Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Fridgidaire side by side
Moved it 10 miles. it had to be layed down. let it sit for 24 hours and turned on. now no cooling. fan runs. vacuumed all the coils.
  • jdcompian Oct 22, 2008
    the fan for the fridge side comes on. the compressor does come on but no cold air
  • Avatart May 11, 2010
    Is the compressor coming on
    Problem Solver:
  • 10 Answers
If the compressor is starting up and there is no cooling effect on the coils in the freezer that would mean you lost your charge or the compressor bad (Unlikely). I would take the back panel off the inside back of the freezer and observe the coils. With the compressor running you should see a coating of rime or frost building up on the coils. If you don't see this you probably lost all the coolant. I've seen this often after a move. The condensing coils under the fridge get poked, it doesn't take much to puncture them.
Posted on Oct 22, 2008
Transporting a Kenmore front load washer and gas dryer
Yes you can lay them down. Some modals call for 24 hour reaping time before you can plugin to run. Reaping meaning some modal have the new R134A coolant in them so if they lay down wait 24 hours before use. Gas you can just lay then down and brace it so it can't move around.
Aug 02, 2016 | Kenmore Washing Machines
Why doesn't it run after being moved across town?
laying down is a no no and has to stand turned off for about 24 hours so the oil returns to the compressor . quite likely you have burned the compressor up using it too soon .
Sep 20, 2015 | Refrigerators
Moving my fridge on it's side or at an angle
You can lay it down but if you do, when you stand it up, wait 24 hours before you plug it in to turn it on. The reason is because the oil in the cooling system has to settle after being layed down.
Jun 01, 2015 | KitchenAid Kitchen Aid - KSC23C8EYY...
My refrigerator wont work after laying it down to move it. What should I do?
I've done that before and there's no hope for it. Once you laid it down the freon got a air pocket in the compressor and it will no longer work. Guy from sears told me that laying them down ruins them.
Feb 20, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
I am moving and need to lay the fridge on its side, but have been told you cannot do so, is this correct?
You do not want to lay that refrigerator on its side because the refrigerant will leave the compressor and fill the system with liquid refrigerant where it should only be existing in a gaseous state, and if the refrigerator is tilted far enough over or lay-ed onto its side then the refrigerator will have to stand up-right and un-plugged for at least 24 hours before the liquid refrigerant will settle back down where it belongs, and then the refrigerator should actually function again if there was no other damage caused when moving the unit.
Sep 21, 2010 | Sanyo SR-3660S Compact Refrigerator
I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Mar 07, 2010 | Freezers
I bought a side by side today from a friend and it was working fine got it home and now its not cooling??
Did you lay it on its side? This can cause a freon restriction, sometimes you can save it by unplugging it for a few days and then testing it again. Also check to see if you bent the condensor fan blade or bracket when you used a shipping dolly to move the refrigerator. Remove the backing panel on the lower back of the refer and make sure the fan is running. Good Luck, Appliance Specialists.
Feb 16, 2010 | Refrigerators
I have a GE side by side.. When we got home last night I noticed some water on the the floor and the power was on inside the refrigerator but the cooling apparently stopped working. I moved the fridge and...
The defrost timer will turn off the compressor and its cooling fan. At the same time it turns on the defrost heater, and usually leaves the freezer fan running. Defrost can take half an hour, easy. As soon as the defrost thermostat is satisfied, the defrost heater is supposed to turn off, and the compressor may come back on. The defrost timer is about the size of a cell phone, with about five wires going to it in a plug. It has a small dial on it that only goes one way. You can mark it and wait a half hour to see if it moves.
Apr 14, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
59 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
