Question about Acer Aspire™ T180 PC Desktop
HP Desktop-Frozen on Blue Screen-Warning me of Virus
I need to know how to reset my HP Desktop to factory settings because it is frozen on a blue screen with yellow writing stating that I need to run an Anti-Virus disk!
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    hmm..factory settings..that would be from the bios setup, methinks..F2 on start..
Turn off system, remove the small 3 volt battery on the motherboard for about an hour and then re-insert and reboot.
- or -
Remove the CMOS jumper for 5 minutes and re-insert then reboot.
This should clear it up and let you get past that dreaded HP INVENT Blue screen. :-)
Posted on Apr 13, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 164 Answers
To get to bios settings its usually the key DEL wen it first boots up.
once there there will be a Restore default settings and then hit y then save and exit.
Posted on Oct 21, 2008
Message on desktop about error and reconfiguring active desktop with blue triangle curser frozen
Do you have a legal software version?
If you have you probably have a virus...
I hope i helped with this. if I dont say what else is wrong
Apr 22, 2014 | Dell Latitude E5400 Laptop
My android 3g T-mobile phone has a blue light on top and won't turn on even when hooked up to desktop with USB. help!!
you need to do a hard button reset and this will fix your issue 100%!!! i found the info at tmobile.com/forums.
myTouch: How to Hard Button Reset Options
01-11-2010 10:59 AM
If the handset is locked, frozen, or unresponsive, you can perform a master reset it using the hardware keys instead of the menu. A master reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. It does not erase data stored on the SIM card or memory card (if available). To perform a master reset using hardware keys, follow these steps:
1. If the device is responding at all, back up your data before proceeding.
Note: The device must be turned on to synchronize or transfer files.
2. Turn off the device.
Note: If the device is unresponsive and does not turn off, remove and then reinsert the battery.
3. Press and hold the Home key and the Power key for at least 25 seconds, even if the Startup screen appears.
4. Release the keys when you see a black screen with a warning sign.
5. Press the Home key and the Power key again.
6. When the Android system recovery utility appears, use the trackball to scroll to and select Wipe data/factory reset.
7. Once the device finished the data wipe, select reboot system now.
Dec 24, 2010 | Cell Phones
My hp pavilion a1110n is frozen on the blue screen and it won't reboot. I've tried to use the command keys but it does not respond.
To solve a frozen screen error, please run a bootable windows XP and repair "c/windows" on the hard drive. Follow the instructions carefully and let the system restart and proceed. Use the key written on the XP CD. After repairing, please an Anti virus (Kaspersky 7 or 2010).
Good Luck!
Jun 17, 2010 | HP Pavilion a1110n (PX743AA) PC Desktop
Blue screen with HP Logo is frozen on my lap top screen
try contrl alt del at same time hold for 5 sec if that does not work take batt out hope this helps
Oct 16, 2009 | HP Pavilion dv9000z Notebook
Magellan 3100 frozen on blue screen with black progress bar
where are you getting that error message, on the pc or the 3100
Aug 05, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Little blue box center (almost) of the screen, mouse operates and moves about however dont know where to clk, seems frozen ???? thx
Sounds like a software or memory problem.
Which operating system are you running ? Windows XP,Windows Vista,Linux ?
What programs are you running when you see the little blue box ?
Jul 28, 2009 | HP Pavilion N5310 Notebook
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Jul 18, 2009 | Palm Treo 650 Handheld
Screen is frozen, just blue background with Windows xp logo,
Is the screen frozen BEFORE or AFTER the screensaver activates? If it's after then try doing a scandisk and defrag of the hard drive to clear up errors. Also make sure to go into MY COMPUTER, right click the C: drive and in PROPERTIES runa clean up to delete the temp files that may be corrupted.
Apr 03, 2009 | HP Compaq nc6000 Notebook
Frozen blue screen
Hold down the power button for around 13 seconds and it will power down. Alternativly there is a small hole on the bottom of the unit where the connectors are for the USB cable, insert a coctail stick or paper clip into the hole and the unit will factory reset. I would suggest downloading the user manual from the Archos web site where these items are listed. I have had one for a week and no matter what I do or how many times I update the device it still is not stable, good luck
Dec 22, 2007 | Archos 605 WiFi Digital Media Player
Acer Aspire™ T180 PC Desktop Logo
280 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
