Back to:
Tags:
Le Chef LSC7100 7-Quart
Where can i obtain a replacement cover
posted by ttd61300 on Jul 25, 2006
The cover got smashed. Is it possible to buy another cover? I have only used it a few times. It would be a real shame to throw it out because it doesn't have a proper cover. Where can you get another cover?
Thanks,
Tirza
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 25, 2006
Not Rated (0)
techman
Rank:Guru Guru
Rating: 87%, 6818 votes
If you dont have the owners manual to contact the company, your out of luck unless someone else has a distribution name and addy. Last time i tryed to get a cover for one of our crock pots, the shipping and handling as well as the part cost almost more then the entire crock pot.. Go figure! good Luck
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on where can i obtain a replacement cover:
I don't want to Accept this solution
Can you Help with these Crock Pots and Slow Cookers problems?
I have a bonjour fondue burner - butane. It burns no...
Have been given a new cooker but with no instrctions for...
My switch locked up and no longer works
I have been given the above slow cooker, but it does not...
I purchased a vintage Presto pressure cooker Model 606...
Loading problems.
Repair Service
Find Crock Pot and Slo. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
