Windows xp hangs up
In safe mode it runs properly. but there is no sound on system. in normal mode the system hangs then start for sometime than hangs up. i scan it for viruses the result is clean. wat shud i do
  • 790 Answers
I guess there are many programs which tries to initialize when the system starts. So try disabling it .. Goto RUN command and type msconfig and then goto startup , there u disable the programs..and about sound try re installing the sound drivers!!!
Posted on Oct 21, 2008
I changed my os from windows xp to windows 7...and i am using amd sempron (tm) processor 3400+ 1.80ghz..and 40 g hard disk..then the windows start up wont start normally. pls help!
Try hitting F8 just after your bios splash screen, before it would show the windows logo.
Select, boot in safe mode with networking.
Once you are in windows 7 safe mode, you can install any required drivers. This might prevent it from hanging on the next normal boot.
You can type in the run dialog CMD. This will open a command terminal. Type "SFC /scannow" without the quotes. This will tell windows to verify it's files. Let it complete, then reboot normally. Hopefully the problem will be resolved!
Mar 25, 2011 | Computers & Internet
My laptop starts properly with the normal starting procedures when when started (with windows vista home premium 1) The mouse gets hanged and keep circling 2) The internet display that is network when...
Good Moring,
I have seen this behaviour in computers with virus (maleware) you can try the following
1)start your antivirus while log in safe mode and run a full scan
if virus is found remove it and start windows normally run a full scan afterwards
2) if no antivirus is install, i would recomend you to reinstall the OS
Nov 15, 2010 | Dell Inspiron 1525 Notebook
I have windows xp home edition and it won't load up. The windows logo comes up then it freezes up and the red light on the tower goes off. There is no way to shut down so I have to unplug it and try to...
Hold down the f8 key while starting or booting up.
Choose start up normally.Once started,Select disk cleanup from your program accessory system tools area.
Then choose disk defragment and let it run,this may take an hour or two to complete.If your using an anti virus program do a full computer scan.If not then get one AVG is free and works well for anti virus.
Last,yo may need to clean out any dust or dirt from the inside of the pc case with a vacum or a rag check the fans for proper operation.
Aug 29, 2010 | Microsoft Windows XP Home Edition
I cannot logon to my PC
Start your PC in safe mode, to do this repeatedly tap the F8 key as soon as you turn the power on. This will then bring up an "options" screen listing boot in safe mode, safe mode with network support etc. Just use safe mode. If it goes directly to windows instead - shut it off and try again til u get the safe mode screen. The arrow keys control the selection to choose.When it starts in safe mode a black screen will usually appear with a bunch of writing, this is normal, after that it may "hang" for as long as 5 minutes, before coming up with a login screen. Sometimes hitting enter or escape will bring up the login screen faster. When you have a login screen, login and disable the updates using the software control options for the software that is trying to update. You might also go to control panel, administrator options, then services and disable automatic updates temporarily. When your pc starts in safe mode - it starts with minimal drivers and does not run updates- this allows you to change settings. You can then reboot normally and it should start properly without updating before starting.
Aug 29, 2009 | Acer Aspire AM1610-U1201A PC Desktop
Try booting into safe mode. If it's a driver problem, safe mode will allow you to start Windows with only the bare minimum of hardware and drivers being engaged. To get to safe mode, press the F8 button on your keyboard during the Windows boot process until it takes you to a screen to let you select Normal, Safe Mode, Safe Mode with networking, etc. I would suggest not using anything other than just Safe Mode. From there, uninstall any software or new drivers that you recently installed. Alternatively, you can use the System Restore feature to rollback to a previous restore point.
Aug 10, 2009 | HP Computers & Internet
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by
May 24, 2009 | Microsoft Windows XP Media Center Edition...
XP professional goes wonky
you are repair the xp professional. First you insert the xp professional cd in your cd-rom then you can repair the operating system.
Mar 01, 2009 | Microsoft Windows XP Professional
Start Normally (black screen with options)keeps re-loading itself
If you can't get into windows normally or into safe mode to try to restore the system back to a date when it worked properly then you'll need to wipe out the hard drive and start the system from scratch.
Feb 08, 2009 | Compaq Presario SR1050NX (DW257A) PC...
Hanging problem
look like the winamp audio porblem.
uninstall it.
try to clean up the hard drive by using defregmentation.
reinstall the winamp again.
Oct 20, 2008 | Microsoft Windows XP Professional
Will not start up
if at all, the case is tat, it just starts ur computer and gets hanged at a stage where, ur motherboard company name is displayed, then,
click del button, and there, in settings, u enable quick boot and restart, and it will work..
pls, let me know , i f it works
Jul 17, 2008 | Computers & Internet
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
