Question about GE DCVH515EFWW Electric Dryer
Control Panel turns off
The problem started when the motor would not start, we would just get a humming sound.. We opened the unit and checked the motor. When we wired it direct, it ran fine. We cleaned the unit and put it back together. Now, after pushing the power button, the control panel lights up. When we push start button, it does not start and control panel turns off. If we push power button again, it lights up and then goes out. After unpluging and repluging unit, when Power button is pushed, the control panel stays lite, but when start is pushed, it goes out again. Model DCVH515EF0WW
I have a GE DCV515EF0WW front-load dryer. When the dryer is on there is a scratching noise that seems to come from the front edge of the drum. The unit just started doing this. I checked around the drum for debris. I found some lint and cleaned it as best asI could. Any suggestions. The unit is heating properly or so it seems. Thanks in advance.
Posted on Feb 20, 2009
  • 1,183 Answers
HI,
The PCB unit ie the control panel circuit board has gone bad. The probable cause of the same is moisture on the board.
Thanks
proton
Posted on Oct 21, 2008
I have a GE DPSR610EG5WTI dryer. Worked fine. Finished a load and then on the next load it would not start at all. I push the start button and all I get is a humming sound until I let it go. No motion or...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Sep 18, 2011 | Dryers
PROBLEM: Unit will start, fill with water, wait through normal cycle time, then drain. Unit does not perform washing (arms spinning & spraying water, etc.) cycle.
Hello & Welcome to FixYa
The problem is that the control detects that the motor is not running and so drains water directly after filling it. If you hear a hum sound from the bottom panel then it is the motor that is bad, if you don't hear any sound and still the unit performs same way then first thing to check is the motor, and then check the control as even a bad relay in control can cause this issue. Please get back to me if you have any other questions.
Kevin
Dec 21, 2010 | Frigidaire Dishwashers
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
Will not turn on when I turn to ''start''. I can hear the motor hum but the unit will not start.
i have afrigidaire electric dryer all electronic control panel when i push the start button i hear a click from a relay on the control panel. but does not start or spin.thougth it was the motor i replace it with the new one it still the same.does not do anything
Oct 30, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Humming, but no spinning
It could be the capacitor which kick starts the motor.
they are relatively cheap to replace.
Ash
Oct 22, 2009 | Frigidaire Dryers
Washing machine make humming sound in control panel
change the start capacitor located at by the motor or at the back of the unit
Jun 17, 2009 | Maytag Performa PAV2200
Ac unit is humming fan is not turning
hi there,
defective fan motor,this means stuck up motor the running winding is functioning but it can't star to drive your motor so the current inside motor produce vibration that why it create humming, several causes to be consider, bearing are worn out,defective fan capacitor, the fan is obstructed by object.there is no supply on starting capacitor,check if there fan relay overload protection reset it on control panel,
also,if humming is came from compressor,definitely because
fan is to reject heat,if no fan compressor will hum due to refrigferant in the system is not flowing,on high side,have this check by a/c technician nearewst on you.have a nice day dont fforget to rate me ,thank's
Apr 26, 2009 | Heating & Cooling
My Matag dryer does not run, but for a while it hummed before starting.
Motors of this sort have a "start" winding, to give them an extra boost to get them turning. Once they're turning, the start winding shuts off. Critical to this is the start capacitor which, when shorted, causes the exact symptom you've described. The motor's "regular" winding gets power (and then hums), but it needs that extra boost to actually start turning. Have someone check the capacitor (with an ohmeter) or check to see if the motor's start winding is open (broken).
Apr 10, 2006 | Maytag HYG2460AWW Gas Dryer
GE DCVH515EFWW Electric Dryer Logo
317 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
