Question about Hoover Dryers
Hoover Condenser Dryer HNC375T making load screeching noise when in reverse
We thought this was the belt and have bought a new belt. However when we took the top panel off, the belt looks unworn. The dryer is only 2 years old but does get quite a lot of use. We can't figure out how to get to the motor. Does the back come off? How do we get to where we can replace the belt, or do you think it is a different problem?
  • 291 Answers
SOURCE: Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Posted on Oct 14, 2007
  • 213 Answers
SOURCE: ED55 dryer making screeching noises
sounds like the rear tub bearing has worn out that would explain the noise and if it got too bad the bearing can break causing the drum to stick and not be able to turn
Posted on Nov 26, 2007
  • 55 Answers
SOURCE: kenmore dryer making excessive noise
Likely the main drum bearing in the back. I have seen these go bad, and loud squeaky noise tells you. You can get a new main bearing and replace. It is in the center of the back of the drum, accessee through back panel of dryer usually.
Posted on Mar 10, 2008
SOURCE: I have a hoover Nextra
My nextra has just started to do same thing, does anyone know what is wrong
Posted on Jun 11, 2008
  • 318 Answers
SOURCE: Kenmore 70 series dryer making loud rattling noise, drying ok
it could be a worn motor bearing, but they usually last for 20 years, i would guess that you have a worn drum roller, the thing that holds up the drum and looks like a wheel.
if your sure the motor has a worn bearing then replacing the motor is not easy as you have to unscrew the blower wheel from the motor shaft.
it also may be that you are talking about the idler pulley being worn. it is the device that holds tension against the belt and they also will wear out and be "wobbly"
Posted on Dec 29, 2008
My question is related to the previous thread. However id like to reitterate the problem so that whoever stumbles upon this thread on google could help them immensely. I bought my mitsubishi montero sport...
There are two fans in a vehicle, One is in the engine compartment and is for the radiator. The other is in the passenger compartment and it runs the heater and air conditioner air flow from the plenum. The condenser is near the radiator and the evaporator is in the plenum. Condensers don't fail. Neither do evaporators. If the squeal is coming from the engine compartment when the air conditioner is turned on, the problem is either the belt to the COMPRESSOR or the CLUTCH on the compressor.
Jun 20, 2014 | Cars & Trucks
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Screeching noise and burn smell how do I open dryer to repair
Pull it out from the wall, unplug it and remove the back panel by removing the screws. The problem is most likely the belt around the drum which is either worn out or out of alignment. Take a look at it and decide if you can just straighten it on the drum or if you will need to buy a new belt.
May 01, 2009 | Dryers
Nextra7 condenser dryer making squeaky noises
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Feb 14, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Screeching Drum
My machine did exactly the same thing until the belt snapped - and it's a very painful noise!! I'm about to replace my belt and if this solves the problem I'll let you know.
Dec 15, 2008 | Candy CDC266 Dryer
Dryer makes screeching noise runs for awhile then shuts off.
The 1,5 year new dryer makes a terrible screaching noise when it has a load of clothes in it. It still dries fine, no problem with the heating element. No noise without clothes, only when it has a load.
Nov 23, 2008 | Dryers
Nov 26, 2007 | Fisher and Paykel DG05 Gas Dryer
Candy condenser dryer cdc 266
Forget purchasing anything, i had the same problem. Slide the lid back and spary the belt with WD40..... noise goes and works a treat and no money spent!
Sep 20, 2007 | Candy CDC266 Dryer
Dryers Logo
165 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
