Question about Sharp AL-1642CS Copier
Reset the drum on a sharp al 1661
I have replaced the drum but do not know how to reset the counter
    Problem Solver:
  • 11 Answers
Press c interrupt c interrupt within 15sec display goes off enter 24 press start button enter 7 press start button 000 blinks press ca to exit from the program or restart the machine.
Posted on Nov 28, 2008
How to reset the alarm indicator drum cartridge replacement in my copier machine sharp AL-1217D and it is necessary to reset the machine if you install a new drum unit? please help.
to reset drum counter u have to go in simulation clear density clear density enter 24 press start button where u normaly press to make copy then enter 7 again press start button off your machine and back it on that,s it
Aug 28, 2013 | SHARP AL-1217D
We just replaced the drum and now are getting 'shadow' images of our documents on every copy. The image starts about half way down the page.
After replacing the drum, did you reset the drum counter? Also, it is best to change out the developer at the same time you replace the drum, this is because both the drum and developer need to be calibrated with each other.
It sounds like you didn't manually reset the counter and now the charge on the drum is to high, I would suggest not using the machine until to reset the counter.
Let me know.
-David.
Nov 05, 2010 | Sharp AL 1631 Copier
Do you know how to reset the drum counter for Sharp Al-1641
Reset the drum count by pressing "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode"
Exposure mode is far left key on panel. You need to do this fairly quickly so that the display goes blank.
Once display goes blank then key in 24 then press print, then key in 7 then press print. You should now be getting flashing 000
Turn machine off then on and light should be gone.
Short version: C,far left,C,far left,24,print,7,print
Dec 30, 2009 | Sharp AL-1641CS Laser Digital Copier
Reset drum counter on Sharp AL-1644
This works on MOST sharp AL series copiers.
Press these keys in sequence:
Clear → Density select → Clear→ Density select
display should go blank. Then enter:
24 as if you were making 24 copies then press print
then enter 7 as if you were making 7 copies then press print
if successful you should see flashing 000
turn machine off then on again and the drum light should be gone.
Good Luck
Nov 03, 2009 | Sharp Office Equipment & Supplies
Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Oct 16, 2009 | Sharp AL 1631 Copier
Need reset code for Sharp AL1631 copier drum
USING ONE FINGER PRESS CLEAR, AUTO(EXPOSURE SETTING), CLEAR & AUTO YOUR DISPLAY WILL GO BLANK, IF IT DOESN'T GO BLANK TRY IT AGAINSOME MACHINES ARE TEMPERMENTALWHEN YOU GET IT GO BLANK PUNCH IN 24 THEN PRESS THE START KEY THEN PUNCH IN 07 AND THEN PRESS THE START KEY AGAIN. THAT WILL RESET THE DRUM COUNT. TO GET OUT OF THAT MODE PRESS CLEAR A COUPLE TIMES OR TURN IT OFF & BACK ON
Apr 09, 2009 | Sharp AL 1631 Copier
Reset the copier counter AL-1641CS
Which reset are you trying to preform
the counter for the drum unit ?
Apr 01, 2009 | Sharp AL-1641CS Copier
Locked up AL-1642CS with blinking Drum Light
Older Sharp AL copiers will go on working with the drum light blinking, but yours will not. Newer models do stop working when the drum reaches its limit. Now keep in mind that just as almost every copier in the market, these units count the copies they make in order to determine toner & drum life. So it is possible to reset the drum counter if you inspect the unit and see no markings or visible wear & tear. Also keep in mind that the toner & drum units have been the same for all AL units through time, so there are plenty of good replacements in the market (not recycled, but re-manufactured or brand-new compatibles).
As for your unit, if the drum is Sharp original or a good quality replacement, you should have to do nothing after installation, for the internal chip in the drum will tell the copier to reset the counter and begin working automatically. However if that is not the case, or should you want to reset the counter on your existing drum, this is the correct sequence to do so.
  1. Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying.
  2. Now press the following sequence of buttons: [CLR], [EXPOSURE], [CLR], [EXPOSURE]
  3. Your unit should turn off the numbers in the panel.
  4. Now press 24 as if asking for 24 copies and press [START].
  5. Press 07 as if asking for 7 copies and press [START].
  6. Your unit should restart by itself and start working normally.
Be blessed.
Nov 07, 2008 | Sharp AL-1641CS Laser Digital Copier
Drum light
Check a service manual on resetting the drum counter. You have to reset this counter to tell the machine it has a new drum
Aug 25, 2007 | Sharp AL-1641CS Color Copier
389 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
