789 Oct 21, 2008
    need to change settings on router
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    nope..it is the network settings..did you do the home network and file sharing set up yet?
  • Linksys Master
  • 6,487 Answers
In order to resolve this concern just disable or configure your firewall and anti virus to allow the file sharing between those 2 computers and after that ping each computer if its replying but still cannot see the shared documents, do a power cycle turn off everything for 30 seconds and power them back after 30 seconds and that should make everything work....
Don't forget to rate the soluiton FIXYA thank you......
Posted on Oct 22, 2008
I'm trying to connect a remote desktop equipped with Linksys network adapter to internet via a home LAN. Though the network shows that it is connected to the home LAN, when i attempt to connect to...
The setup disc for the router only needs to be run once when setting up the router to work with your internet provider and modem/router. You can try putting the disc in your desktop computer and reconfiguring the router.
Feb 28, 2011 | Cisco Linksys WirelessG Broadband Router...
Cannot connect my laptop to internet through router wrt54g v8
Make sure you have ipx and spx protocol installed, and a home network setup through windows. Also if the first try don't work make sure you firewall setting is not blocking your router.
Dec 03, 2009 | Linksys Wireless-G WRT54G Router
Network/router problem
Is your router wep or wpa encrypted if so you need to put that wep key into your new laptop so you can connect to it.
Oct 17, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G can't connect 3rd wireless computer
log into the WRT54G wireless router and ensure that you do not have it set up for only handing out 4 IP addresses also check the laptop to see if it is set to have a DHCP or static IP address, if it has a static IP and your network is dynamic then this is why it wont connect.
if this resolves your issue and you are happy with the answer please grade me accordingly.
thanks
Aug 25, 2009 | Linksys Wireless-G WRT54GS Router...
I have connected my desktop computer through ethernet with Lynksys wireless router G WRT54G. All other laptop computer works fine with wirless connection. They remain connected but my desktop computer...
If the wired connection keeps getting kicked there is a problem with a network setting on that computer seeing as the others are fine.
when you say ms utilities I presume "network seutup wizard"
If so the maybe you should copy the setting from one of your working machines by running the network wizard on that but not making any changes. when you get to the end it should offer to save the setting to a usb or floppy or even display them so you can write them down.
I would put them on a usb stick and plug that into your faulty machine and run the program that is on the usb stick which will then set you faulty machine up the same as the working ones.
If this information was any use please click.
Aug 13, 2009 | Linksys Wireless-G WRT54G Router
Need to setup Laptop wirelessly thru Linksys WRT54G
The default password of Linksys device is admin without username.
Jun 06, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Connecting WUSB100 to Wireless G WRT54G
laptops have a wide range reciever built around the screen and tend to be far better than a normal usb dongle.
The fact that your pc is downstairs will be effected a lot because the signals from the router will be bouncing around in an area around the antenna and above, signals below will be effected by floors, doors and wall partitions.
Your best solution would be to place the router on a phone line downstairs and see if the signal is increased.
Aug 18, 2008 | Linksys WUSB100 Wireless Adapter
Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Oct 10, 2007 | i-mate K-jam Smartphone
Linksys Wireless-G WRT54G Router Logo
67 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
