Question about HP S5500 15" CRT Monitor
Problem with the vga cable
Hello, my cpu was stoled and the bad guy cut the vga cable. i can put a new db conector but i havent how the wires get into the pins. could anybody the colour sequence in the db15 conector for this monitor . thanks and i`msorry about my english
3 Suggested Answers
  • 2794 Answers
SOURCE: VGA Cable Wire Colors
I don't think and RGB cable will work with a VGA cable because the signal in the video card is completely different. It's not just the picture but the scaning and refresh rates are totally different. Even if you could wire one it probably won't produce a picture.
Posted on Jun 30, 2008
  • 382 Answers
SOURCE: Hp Pavillion F1703 17 LCD monitor
The VGA cable should be the standard 15 pin connector. But if you are referring to the power cable it is a small round plug similar to that of a laptop. You should have recieved a power cord with a transformer suited to the same voltage and amperage as the monitor.
Posted on Jan 29, 2009
SOURCE: Hello, I have a HP 1502
key boad
Posted on Jan 14, 2011
0 characters
1 Points
Came with 2 cables for attachment - on longer type with 2 sets of pins to middle and one side and another smaller with 2 rows of pins - problem is monitor has 2 places to attach but the smaller has 3 rows...
The monitor comes with DVI and VGA (DB15HD 3-ROW HIGH DENSITY) connectors. If your PC only have VGA (DB-15HD) output for the monitor, then you need to use VGA cable (DB-15HD Male to Male) for connection. Hope I explained clearly.
Apr 01, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
Vga conector
there's no problem with the color (black,white,blue) it's doesn't matter.
Dec 17, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
My VGA plug is missing on my monitor
If the cable does not disconnect from the monitor, then go ahead and buy a new connector
I recomend this over buying a generic VGA cable and splicing wires, for better connectivity and less 'noise'.
Aug 06, 2009 | Neovo F-417 17" LCD Monitor
How do I find and replace the vga cable? (It is hardwired to the back of the monitor.)
I got hold of an old vga cable (15 pin), cut off the male end. I then cut the existing cable comming out of the monitor. After soldering the wires together and lots of electrical tape wala - it works.
Now the problems I incured - Don't solder wires together based on color, they probably will not match. Peel back the ends of the cut off connectors and find each pin with a Multimeter. Once you find each wires match solder them carefully and tape. When done test and if good place a short splint on the spliced area and tape. This will keep the wires from breaking from movement. Good luck.
May 24, 2009 | Sylvania SF150 15" Flat Panel LCD Monitor
you are in a bad spot, the plug is sealed when molded. maybe ebay has a defective monitor and you could take the cable off it.
Monitors will usually snap apart with a butter knife.
Jan 27, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
View sonic g220f
If both ends of the cable are plug in type, any monitor cable with a 15 pin D connectors will work.
Search internet for VGA cable.
Jul 30, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Phillips VGA Cable colour chart
you can use any vga monitor with the same color output and resolution setting just goto craigs list in your town and look for someone throwing one out detach old cable and reapply to your screen by either soder or splicing the wires independently together this is tricky
Pin Name Function 1 RED Red video 2 GREEN Green video 3 BLUE Blue video 4 n/c not connected 5 GND Signal ground 6 RED_RTN Red ground 7 GREEN_RTN Green ground 8 BLUE_RTN Blue ground 9 VDC 5 VDC supply (fused) 10 GND Signal ground 11 n/c not connected 12 SDA DDC / I2C data 13 HSYNC Horizontal sync 14 VSYNC Vertical sync 15 SLC DDC / I2C clock
Jun 02, 2008 | Philips 107E66 17" CRT Monitor
Put the connector infront of you and take biger size to top and smaller to down then count the pins like this-1=red,2= green,3 =blue(count the pins right hand side to left hand side),4=ground,5= blank,in lower row 6=red ground,7= green ground,8=blue ground,9,10,11=blank,12,15= in command section,13=horizantal synk,14= vertical synk.Hope this solution works otherwise i am always for help you.
Mar 31, 2008 | SAMTRON 55V 15" CRT Monitor
HP S5500 15" CRT Monitor Logo
21 people viewed this question
Top HP Computer Monitors Experts
Ivan Bernal
Level 1 Expert
Tony Isted
Level 1 Expert
Elizabeth Mescall
Level 1 Expert
Are you a HP Computer Monitor Expert? Answer questions, earn points and help others
