Question about Intel Desktop Board D845GERG2 Motherboard
Windows XP, Blue screen of death
When I turn on my computer it goes to a blue screen that reads x00004 fatal system error.. nothing i press on the keyboard ( DF1 or F12 ) helps. Its just frozen. Help!
  • sequence04 Oct 21, 2008
    re-install the operating system? I dont know if I have any disk like that? where would i get one?.. and by use any hard drive partition software ( im guessing you mean, just any application i have , which i have tried-nothing happens ) Is my computer dead?? ; (
    Sergeant:
  • 359 Answers
Yes there is something you can do other than formatting and losing everything you have.
How many sticks of memory do you have installed on your computer? If there is more than one take one out at a time and see if the blue screen goes away to determine if any of the RAM sticks are bad.
If that doesn't work/make a difference:
See if you can goto a friends house and plug in your hdd and do a error check on it. If it passes transfer any data you may not want to lose, since a format is probably in order
If it doesn't pass, most likely you will need to replace HDD due to bad sectors. See if you can transfer anything off of it since HDD replacement is in order.
Back to your comptuer:
If everything checks out with your HDD, try booting off of a xp install cd and see if you can format your HDD,
Now if that doesn't work, the mainboard will most likely have to be replaced. Now would be a good time to replace your powersupply as well as these are fairly inexpensive. I would keep your old RAM and put back in new mainboard.
Basically, the worst case you may need to replace HDD, RAM, or motherboard. Either one is a fairly inexpensive solution.
Posted on Oct 21, 2008
  • Daniel Jenkins
    Daniel Jenkins Oct 21, 2008
    You will probably want to order Windows XP Pro or get it from a friend if you don't have an XP CD.
    Genius:
  • 1,605 Answers
Re-install the operatng sytem. nothing else you can do.
use any hard drive partition software should tell you if your hard drive is still good.
  • Frank
    Frank Oct 22, 2008
    go to you friend who have a virus software on a CD, scan for virus, and also see if your friend has a hard drive installation software. you can recover the MBR. it should let you access the hard drive.
    if you are sure how to do these, you can take it have it repair
I switch on my pc (window xp) this evening, and my pc auto restart with blue screen pop out. its say some error with name 'fatal system error'. already clean disk, de-fragment in the safe mo
turn on computer,press F* repetedly until screen shows up wth options
safe mode
safe mode with networking etc...
in dat screen select option "most recent good configuration"
and enter..next window select windows xp and enter..thats it.
after u log in.clean whole system with good virus scanner for viruses,malware,trojans all
May 19, 2012 | Computers & Internet
I have a disk error how do i fix it?
Could be the HDD or even just the boot sector itself. Basically, it's not able to read the Operating System Boot...or it got damaged somehow. If you have a disc for the exact version that is on the system, you may be able to fix it through the Advanced Options using the command prompt. (bootrec.exe /fixboot /fixmbr /scanos /rebuildbcd)
Oct 11, 2017 | Acer Aspire L100 PC Desktop
I have a problem on this cod c000021a fatal system error i have window when i shut down my computer show blue screen with this cod c000021a fatal system error and computer restarts i need help for solve...
Blue Screen system error. If you've been running windows Xp, please do the following:
1. Insert Windows XP CD in the Pc.
2. Restart the PC and while in Bios, go to Boot Priority and select Boot from CD as your first priority.
3. Save and exit.
4. The PC restarts and follow the instructions on the screen. (Press any key to boot from the CD).
5.After system has finished, such will happen <Enter-To Continue R-Repair ESC-Cancel>.
6. Choose R to repair.
7. A black screen pops up, just read and type 1 and wait for the next step (password).
8. Put in your Admin Password or press "Enter".
9. Then type CHKDSK and press "Enter".
10. the system will repair the errors within the HDD and windows and later restart the PC. Good luck
Jun 21, 2010 | Dell Inspiron 1501 Notebook
When you first start your computer how do get it to read the disc first?
You go into Boot Menu, and set the - first boot device to CDROM.
The computer will then read what is in the optical drive, first.
Computer off, press the Power On button. Watch closely for the blue dell logo.
Looking at the bottom of the monitor screen when the blue Dell logo comes up, you will see - F2 = Setup.
At the top right of the screen you will see F12 = Boot Menu.
This screen goes by F-A-S-T!
As SOON as you see the blue Dell logo press the F12 key.
If you miss this small window of opportunity, just wait for Windows to fully load, then click on Start, Turn Off Computer, and Restart.
If Windows is not loading, then press the CTRL, ALT, and DELete keys at the SAME TIME. (Not shouting)
This will restart your computer so you can try again.
Upon entering Boot Menu you cannot use your mouse anymore, you have to use the keyboard.
The Boot Device Menu has the devices listed, and each device has a number next to it.
At the bottom of the menu, type the number that is next to CDROM, then press the Enter key.
This is Dell Support, and the main page for the Dell Dimension 4700 Service Manual,
http://support.dell.com/support/edocs/systems/dim4700/sm/index.htm
Left-click on - Entering System Setup
Should you have any questions concerning this, simply state so in a Comment.
May 03, 2010 | Dell Dimension 4700 PC Desktop
Compaq Preario V5245eu cant get past scrolling xp window just restarts and doesn'r get anywhere have had a c000021a fatal error warning- help please Rodger
If you attempt to install a piece of hardware or software on your PC computer that is incompatible with your system, you may see a blue screen with a C000021a fatal error warning. The easiest way to recover the Windows operating system from this type of error is to restore your computer to a previously working state.
1.Press the "F8" key on your keyboard when prompted during the boot process.
2.Use the up-and-down arrow keys to highlight the "Last Known Good Configuration" option. Then hit "Enter.
3.Use the up-and-down arrow keys to highlight the operating system version that you wish to boot up to, and then hit "Enter" again. The system will now restart to the last working version of your operating system, which will eliminate the C000021a fatal error.
Hope this helps
Mar 13, 2010 | Computers & Internet
My main computer has stopped working. it is displaying a fatal error blue screen with code numbers at the bottom these seems to be problems with the registary stop: 0x00000024 (0x00190203,0x807ae0b0,...
BSOD - blue screen of death....sorry mate but its seems that a fatal error on your operating system occured....most probably a sure way to fix this is to re-install windows, and lose everything on the hard drive...
Feb 15, 2010 | Computers & Internet
Acer computer is frozen on screen which reads press f12 or del to enter setup. when computer comes on it does not beep so i cannot use keyboard all the lights on the keyboard aare off. HELP!!
From the description you are giving, it appears that the system is not detecting a bootable hard disk drive. Hold the power button on the system till it powers off. once system is off, try the following:
  1. Ensure no floppy diskette is in the A: if system has a floppy drive
  2. Disconnect all external items (Printer, scanner, network connection) leave only video and keyboard connected to system.
  3. Try powering system on again
If the system gives the same message, try rebooting and pressing F12 ONCE at the ACER screen and see if you can get a 1 time boot menu. If you can get the boot menu, select CD-ROM, and put you WINDOWS CD in the optical drive, see if system will boot to the CD. If you can, then at the first prompt, press R to enter recovery console, and see if you can run the command CHKDSK /R (then press enter)
If chkdsk runs, then reboot and see if the error has gone away. IF you cannot run CHKDSK then the hard disk drive has likely failed and will need replacement.
Nov 01, 2009 | Computers & Internet
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Memory dumpping
That is usually called a fatal error. It's not really fatal but you need to fix it. Download ccleaner and regscrub xp both for free and run them to clean your system up. It should run much quicker after that.
Oct 21, 2007 | Logitech Keyboard
Intel Desktop Board D845GERG2 Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
