Cars & Trucks Logo
Posted on Oct 21, 2008
AUDI A4 AUTOMATIC SLOW TO ENGAGE FORWARD GEARS ,REVERSE ENGAGES INSTANTLEY BUT TO MOVE FORWARD I NOW SELECT DRIVE FOR AROUND THREE MINUTES THEN MOVE OFF SLOWLEY,THEN ALL GOES WELL
  • 5 more comments
  • FRED0606 Oct 21, 2008
    WHEN I PUSH ON GAS BEFORE THREE MINUTES IT FEELS LIKE ITS SLIPPING THEN AFTER A SHORT DISTANCE ALL IS FINE
  • Anonymous Mar 29, 2009
    I have the same problem, although the shift can be quite sudden at higher speeds. I am going to change the fluid and filter to see if this helps. Previous owner I think used Dextron when he should have used VW ATF.
  • Anonymous Mar 14, 2014
    I was driving and heard something break. The car slowed down and stopped and would not move forward but does in reverse. The trans engages in drive but the front wheel does not turn going forward
  • Anonymous Mar 15, 2014
    My nze121 Toyota Cor olla does not move immediately when gear in drive. It takes sometimes about 1 minute to engage geardrive.Pls advise Thanks. Bally
    NZE12corolla1Toyota
  • Anonymous Mar 19, 2014
    automatic gear not engaging
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Oct 21, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
4967
Points
27
Not overly familiar with Audis but it sounds like either a.) you have an electronic tranny that has a serious bug or b.) there's a problem in the computer of the car itself. What is sounds like is the car is taking a long time to "understand" that you're telling it to move forward. How new is the car? When you push on the gas before the three minutes, what happens?
50 horse 4 stwont go into reverse gear due to shaft problems
the drive shaft just drives a pinion gear in the prop box that drives to gears that spin in opposite directions all the time
by selecting forward with the selector rod , a dog gear is moved forward to mesh with one gear that is turning or moves the other way to engage the other gear that is turning
that is the forward or reverse action for the prop
if you have forward but no reverse the it is not a drive shaft problem but a selector rod adjustment that is not moving the dog far enough to engage the running gear
I have an 2002 Audi a4 1.8t it will not go into reverse and will not go into drive and won't move. Could that be from the shift cable?
If it has recently started to do this it might be due to a faulty gear selector or a collapsed torque convertor.
Looking through the responses to othe similar issues in other cars it seems that in the States there are devices built in that prevent the engaging of gears if the brake laights have failed. Check these also
Good Luck
1helpful
My smart fortwo will not engage automatic or reverse
If the ABS has a problem , the transmission will not work properly
2answers
Audi a3 auto reverse gear doesn't move
run fault codes and look for faulty TCM and reverse servo .
1helpful
My Audi 03 A4 shutters on take off like a clutch engaging and dis engaging but it's auto...
If you have C.V drive joints worn this maybe why there's a shutter when taking off,did you get them checked out recently,also along with worn CV drives joints a bush on the wish bone arms on the inside near the chassis can be wearing out,so the car wheels move forward a few inches before the chassis and car do.Also if its an auto,your transmission oil may need changing,its tick and clogging the sive,filter.Or thick in cold weather before heat up.
Hi, I have an AUDI A4 AVANT FSI 2.0. Automatic gearbox. Recently is has had problems picking up reverse gear when selected and not engaging but reving the engine. This has recently happened in drive as...
Hi i had the same problem with my a4 fsi sport auto gear box i had to have the gear box changed seems like a common problem with the a4 auto gear box.
1helpful
Sometimes can't get reverse gear Audi A6 2004 Auto 1.9TDi UK
Unless your shade tree mechanic is an Audi expert, go to the dealer who has all the books and diagrams that tell the tech exactly where to look. The other guy may want to replace something just to troubleshoot and the factory tech should know exactly what to replace or which plug is loose.
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
