Question about HP Office Equipment & Supplies
New HP.photosmart C4580 ( ALL-in-One. Just setting up. put inks in and paper pressed OK. said Busy. cant move on.
    Sergeant:
  • 352 Answers
Hi cat, even thought the unit my be new and have a "new" install disc, the information on the disc still may be corrupted, this is not uncommon, quite the contrary, I would suggest you update your printer drivers, try this, it should help:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 21, 2008
I have a hp photosmart c4585 all in one with a message print carridges misssing or not detected can you halp me
Try to turn off first your printer
Open thecover
1YOu can actually move the cartridge carrier manually by your hand just make sure its compleltey off , move it to the center so you can see your cartrdiges remoev all the cartridges
- > clean the gold plated area where you plug in the cartridges including the contacts the gold plate clean it with a dry cloth or a dry paper make sure its clean clean also the cartridges the contacts and whrer the ink goues out once your done .(Make sure its clean )
return the cartridges propperly
close the cover and then you may now turn it on ..
Hope it help in case you have the same problem
replace cartridges in case still you have the same problem probably its on the carrier OK
thanks
May 22, 2011 | HP Photosmart C4580 All-in-One InkJet...
I HAVE AN HP PHOTOSMART C4580 ALL IN ONE PRINTER SCANNER COPIER THAT KEEPS GIVING ME A PAPER JAM. I WAS TOLD I NEED TO RESET THE HARDWARE OF THE PRINTER
It's one or two things. First make sure there is nothing stuck in the printer. Such as, a paper clip, coins, or even a staple. Make sure you take all the ink cartridges out of the printer. Shake the printer and see if anything falls out. Good luck!
Dec 08, 2010 | HP Photosmart C4580 All-in-One InkJet...
I have a HP Photosmart C6380 printer locks up & gives error
it is likely that you have had a jam which damaged the sensor when you removed it (itr if you print lables gunked it up). If it is likely to be gunked up you could strip and clean but to be honest it is probably not worth the time. If this has iccurred following a jam - unless you have another identical machine for spares bin it and get a new one as the parts are difficult to come by and labour will be steep unless you can do it yourself of course
Jul 12, 2010 | HP Photosmart C6380 All-In-One InkJet...
Paper jam on HP C4580 - freed jam but the printer makes a strange clicking noise on pressing the reset button and will not clear!
There seem to be a physical obstruction like a foreig object in the paper pathway.
Try to turn the printer upside down ad shake it.
That is after removing all the paper and securing any movable parts. Don't worry about the ink. they won't fall out.
If you give it a shake you may hear the object rattling.
If you are lucky it will also fall out.
After it fall out keep shaking to see if ther are other objects.
If not you may need to use a small flashlight to examine it.
the common objects are paper clips,
coins buttons and children's krayons. But just about any-ting that is stored above the printer is likely to fall in the paper way.
Goog luck.
Jan 30, 2010 | HP Photosmart C4580 All-in-One InkJet...
I am missing a ink cartridge and my hp photosmart C4580 wont let me use my scanner
This is because printer and scanner are connected together.The printer need both cartridges installed to initialized and then initialized the scanner.Just put the missing cartridge and problem will solve.
Oct 29, 2009 | HP Photosmart C4580 All-in-One InkJet...
I can't get the ink to fit into the slots.
If you have purchased the printer with the ink cartridge then insert the ink cartridges with the GOLD(contacts) facing towards the printer. If you are replacing the ink cartridges, then you must make sure that cartridge numbers are the same as the empty ones.
GOOD LUCK
Jan 03, 2009 | HP Photosmart C4580 All-in-One InkJet...
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
42 people viewed this question
Ben Johnson
