Question about Kenmore Elite 45986 Front Load Washer
Dryer will not start, pwr ok
Dryer won't start, pwr ok, contact noise
  • 63 Answers
Door switch or therm fuse on top of blower wheel housing if not poss main board
Posted on Nov 14, 2008
Dryer comes on but won't start any cycle. What could be causing this?
Samsung Dryer Won't Start - Model DV448AGPXAA - Repair ...
www.repairclinic.com/...Dryer/...-/Samsung-Dryer-won-t-start-DV448A...
Samsung dryer won't start? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Dryer Won't Start - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/How-To...Dryer/...---/Dryer-won-t-sta...
If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a ...
Troubleshooting Why Your Dryer Won't Start ' PartSelect ...
? 4:47
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
Oct 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer might not be starting. ... If it makes noise but won't start trying spinning the drum empty ten times then close door and try it. ... I changed the door switch and still gives code AU. any suggestions .... thermal fuse everything seems good except my dryer won't come on!!!.
Samsung Dryer DV431AEP - won't start cycle - Appliance Repai
Jan 10, 2016 | Samsung Dv410aew 7.4 Cuft 11-cycle Steam...
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
see this causes and fix it. God bless you
Sep 28, 2012 | Dryers
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
LG DLE2301R no power up when pressing start. 240V at term block. Also pwr on both heating relays (white + Blk) on cntl board. nc contact working on door switch. Seems that control unit is bad. jim
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 15, 2011 | LG DLE2301 Electric Dryer
My hp 7060n won't pwr on. I checked the ps it test
I don't think you know what you are doing. No computer will boot without memory! And no mo bo will work without the 4 pin connector being attached to mo bo along with the 20/24 pin mo bo connector..
Listen, keep it simple and just plug in another known working ps to see if unit works. If it still does not work, then your issue could be corrupt bios, bad hard drive, corrupt OS, bogus peripheral, bad memory.
Sep 16, 2017 | Computers & Internet
Dryer won't turn over/start. When push start switch makes noise but won't turn. If hold door closed switch and turn manually while pushing start button it would work for awhile, but that has...
heatman101
Sep 05, 2011 | Amana Dryers
My Maytag Dryer won't start. Mod.# MDE3000AYW . The on button makes the right noise like it is going to start but nothing happens. Sometimes I get lucky and it will start but most of the time it just...
heatman101
Jul 05, 2011 | Dryers
Whirlpool oaisis dryer will pwr on, but when start pushed-clicking noise and dryer won't start. Must pwr dryer back dwn to be able to change any timer setting, but dyer still will not start. ????
Model is 110.6705 Oasis Kenmore elite. Have removed back cover and have found drive belt broke. is there a seensor to shut motor dwn if belt breaks? Will order belt replace and see if thay resolves issue. Thanks
PS
No code given.
Oct 16, 2008 | Whirlpool Dryers
Kenmore Elite 45986 Front Load Washer Logo
44 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
