Question about iLO 2600 Television
COLOR BLEEDING After my ILO 2600 HDTV has been on for about an hour, the color saturation increases to the point the colors bleed profusely and the entire picture becomes blobby. The tv has worked fine for about 7 months now, and still works fine when it's turned on. Problem only occurs after about an hour or so after being left on. Ideas?
  • idela66 Jan 18, 2009
    I have a Samsung 40 inch that is just over 1 year old with the same problem. After TV is on for a while, color bleeds. If I turn the set off for about 30 seconds, then turn back on, it goes away. Intermittent issue.
    President:
  • 3,130 Answers
Thats A 26" LCD tv sets thats sold mostly by walley world. The problem you describe is most likly the sustain voltage on the LCD screen has a bad capacitor in the power supply circuit that supplies that voltage to the driver board. If you still have a warranty Take it in or hopefully you bought an extended warranty with the set. Good Luck.
Posted on Jul 25, 2006
Ilo 2600 HDTV manual
You would need a converter to make it work. Adapters won't work as the type of signal would need to be changes. Your best bet would be to purchase a DVD player that has outputs that work with the tv. Sorry.
Jul 07, 2016 | iLO 2600 Television
Color problem on Toshiba CRT TV
It sounds that the color mask inside the picture tube have been displaced due to hard shock. If so, it is irrepariable.
May 28, 2013 | iLO 2600 Television
LG 50PX5D, I heard a loud pop and the screen went
Ur Main Tuner signal board is dead.Replaced the Main Tuner signal board will solved ur picture problems.
Jan 23, 2010 | LG 50PX5D 50 in. Plasma HDTV
No Red color at all. The convergence feature does not work either. Lots of green and blue RCA Model D52W59
Red color gun has failed, which will make the picture over saturated with the other two colors(blue,green) the bad news is the three color guns need to be replace in a set(all at the same time) because if you only replace the red it will over saturate the older blue, green guns then your picture will be mostly red.Unfortunently in most cases it's not worth the investment, better off to purchase a new tv. Good luck !
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color picture jumps in and out of normal color mode . . .
You have bad solder connection in or around the Jungle IC and or color processing Circuits. Most commonly the area is the color cyrstal, located on the main board.
Oct 10, 2009 | Televison & Video
Loud Buzz
loud buzz is the color engine, turning the color wheel. Find instructions on how to take it out and clean it and that should fix that problem.
Jun 28, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Need best settings for a Panasonic TH-50PZ85U
As with any display best settings are up to the user.
Some general rules about adjustment of a video display device apply
1. if the display is too bright you would decrease brightness by turning it down
2. if the display is too dark you would increase brightness by turning it up
If a display is too bright it will shorten it's life span so you want to keep the brightness down
Contrast must also be adjusted in the same manor
You should increase color saturation to suit your self
Increasing the color saturation too much will decrease the life of the display and look ugly
so you want to add just enough color to satisfy your taste.
Loch Hiam :-)
Sep 14, 2008 | Panasonic Televison & Video
Color is messed up on 42" ILO LG HD
I own a 26inch, I may not see a Green and Red option but if you have the remote you can select TV MENU; from there you can use the down arrow to the bottom portion and you can also choose to do a factory reset if that helps. Otherwise at the top part theres a way to customize all; brightness, saturation, etc under picture choose Custom
Nov 30, 2007 | iLO 2600 Television
Color
USING A CABLE OR SAT. BOX ?? IF SO CHECK W DVD
Sep 03, 2007 | iLO 2600 Television
ILO TV
call a tech as your tv is repairable i cannot recommend a tech for you due to my location belize good the tv is having problem in the color circuit good luck
Apr 05, 2007 | iLO 2600 Television
Televison & Video Logo
1,115 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
