Question about Bosch Washing Machines
The rubber seal on my washer has mold on it. I would like to have it replaced. can you recommend a repair person in my area. zip code 48302
  • 62 Answers
Look up A&E appliance repair. There everywhere.
Posted on Oct 22, 2008
How do I replace the front door rubber gasket and seal ring?
Greg, new seal but need to know how to swap it out. Check the attached links,instruction and guides, If you want to google your make and model Washing Machine door seal replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Replace Washing Machine Door Seal
How to replace washing machine door seal on Hotpoint washer
http://www.how-to-repair.com/help/how-to-replace-whirlpool-washing-machine-door-seal
How To Replace Front Load Washer Door Boot DIY
Jul 25, 2016 | Washing Machines
Mold and mildew and a musty odor. I can see black mold around the door seal, primarily at the lower side of the door seal. Can I attempt to clean by using bleach? What are your recommendations to correct...
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((^^&&
Sep 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Torn front grey colored rubber seal, is this repairable?This rubber seal is covered with mold
These seals are not fun to replace for the average person. There will probably be a spring clamp around the front of the gasket which you can remove with a good pair of needle nose pliers. The back side will be held in with another spring or a screw clamp. If you install a new gasket just work from one side clockwise feeding it around the drum with your fingers. This can be a VERY frustrating process. If you have the extra money I would probably advise just calling a tech out. You will probably be looking at around 200 for the repair. Maybe more depending on the service call and labor.
To avoid the smell when you get a new gasket leave the door cracked between uses. You can also just run an empty load with bleach in it on the highest temp cycle with an extra rinse. (Basically highest heat longest cycle) Once a month.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
There is mold around the rubber and in the inside of the rubber on my Front Load. How can I get rid of this? Is there a product to clean front load washers?
Hi.
The mold is an enzime from the washing detergent or softener. It attacks certain rubbers and causes them to turn black. Eventually it will cause a musty smell which will go on the clothes.
The only way to remove is by replacing the door seal.
If you try bleach etc then it will cause the mold to get worse.
Hope this helps
Aardvark Repairs
Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Musty odor removal; also "mold" black in color around rubber seal
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^*#
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have mold on the rubber door seal
This is a comon problem In areas where miosture is high and the tempiture is warm. Try using bleach to clen it off with or you can use super clean to remove it from the rubber. Not touchingthe seal with your hands and clothes will help some to.
Aug 31, 2009 | LG WM-2277HW Front Load Washer
Mold on gray rubber seal in Bosch washing machine
I use to sell bosch front loading washers for about 3 years, its a common problem on all front loading washers. Try a hot wash through the machine, if no joy then remove the seal and wash in hot soapy water. Make sure you replace the seal while its still hot from wasing if you take it off.
If still no joy, the call a service person and replace the seal. Its just one of those things.
Jun 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Washer door ring has mildew on it and is causing my clothes to smell moldy. What can be done to get rid of this? I've used bleach, and cleaners directly on the rubber ring, but with out success.
Unfortunately, when mold and mildew impregnate the rubber door boots on these models, it's nearly impossible to get it to go away. I would recommend replacing the door boot and follow these diligent preventive measures to keep the problem from coming back: 1. Check the area in and around the door boot after each wash for lost articles of clothing like underwear and socks. Also, clean out any lint or debris that collects under the boot. You might want to think about using a mesh garment bag for small items in the future. 2. Wipe the area periodically with a towel to get rid of the accumulation of soap deposits and dirt. This means wiping BEHIND the door boot where it meets the wash tub as well. I recommend waiting until you get ready to do a load of towels. Clean the area with a towel, then throw it directly in the wash. 3. Leave the door OPEN between washes to allow the door boot to air dry. Due to the nature of these door seals, they seal air tight and create an environment for mildew and mold to grow. 4. Run the washer with no load on the hottest cycle you have with nothing but bleach about once a week to keep bacteria to a minimum, and to flush the drain lines and pump. The door boot costs about $80 to replace, but it may be your only solution to getting rid of the smell and bacteria. Let me know if you decide to replace it. I can give you some pointers.
Jul 28, 2007 | Kenmore 44072 Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
