Question about Compaq Microportable 2810 Multimedia Projector
Infocus IN1 Gaming Projector
I have recently purchased a IN1 Gaming Projector however, after i have turned it on and it has warmed up it just turns it's self off with no warning, or display to indicate that it is over heating.
Is this may be just the lamp or something more terminal
  • rsanderlin21 Mar 14, 2009
    I have an IN1 Infocus gaming projector also. I have had it for about 4 months and it just started shutting off after about 10-15 min. After looking at many reviews for this projector I have found that it is a regular problem with all the infocus projector models. One tech called it an "irregular shut down" and the lady who had it had to send the whole projector in to be fixed. If the company has this problem so much then why is there no recall to fix it.
Send it in to Infocus to be fixed, or try the fan thing.
Posted on Mar 14, 2009
Hi, I just bought the same projector Infocus IN1 and after just 15 minutes of use it turned off due to overheating. It seems that the lamp is very ineffecient and produces too much heat. The ambient temperature in the room is only 16 deg. celcius.
The solution I came up with is to have a standing fan blowing air directly on the back of the projector from less than a foot away. The standing fan which we usually use here in summer was enough to keep the projector cool. The infocus IN1 did not switch off for the next 2 hours (the entire length of the movie), until i turned it off myself. I am not sure how this system will fare in summer when the room temperature reaches 30 deg. celcius.
Posted on Jan 12, 2009
What kind of bulb do i need for it? What do i need to show movies ?
sp-lamp-030. you can try projector doctor. they may have it.
Mar 14, 2010 | InFocus Play Big IN1 DLP Projector
Black and white stripes, no picture
just clean your projector board that connected to the main board, just clean the port.
Oct 08, 2009 | InFocus Play Big IN1 DLP Projector
My infocus IN1 projector won't turn on anymore.
It may be the lamp is out. Normally a projector will try & fire the lamp 3-5 times then shut down with a different color light like amber or red. If the lamp doesn't light then it could be the lamp or perhaps the lamp ballast that starts the lamp has failed. A stuck fan also causes similar symptoms. There's 2-4 fans in the projector if one is stuck or bad it will turn off within 5 seconds or so after the lamp lights.
Does your lamp light at all? Are the lights a different color after it shuts down? Answers to these questions help figure out what's wrong though it's impossible to say for sure without looking at it. I service almost all Infocus projectors if you would like a quote please reply with your email address or write me at prmhelp@earthlink.net
Good Luck,
Jim
Jul 24, 2009 | InFocus Televison & Video
My in1 projecter keeps turning itself off
if the lamp has 2000 hors on it, it needs replacing. go into the menu and find out how many lamp hours are used. it could be the lamp and it could be the ballast.
Nov 23, 2008 | InFocus ScreenPlay 4805 Multimedia...
Problem with the InFocus IN1 Gaming Projector (when recieved) - No red, constant yellow tinge and constant lines.
It is because the xbox 360 is set to 60hz, change it to 50hz and it will be clear like it's meant to be. However, some 360 games are 60hz so for those games the quality is not good.
Aug 10, 2008 | InFocus IN72 Multimedia Projector
I recently bought a infocus in1 audio projector and i cannot get sound and picture together. only seperately by pressing the input botton
Sounds like you have the video and audio plugged into different inputs. For example the video is going to video 1 and the audio is going to the audio input of video 2
If you get only video one input and only audio on another input... Then the above described connection is the only thing that would cause this to happen!
Cheers
Jul 29, 2008 | InFocus Play Big IN76 Multimedia Projector
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the projector.......help!
Feb 24, 2008 | InFocus X1A Multimedia Projector
Compaq Microportable 2810 Multimedia Projector Logo
478 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
