Question about Microsoft ChiMei CMV938D 19" Widescreen LCD Monitor
Elongated desktop and software screen images
A Chimei 19" CMV 938D monitor was purchased with a view to using it vertically for desktop publishing. The stand and mount were removed, rotated 90 degrees and reistalled so that the rather "lengthy" monitor stood upright to provide a "portrait" view of the screen. The desktop and all programs were then of course displayed "sideways" on the screen. Was unable to find any graphic card adjustments (for my existing card) or Chimei software or firmware that would allow the screen image to be rotated 90 degrees so it could be displayed in the vertical mode. The objective was to display the screen vertically so that when running Pagemaker, an A4 page being created could be viewed in full in "portrait" mode. Otherwise, on standard screens, it is never possible to see a "readable" version of a page - it is necessary to scroll to see the various sections of the page. Then a trial version of "Pivot" software was found that allowed the screen image to be rotated 90 degrees and this worked well with Pagemaker. BUT, the page proportions were incorrect. The A4 page was "tall and thin" instead of having the correct A4 dimensions. Clearly, this Chimei model is designed to deliver "digital TV" format and seemingly, nothing else. Does anyone have knowledge of any method of altering the relative proportions of the visible screen display? That is, make the horizontal (normally the "vertical" but now rotated 90 degrees) wider, without simultaneously making the vertical wider as well. The Chimei monitor controls allow shifting the image in the X and Y directions, but do not allow widening or narrowing. I'm stuck at this point. Another graphic card maybe? Ditch the "digital TV format" screen and try a conventionally shaped monitor? Or is there a hidden secret in Windows or another piece of software that allows the screen image size and shape to be controlled? Cheers, Sean You can email me on seanmclean@lycos.com.au
  • Anonymous Nov 12, 2008
    SAME EXACT PROBLEM!
  • 3 Answers
Many graphic cards enable you to rotate the screen up to 360 degrees. You could try to post this question again under you graphic card model instead of computer screen model as it is your graphic card that is certainly the problem.
Posted on Jan 19, 2008
Can I purchase a replacement stand for my chimei 222H monitor? If so where?
I have broken the mounting arm of my Chimei CMV 222H ...
www.fixya.com/.../t14977283-broken_mounting_arm_chimei_cmv_222...
Nov 12, 2012 - ... the mounting arm of my Chimei CMV 222H monitor, can you getreplacement arms? The locking mechanism - Chi Mei Corporation CMV-222H 22 inch LCD Monitor question. ... Video; Photos; Link; Replacement Parts. Add.
Repair Kit, Chimei CMV 221D, LCD Monitor, Capacitors ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Dec 15, 2015 | Computers & Internet
I have a 19" cmv
How old is it? If it still under warranty get it repaired, it sounds like the switch is gone or the energy saving s/w inside is bad and is not detecting when/when not to turn the display on/off.
May 22, 2011 | Microsoft ChiMei CMV938D 19" Widescreen...
Where can I download an English manual for a CHIMEI - CMV633A monitor. The ones on their site are only in Chinese. Thank You
try www.chimei.com.tw then you click on the English. it will give you the English version.hope this helps.or try www.scribd.com or www.w9drugs.org
May 07, 2011 | Chi Mei Corporation CMV-633A LCD Monitor
I have exactly same problem
Sound like your display is having issues with the inverter board. When the power supply detects a short circuit, it turn off by itself. When you try several times, you may be able to "bypass" the circuit protection but the damaged parts still having problems. This issue may be related with the DELL display issues.
The display needs to be fixed by someone with experience in electronics repair.
Sep 29, 2009 | Microsoft ChiMei CMV938D 19" Widescreen...
19"chimei Lcd. Screen stays black.
probably power supply, dac-19m015, 2200uf bad capacitor.
Apr 26, 2009 | Microsoft ChiMei CMV938D 19" Widescreen...
Monitor problem
Hi, sandjkroll, this kind of problem could be because of ur monitor or even because of the on board display  card on ur motherboard. To check ur monitor, u unplg display cable which goes to ur cpu and the power cable which goes to ur cpu.
Them connect the power plug to mains, so no cable from the monitor should go to the CPU. Then u swithch on the the poower suply, and on the monitor. I
If ur monitor displays elongated screen still, and shows signal not found,and no display comes that means ur monitor needs to be send for service. and if there are no elongated screen and says no signal found, ur monitors fine, ur motherboad has a problem
From
Deepak
Sep 28, 2008 | Microsoft ChiMei CMV938D 19" Widescreen...
Chimei CMV 938D 'Out of range' error message only when using DVI Connector on specific resolution and color depth
I know this sounds obvious but- I had the same problem, and turns out the cord want plugged in quite properly at the back of the monitor. This may not fix every problem, but, I suggest you check the cord pligged in at the back of the monitor is firmly in there and restart, then if you still get the problem, contact the company.
Jul 21, 2008 | Envision EN-7100e 17" Flat Panel LCD...
CHIMEI CMV938D 19 WIDE SCREEN LCD volt
I have the exact same monitor and it is 220v. But seeing as i bought it in Australia that makes sense. If yours was purchased in North America then it is almost definitively 110v. It is likely that it is written on the actual monitor. If in doubt you could always try it with 110v. If that works then theres your answer. If it doesn't then its probably 220v.
Oct 17, 2007 | Microsoft ChiMei CMV938D 19" Widescreen...
Computers & Internet Logo
583 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
