Question about GE Adora (DSF25KGTBG) Side by Side Refrigerator
GE Adora Side by Side Loose Handle
The refrigerator door handle is getting loose. Can anyone tell me how to tighten the bolt....thru the handle cover or do I have to go thru the inside of the door?
Thanks.
  • mislplaced Jan 05, 2009
    same problem... my husband was going to try and figure it out...
  • Anonymous May 06, 2009
    My door handle is loose and I don't see how to tighten it. My appliance is only 2 years old and is not abused.
Do the covers pop off to tighten screws on the handles
Posted on Aug 31, 2010
The bottom & top of door handles have pop off covers. Carefully use a utility knife to pry off the cover on handles.
Posted on Jan 03, 2011
    Problem Solver:
  • 14 Answers
Yes you will have to tighten it from the inside
Posted on Feb 21, 2009
The cover plate comes off to exposed the screw that needs tightening. My husband just fixed ours as I was looking up how to fix it.
Posted on May 06, 2009
I have adora side by side refrigerator. Both door handles are loose
check along the handles for little hole that may have set screws in them and tighten them. may need an Allen wrench set to do this.
Dec 17, 2010 | GE Adora (DSF25KGTBG) Side by Side...
How to tighten loose door handle
should be a small access cover on the handle top and bottom pop them open with a flat small screw driver screws should be underneath
Jun 09, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Loose door handle
I just FINALLY fixed mine...  Popped little cover pieces off top and bottom of handle with a plastic bread bag tag slid along space created by loose handle (did not scratch finish on door).  That exposed the screws which could be tightened with a phillips screw driver; the cover pieces then snap back on the ends of the handle.
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Door handle is loose on model#gsh22jftacc. how do you tighten?
If it's the same as the one we have (which is similar to the pic posted on yours) there's a plastic piece on the top and bottom of the handle that you have to pry up (gently) to get to them.
It looks like a line that runs horizontal across the handle, but it should come up with a little force (meaning it shouldn't require tools). You have to pry it from the side, not the top or bottom.
Mar 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
How to fix loose door handle on GE model DSF25KGTB BG side by sid
If the screws aren't obvious, they will be locater under a pop out plug on under a nameplate on the handle.
Feb 20, 2009 | GE GSS20IEP Side by Side Refrigerator
Loose door handle GE two door freezer/frig model TFG 22JADAWW
Called and watched mechanic who clipped of top and bottom covers with a screw driver then tightened both screws and replaced covers. Cost was $100 but I could have wrecked the door. Needs a special little star shaped screw driver head with ratchet fitting. Now equipped for next time.
Jun 22, 2008 | Refrigerators
Door handle loose on Model GSS25WGTA
There is a cover that runs up and down the door. This cover is removed simply by using a thin screw driver and peeling it off. You will find the Bolts under this cover. BE CAREFUL not to over tighten the bolts..
Good Luck
Mar 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
GE Adora (DSF25KGTBG) Side by Side Refrigerator Logo
788 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
