Question about Toshiba Satellite M45-S265 Notebook
UPDATE BIOS the problem is don´t let me install winxp sp2 in the computer, because need to update drivers ACPI, but when i install other kind of version of the bios is doesn´t work yet, and i need to install this SO
Go to http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp# , Download, select model. Next select OS. Choose the ACPI driver needed. Download and install.
Posted on Dec 02, 2008
Bios is not ACPI complaint
It's possible that the BIOS setup has been accidentally set to non ACPI mode. Check in the setup to ensure ACPI is enabled.Other possible causes are memory expansion, overclocking and incompatible driver software. Check out what you have recently installed or updated on your computer.This can occur if Windows has detected that the BIOS in the computer is not fully compliant with Advanced Configuration and Power Interface (ACPI). To correct this problem, contact the manufacturer of your computer to obtain a BIOS update that is fully ACPI compliant. (If your PC is an older model, a BIOS update may not be available). There are third party companies that will write a BIOS update for your computer for a fee which may make it more cost effective to replace your computer.You may also find help on this Microsoft Support Site.
Apr 09, 2013 | Computers & Internet
Every time I start up my eee pc I have an error message : "Asus eee pc acpi service encountered a problem and needs to close..." If I close the pop up comes back immediately. I have already try...
ACPI is the reporting system for the hardware. It tells the operating system about battery charges fan speeds and so on depending on the model.
I would look at the Asus support page for a bios update as well as updates for the ACPI system or software. You can download and just run the updates to install and that should fix this if they have a driver problem and a fix.
http://usa.asus.com/Eee/
Select your model to go to the model page then under downloads you should find the bios updates and the bios utility. Download and run and it will update and hopefully kill the error. I saw 4 updates and two looked like they might address this. Just get the latest one. It will tell you if it needs to be done. Don't run anything else when you do this. Start the update and don;t touch. It should take just a few minutes and may want to reboot after.
Sep 02, 2011 | ASUS Eee PC 1000HE Netbook
When I format the hdd and installing win xp sp2 Blue screen keeping reporting tha the bios is not fully acpi compatible and I'm unable since to get it done
im sorry there is no one answer to this problem a couple of possible solutions are to 1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant.
you could have a bad stick or sticks of ram
or you need to flash/update you bios
or you need to clear the cmos [removal of battery or a jumper switch depending on your mobo]
once again im sorry to not have a clear one size fits all solution to this problem i hope this helps you and please vote for me
Dec 05, 2010 | Computers & Internet
Where to download drivers to update the BIOS for my IBM desk-top
Ha! Old OS, old URL; possibly just an old desktop not up to the task of running WinXP.
It's a new BIOS you'd flash your system with, and probably a push between your motherboard's BIOS having an update (you'd go to the mobo's maker's site, e.g. that of ASUS, Gigabyte, Intel, etc.; read the screen-print on the board; to get the update) and telling WinXP to install anyhow using a handy force-install option.
May 02, 2010 | Computers & Internet
ACPI Compliant
Don't worry check out on the net about this motherboard, put that serial number of the mother board on the site and download the BIOS drivers. update that BIOS by DOS prompt , problem will be solved
Jun 15, 2009 | Computers & Internet
ACPI BIOS not fully compliant
w8000 a very old PC not supported by HP.
windows 2000 support ended like 15 years ago.. W2k. is gone. w2k only runs on very old pcs with very old ACPI
(power controls is that)
this PC is only supported with XP
never 2000.
HP tells you that if you looked.
park the 2000 disk or use it as frezzbee. IMO
https://support.hp.com/us-en/drivers/selfservice/compaq-evo-workstation-w8000/322279
id get w7 disk and use that, it might work.
but will cost you a license from MS,
about 5 times the value of w8000
why not just go here, and get used $20 w7 pc
save a bundle of case and grief messing with any legacy junk....avoid legacy junk and win.
http://www.pcdied.com/cheaper.html
a usa answers.... always...
Jul 19, 2017 | Compaq Computers & Internet
Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
RESOLUTION
Manually install the Standard PC hardware abstraction layer (HAL):
Mar 16, 2009 | Dell Inspiron 1100 Notebook
Acpi bios
Hi suleman_indi, I'm guessing you have a question about the D845GVSR motherboard. If your question refers to the bios setting for ACPI. Disable it until windows has been updated to SP2. Enter your bios & enable the ACPI. Should be fine once windows has been updated. Click on this link to load Intel's site for the Intel D845GVSR motherboard.
http://downloadcenter.intel.com/Product_Search.aspx?Prod_nm=+D845GVSR&lang=eng&MissingSearchTxt=Please+enter+a+valid+product+name%2C+filename+or+product+ID+%23.&x=21&y=5
If you find you need more information, feel free to update your question.
Mike
Sep 09, 2008 | Intel D845GVSR Motherboard
System reboots when acpi turned off
Hi martinkp, what you need is the update from windows. Leave you're acpi enabled withing the bios. Check windows update. Windows will update (windows software for the acpi). Rule of thumb concerning windows update. Check the dates of the updates & install in order, oldest to newest. This should fix you're system from shutting down. There will be no reason to turn off acpi after updating.
Mike
Apr 06, 2008 | MSI K9VGM-V Motherboard
Problem istalling windows 2000 professional on a pc with intel d945gcnl motherboard
try to make bios settings default and make a proper installation
The bios in this system is not fully ACPI compliant. Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
Dec 04, 2007 | Microsoft Windows 2000 Professional for PC
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
323 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
