Question about Canon MV750i Mini DV Digital Camcorder
No power Can get no power, have purchased new charger/DC in, but camera will not work on DC , battery power does not work no charge light comes on.
  • dtfix Apr 10, 2009
    I have the same problem and want to attempt a repair. For what Canon will charge, I may as well just buy a new camcorder!
    Does anyone have the instructions to take the unit apart to check the main board?
    New Friend:
  • 55 Answers
There are 2 or 3 very small fuses on the main circuit board. These are commonly termed "Surface Mount" They are approximately 1- 1 and a 1/2mm long and only half the width. They are white on the face with a letter on them. These are fuses of which you can if you are very careful and with a fine tipped solder iron, replace.
To determine the faulty one, use a simple multi-meter and test for continuity across the fuses in turn. The fuse with an open circuit is faulty ie...does not read on the meter.
If you are silly enough to use a piece of fine wire to bridge the faulty fuse...then be it on your own hands...but remember, THE FUSE BLEW BECAUSE OF A FAULT and the wrong rated replacement could cause further failure if it is not able to "BLOW"
Posted on Aug 05, 2008
SOURCE:
Z1015 won't charge battery internally. this battery was working
Hello, Is the battery in the camera or in the charger ?? Don't quite understand the question. You wrote "received correct wall charger AC/DC ?" was that a question concerning the new charger ? it sounds like your not quite sure about the charger.
Best Regards, Russell
Dec 31, 2012 | Kodak EasyShare Z1015 IS Digital Camera
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
I lost the adapter/charger and purchased a new one of the same size. The light will work when plugged into the car cig lighter, but not while plugged into the dc adapter (has been plugged in for approx. 3...
The battery life for these lights are for about 2 years at the most if left uncharged. The best way to determine if you need new a new battery or batteries would be to dismantle the light, remove the batteries and check the voltage with a volt meter. If they are dead, you may be able to fine a suitable replacement at: http://www.batterymart.com/c-04-12-volt-sealed-lead-acid-batteries.html
Nov 12, 2010 | Vector 20 Million Power Series Spotlight
Will no charge
Same with my SVP DC-12V Bought a new battery, same problem, bought a new charger, same problem.
I guess now I'm regretfully going to agree with the majority of
SVP camera owners and say that they are pieces of **** !
Jun 11, 2010 | SVP DC-12V Digital Camera
Charger lite will not come on! there is power to charger and if you wiggle lite the charge lite will blink but not stay on
It sounds like the battery is completely dead. Try placing it in the freezer for a couple of hours and attempt to charge it. If that doesn't work, you will need to know the make a model of the flashlight it goes in as well as the voltage. If you have to purchase a new battery I would suggest you purchase a Nickel-Metal Hydride (NiMH). NiMH's have much higher capacity than NiCd's and don't suffer from memory effect.
May 20, 2010 | Streamlight Ultrastinger Rechargeable...
My battery will not charge. I purchased a new
The flashing on a charger usually means that the battery is defective or will not take a charge. I would take the battery back to the vendor and have them check it. A good indication is that if your old battery took even a small charge, it is not usually the charger that is the problem. It points to the new battery being faulty.
Jan 12, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
Cant get my hitachi dz-acs3 ac adapter battery charger to work
the light will not come on when it is plugged in and the batery is set in the charger to charge, even with the dc out power supply the dvd cam will not work, could the charger go bad? does this happen often?
Sep 15, 2009 | Hitachi DZ-GX20A DVD Camcorder
My Sony Handycam DCR-HC30E mini DV is not working
In many cases I found DC Jack defective in this model and resulted does not charge battery through ac charger nor power up directly with ac charger.
I would suggest to check ac charger and battery on similar model Sony camcorder and I think your camcorder has DC jack problem thats why camera is not getting power from ac charger.
Jan 08, 2009 | Sony Handycam DCR-HC30E Mini DV Digital...
Battery Will Not Charge
Hi amber_penn, battery charging problems usually come from two sources, the battery or the battery charger.
Check the contacts on both the battery and the charger for oxidation, dirt, etc. Try cleaning the contacts with a little alcohol on a swab. The charger seemed to still work judging from the humming sound. Next step would be to buy a new battery.
Try to follow this link http://www.livingroom.org.au/photolog/reviews/miscellaneous/norcent_dc420.php
Mar 29, 2008 | Norcent Technologies DC-420 Digital Camera
Camera will not charge the battery
Well. Ive got the same problem only ive gone thru 3 batteries trying to figure out what the problem is. When i plug it in to charge the light turns red , then within 5 sec's turns green. It stays green but never charges the battery. After 24 hours, its still a dead battery. Im just assuming since its 5 years old that the internal charger is shot. Looking for a new camera at this time.
Aug 20, 2006 | Gateway DC-T50 Digital Camera
Canon MV750i Mini DV Digital Camcorder Logo
276 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
