Question about Onkyo TX-DS575 Receiver
More Bass Is there some known defect w/ this unit. The Bass control really does not change the sound whether it is 1/2 way or all the way. Just for info. The rear surround channels on this unit DO NOT have any bass information. The manual calls this out. Is this unique? Thanks for input. CK
    Problem Solver:
Go to front and make it say small that should do the trick.
Posted on Aug 24, 2007
SOURCE:
What is wrong? my active bass whether i put a new battery in or not sounds passive no change whatsoever. quite a bit of the low end is severely missing. Schecter STARGAZER 5 bass.
That bass combines passive EMG pickups with an active preamp (which provides the bass and treble controls). Sounds like you are never getting the preamp to work, and if that is the case there could be numerous reasons...a dead battery...jack wiring that is broken (meaning the battery ground wire is not attached or is grounding out)...likely should see a tech, but that is a good sounding bass when working correctly.
Feb 07, 2013 | Schecter STARGAZER 5 Bass
Switch Noise
Try moving the unit away from power sources, for examples power adapters etc. The noise it is probably because of a faulty transistor or IC in the AMP section of the device.
To fix this you need to take unit apart and test components on the Amp area of the board, as this happens with all devices it is the final amp section having troubles.
Strange thing that device restart normally after this.
Aug 31, 2008 | Audio Players & Recorders
Tip
Noise Control and Being a Good Neighbour
Whether you live in a private dwelling, or in a multiple home dwelling, such as a condo or apartment building, one should pay attention to controlling the sound from home theatre and stereo systems. In this case, we are generally talking about managing the bass frequencies of the sound system. High frequencies tend to be absorbed by common building materials. The physical/mechanical aspects of sound transmission are complex, but the average person can apply some simple and inexpensive methods to minimize the unwanted transmission of bass frequencies beyond the listening space. <br /> Transmission of bass frequencies can often be controlled by placing bass-producing speakers on pieces of rubber material. These can be as simple as scrap pieces of rubber mat, salvaged rubber feet from other equipment, etc. The physical placement of speakers can determine the amount of bass frequencies that the sound system produces in the listening space. Generally, more bass is generated by placing speakers in corners, and along the shortest wall of a room. <br /> Of course, adjusting the bass and volume controls is a method that can be used to satisfy personal tastes or to control the sound in any situation. Many home sound systems now employ a subwoofer to provide enhanced bass response. This can add lifelike sound quality to the home listening experience, but it is probably the source of most noise complaints. The subwoofer channel of most video program sound tracks has more bass intensity than one generally finds in television, radio or music sound sources. To prevent disturbing the neighbours, one should employ all of the methods detailed above, to reach a happy medium of being able to enjoy full spectrum audio within reason. Personally, I ask my neighbours listen in their homes, while I adjust my maximum sound system volume to a level that they would not complain about. <br /> <br /> <br /> <br /> <br /> <br /> <br /> <br />
on Oct 28, 2010 | Audio Players & Recorders
I have a problem with my z-5500! the bass is really bad, on all the effects. my friend has the same pare of speakers han his bass is really good. what should i do???
Always make sure that your computer settings for audio are checked and set accordingly and that all the equlizers and audio programs that are installed and controlling your audio sound output are accounted for and adjusted properly.
Feb 07, 2012 | Logitech Z-5500 Computer Speakers
I can't get any real bass out of this unit. Iv'e gone thru the manual 20 times and I set the "DZE" off, then adjust the bass to max and it made a little difference. But this unit is suposed to...
Try to exchange one speaker connections only, unplug connector from speaker and put them + to - and - to + pins.
In my opinion, both speakers are giving out of phase sound that cancels the bass sound, speaker connections should be same phase to get bass sound so just change connecting two wires at any one speaker, that will work.
Thanks.
Nov 26, 2010 | Clarion DXZ785USB Car CD/ MP3 Player
I am using a creative speaker. bass speaker is working well except for the small ones. is it shortwired or grounded? volume adjustment is also not working. only 1 small speaker is working but still...
navigate to control panel, select sound and audio devices. select advanced the volume control appears then set the balance to be at the center the on the other advanced option, select desktop stereo speakers. thanks.
Jun 22, 2010 | Creative Labs Creative Black SBS350 2.1...
My bass guitar wont connect to my amp.
Assuming that the amplifier is functioning properly, I suspect that the problem is either in the cord, the plug socket on the bass, or the volume control potentiometer. First, I would try another cord that is known to be in good condition (ALWAYS plug the cord into the instrument FIRST). Second, carefully remove the cord receptacle plug from the bass and examine the solder joints (check for loose wires). Third, carefully remove the plate that holds the volume and tone pots. Examine these controls for loose wires or faulty solder joints. CAUTION: If solder joints are found to be the culprit, care must be taken to correct this problem. If too much heat enters the pot, it can be ruined!
Dec 31, 2009 | Music
Will not put out sond
Hello billyelder,
If the amp is powering up but not producting any sound, there are 4 possible causes.
1) Incorrect or faulty wiring.
2) No input or input too low for the amp.
3) Defective speakers.
4) Incorrect amp or head unit settings.
Start by checking all of the wiring and onboard fuses. Especially check the speaker wiring and make sure there are no shorts or grounds and that the insulation is not nicked or frayed. Check the RCA cables by substituting a known good pair. Check the receiver (head unit) to see if there are any settings that need to be turned on for the preamp outputs to work.
Test the speakers on another output to determine that they are functional.
Check the amp settings and insure that filters, crossovers and gain controls are properly set. If your wiring and the settings all check out and the speakers work on another output, the amp itself is probably defective.
Hope this helps.
Sep 01, 2009 | Audiofonics ADF-241 Car Audio Amplifier
AMP POWERS UP, I CAN HEAR IT WORKING BUT THE SOUND IS REALLY REALLY LOW...
Hello korre,
Low output could be the head unit, the speakers of the amp itself. Start by isolating the problem.
1) Test the sub(s) on a known good output.
2) Input a known good signal. A portable with RCA preamp outs will work OK.
After you have eliminated the other components, troubleshoot the amp itself:
1) Check the onboard fuses. The M605 has 2 each 30A fuses just to the left of the power and ground terminals.
2) If it was just installed, then my first suspicion would be a problem in wiring. If one tiny little strand of your speaker wires comes into contact with another wire or ground point, it could present just enough of a signal path to ground out most of your power, and perhaps still allow the amp to seemingly operate normally (at least for awhile). Check power and ground too.
3) Make sure your head unit RCA's are plugged into the inputs and not the outputs.
4) Check the low-pass and subsonic filter settings. If low pass is turned all the way down, the amplifier would ONLY send frequencies below 30Hz to the speakers. Subsonic turned on and the low pass all the way down would effectively result in no sound.
5) Remove the top cover to access the mode controls and display. Check the input level.
If everything checks out, the amp probably has a defective component and needs factory/service center repair.
Hope this helps.
May 06, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
JL 300/2 v2 Power Light Blinks, No sound out of Sub. Works in friends Car HELP
Are you sure you don't have any shorted wiring or defective speakers?
Sep 30, 2008 | Jl Audio 300/2 Car Audio Amplifier
Onkyo TX-DS575 Receiver Logo
69 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
