Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Generic problem for all PC Laptops
HL-DT-ST DVDRAM GSA-T20N ATA Device
iulica on Oct 21, 2008
HL-DT-ST DVDRAM GSA-T20N ATA Device will not read any discs and has a error code 39.
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
Posted by bossbii on Nov 22, 2008
My DVD ROM has failed to show after booting. It is also removed from the BIOS. I was surprised though that after several effort to resolved it have failed and I almost concluded that the DVD drive is defective, it showed one day. But unfortunately, after using it for just two times, it vanished again. When it showed up I managed to write down the name of the disk as follows: HL-DT-ST DVDRAM GSA-T20N ATA Device DVD/CD-ROM drives. Please, assist me fix this if you can.
Posted by WeListen2You on Oct 21, 2008
what kind of disks..
Same Problem
May 06, 2009
-   i sent my laptop away to replace the fan and presumably the repair team updated my computer, because when i got it back it didn't show my dvd burner, i managed to get it to work twice, after a fiasco of restarts but since i've got nothing, i've tried this method listed above but my computer doesn't show any upperfilter or lower filter so i'm lost as to my next course of action, any ideas? -   Myn Donos
Apr 15, 2009
-   my device does not read any disc -   Guest
Mar 14, 2009
-   SAME -   Guest
Feb 22, 2009
-   For some reason my DVD drive just stopped working with a code 39 listed in the device status window. I know this is not a hardware issue. I have seen that many people have had the same problem. Please help!!!-   Knowone36
Jan 31, 2009
-   Acer 4520 with Vista. Is not able tio open disc drive, or re install.
Says drivers are up to date. Reads, CODE 10 ERROR-   TerryDeAngel
Best Solution
posted on Nov 03, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I got the fix from Microsoft and run the exe to fix the "upper" something and after that it can see the CD/DVD drive. I think it is a Windows bug. Not a hardware failure. (Cost me a trip to local store)
Solution #2
Helpful)
ald1e
Rank: Apprentice
Rating: 94%, 12 votes
try this ..
you must start regedit ( start -> run [See screenshots at the bottom] Type here: regedit )
search the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class/
search for "4D36E965-E325-11CE-BFC1-08002BE10318"
if you doesn't find anything, search only for a part of the string.
now search the propertys UpperFilter an LowersFilter and kill the value. If only one prop. is there, you must kill only the one value
on my laptop it works!!
http://www.computerhilfen.com/hilfen-26-186214-0.html
cheers ...
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Jan 28, 2009
Very Helpful)
pecaro8
Rank: Apprentice
Rating: 100%, 3 votes
search the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class/search for "4D36E965-E325-11CE-BFC1-08002BE10318"
now search the propertys UpperFilter an LowersFilter and erase them
Was this helpful?
Yes
No
Solution #4
posted on Jan 19, 2009
Very Helpful)
pete-w17
Rank: Apprentice
Try This
Step 1: Start Registry Editor loadTOCNode(3, 'whattotry'); Start Registry Editor. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
  1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
  2. Expand SYSTEM, and then expand CurrentControlSet.
  3. Expand Control, and then expand Class.
  4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  6. On the Edit menu, click Delete.
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'whattotry');
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
    Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
    If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  2. On the Edit menu, click Delete.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer loadTOCNode(3, 'whattotry'); Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #5
posted on Nov 29, 2008
Very Helpful)
flassoc
Rank: Apprentice
Rating: 100%, 2 votes
I did not get an error code, but, my drive would not read any discs.
Contacted the HP factory & they told me to do the following:
I ran a virus scan on the drive, did a hardware change check on it, updated the driver, which would not up date, uninstalled & let the computer reinstall the drive. Restored the recovery original drive drivers.
Nothing worked so they are shipping me a new replacement drive. I happened to look at my other HP dvd drive in another laptop & it looked different, because, I found I had a 1/2" gray felt washer around the mounting post, that was not letting me get the discs on very well. It was also keeping the discs too far away from the laser reader.
Guess it came from the factory this way, as I sure didn't put it in there.
Now it accepts all discs snapping on easily, & reads all of them too.
Called HP to have them cancel the shipment, an hour later, but their system, like so many others, does not allow them to cancel an order. Now, how dumb is that? If you load up your pistol, but don't shoot it, can't you take the bullets out?
Was this helpful?
Yes
No
Solution #6
posted on Feb 22, 2009
Somewhat Helpful)
onlinehelps
Rank: Master
Rating: 67%, 7 votes
I have searched the solution and made snapshots of the sample windows at every step. Click HERE.. this worked for me.
Comments:
Feb 22, 2009
- I have searched the solution and made snapshots of the sample windows at every step. Click HERE.. this worked for me.
Was this helpful?
Yes
No
Solution #7
posted on Feb 04, 2009
Somewhat Helpful)
larrywb916
Rank: Apprentice
Rating: 75%, 1 votes
how do i fix this
Was this helpful?
Yes
No
Solution #8
posted on Dec 11, 2008
Somewhat Helpful)
sadvst
Rank: Apprentice
HL-DT-ST DVDRAM GSA-T20N ATA Device will not read any discs has a error code 39
Was this helpful?
Yes
No
Solution #9
posted on Nov 20, 2008
Not Rated)
Dmitryp
Rank: Apprentice
Rating: 0%, 0 votes
Fixed by changing Registry http://www.computerhilfen.com/hilfen-26-186214-0.html
Thanks to ald1e !
Was this helpful?
Yes
No
Related Problems
Just bought a new acer a150 netbook, but there doesn't...
My acer aspire one ZG5 power lite is on, but screen is...
I was just given the Acer Aspire one d250- 1151 netbook. I...
am not able to find the wireless software o drive.i mean...
Can you Help with these PC Laptop problems?
the same problem
Solve
i am facing the same problem, i can acces my orkut in my mobile but can't in my laptop or pc
Same Problem
Solve
my thinkpad was running normally suddently it freezes i tried restarting it and here goes the prob... (More)
my laptop's battery & DVD...
Solve
my laptop's battery & DVD writer is also not working.
need the correct driver for webcam...
Solve
need the correct driver for webcam for acer aspire 4720z not sure if it is the syuin or bison , but... (More)
nx7010 does not start.
Solve
Dear Sir or Madam, I have HP compaq nx7010 . However, my laptop does not show any sign of... (More)
29 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 28, 2009
dido
Comment by Guest, posted on Jan 19, 2009
if have exactly the same problem...how to struglle whit it...
Comment by coco_moco, posted on Jan 10, 2009
how i can make to solve this problem
don't read, just run and make some sounds but for nothing...
Comment by Guest, posted on Jan 01, 2009
compag laptop will not recognize HL-DT-ST DVDRAM GSA-T20N ATA Device.
I tried uninstalling and reinstalling... updating drivers.. but nothing works! Help
Comment by Guest, posted on Dec 27, 2008
drivers gone and not recognised as existing. Disk drive mounted in HP Pavilion dy6000 with Vista
Comment by fern_lin, posted on Dec 15, 2008
windows cannot load device driver for this hardware.DRIVER may be missing or corrupted.(CODE39)
Comment by toshidoce, posted on Dec 14, 2008
Same problem Here. I tried to follow the instructions on "killing the upper something". But it does not let me to change the properties. Any help here ?
Thoshiba user here.
Thanks
Comment by frenchiechar, posted on Dec 14, 2008
dvd rom not showing on my computer but divice is there in device manager, i've followed the recommended procedure to uninstall and reinstall still don't show up or work
Comment by Guest, posted on Dec 10, 2008
yeah, how do u kill the vlaue? just press delete?
Comment by jewk90, posted on Dec 02, 2008
My Acer Aspire 3690 series can neither identify nor read any disc. The cd/DVD rom cannot be displayed
Pls help
Comment by johnx001, posted on Dec 01, 2008
have same problem code 39 on acer laptop 5315, any 1 help.... not confident about going in to regdir tho knowing me i'll bugger everything up ... thanks
Comment by d1g_zgool, posted on Nov 23, 2008
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Comment by outoftown03, posted on Nov 22, 2008
this shows up on a two to three month purchased computer... how do i fix it... need my driver
Comment by Guest, posted on Nov 22, 2008
I am getting a code 39 on my laptop. I bought it about two months or so ago and everything was working fine until about a week or so ago. Need to get it up and running.
Comment by junglebwana, posted on Nov 22, 2008
My Laptop is not detecting my DVD Drive? Surely this problem shouldn't happen with a brand new laptop... how random
My Laptop is not recognising the DVD drive. Please Help.
Comment by Dmitryp, posted on Nov 20, 2008
Same problem, laptop ASUS X51RL, but the system is Win XP (SP3), not Vista
Comment by spottingferr, posted on Nov 20, 2008
same product, but installed in a Toshiba laptop. Is it me or have all these errors occired after the latest Vista upgrade?
Comment by JerrodS, posted on Nov 19, 2008
I have an Acer Aspire 5610z with an HL-DT-ST DVDRAM GSA-T20N ATA Device that just stopped working and wouldn't update the drivers. When I tried to update the drivers message said most up to date drivers were installed. I have been up to the Acer site and they are just about worthless. Had the same problem with my built in camera when I first got the laptop and Vista updated. It's getting old.
Comment by elv22, posted on Nov 05, 2008
DVD player doesn't work. It will open and acknowledge the disc then it just stops running. This is an Acer 7720-4799 laptop with the wonderful OS Vista Home Premium. Any suggestions would be much appreciated!
Elv22
Comment by Guest, posted on Nov 05, 2008
pc wont recognize dvd's or player
Comment by lynhnn, posted on Nov 02, 2008
Same problem after buying it from Fry's
Comment by musa_lies, posted on Oct 26, 2008
I HAVE SAME PRBLM COD 39 PLS HELP ME+
Comment by rakabyt, posted on Oct 24, 2008
My HL-DT-ST DVDRAM GSA-T20N ATA Device is not listed in my computer. It has an error code 39 when checked on device manager "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Sponsored Links
Describe your Computer problem:
Select a Category:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more PC Laptop Experts
Top Computers & Laptop Repair
(407) 952-4048
WE REPAIR ALL BRANDS TV-BIG SCREEN-PLASMA-LCD...
jr electronics
(330) 502-6853
Instead of lugging your computer into a shop and...
PC Laptops
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
