Question about Nikon F65 35mm SLR Camera
My camera won't load film
Alright, so i tried loading a 36 exp roll of film into my camera, chut the back, and the camera rolleed the film. in the number of exp area it only says "1" and above the battery symbol it says "FEE" what is this "FEE" and why can't i take my pictures?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
Set your lens to the smallest aperture ( largest number on lens ) f/22 or f/32 and lock it in place with the small latch on the aperture ring. The camera won't operate in auto modes without the lens set there.
Posted on Nov 18, 2008
My camera will begin to turn on but the flash settings won'
is it the auto film load feature on this camera doing this ??? it maybe the type of film u use , most auto loads are not to forgiving on the different types of film , I had this problem as I still use a film camera a lot for infrared photos (digitals too expensive ) and have found that its real picky on whos film I use to weather it works or not , as on some brands of film it just goes on and on and never stops , the only way I can save it from being ruined is to tell it to rewind , it then sucks all the film back into holder and I try it again ,sometimes works sometimes no
Aug 17, 2016 | FUJIFILM instax mini 8 Instant Film Camera
Camera keeps sucking the film back into the canister instead of loading it
Check the bottom DX pin in the film chamber. These get bent easily and it is also used for the film detect switch so that the camera knows there is film in the camera.
Dec 10, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
The new roll of film winds into the right spool upon closing back cover // brand new batteries displays 1/2 and ERR appears on led panel
Is the ERR blinking, and is there an additional blinking E on the display? If so, the film is not loaded properly.
The film is supposed to advance all the way to the take-up spool upon loading. The camera then "rewinds" one frame at a time as you take pictures. This way the camera knows exactly how many shots are left on the roll. Also, if the back is accidentally opened, the shots already taken are already in the can and won't be ruined.
If you need a manual, you may download a copy here.
Try cleaning the battery contacts and see whether the battery reads full with no film in the camera.
If problems persists, feel free to reply to this post and give any additional details.
Mar 04, 2012 | Nikon N75 35mm SLR Camera
Film-advance warning won't go away on a RB67 Pro SD 120 film back?
Mamiya RB67 Pro SD that is new to me. loaded the film correctly took the first shot. But, the film won't advance. What am I doing wrong?
Feb 18, 2012 | Mamiya RB67 Pro SD Medium Format Camera
Hi i recently bought a used F3/T. Just ran a 36 exp roll and everything seemed to work fine. However i realized on loading a new roll, that the film counter did not reset. It remains at frame 37. How can i...
This won\'t be easy for you if you don\'t the proper tools, You have to remove the wind lever assy, and the speed dial, Then wind side top cover, Then pull wind base plate assy, And check counter reset lever, to make sure spring didn\'t come loose, Putting the baseplate back on can be fun because of linkage to the wind assy
Sep 29, 2010 | Nikon F3HP 35mm SLR Camera
Film will not load
Took out the battery, then put it back in. The film then loaded properly.
Jul 21, 2008 | Kodak Vivitar KV270 Film Camera
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Jun 11, 2008 | Fuji Discovery 185 Zoom 35mm Point and...
N75 will not load film
Quick solution: force a manual rewind.
1. Remove film
2. Close camera back.
3. With the power turned on, press the two rewind buttons together. They are marked in red.
4. The camera will make a rewind sound and will stop after about 2 seconds.
5. DO NOT fire the shutter yet.
6. Put the mode on Manual and select a fast shutter speed like 1/90 sec. Any aperture will do.
7. Load the film correctly as given in the user's manual.
8. As you close the camera back, the film will prewind to the end of roll. At the end of the roll pre-wind the LCD will show you the total number of frames available.
9. Select any shooting mode.
10. Go on and take pictures.
Hope this helps
Dec 14, 2006 | Nikon N75 35mm SLR Camera
Nikon F65 35mm SLR Camera Logo
148 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
