Question about Whirlpool AWM029 Front Load Washer
Machine comes on intermittently
Basically the washing machine will run fine and then at some pont will decide to stop - ie the power light goes off. This occurs at no particular point. It sometimes can be re started by pushing the front panel or bagging the machine. It then continues on its merry old way. Sometimes stopping again and having to be banged etc. Thanks
  • 1 more comment
  • mikethecrow Nov 05, 2007
    washin goes through cycle but dont spin or drain water out ??
  • jeffinkona Jan 06, 2008
    I had this same problem and it ended up being the lid switch (part #3355806)
  • shelley aitkenhead Mar 16, 2008
    Have just inherited this machinein a house I have just moved - not sure what to do as would like to switch it on and know it will continue. Dont' want the expense of getting a new one or even someone to look at it. Help??
    New Friend:
  • 163 Answers
The intermitten defec is the most eassy or dificult defec becouse could be any were.. from the ac plug to the motor itself but try these... gentels nock to the timer... coulbe a carbon dirty contact in side the timer.. bend the ac cord and swing it around to look for broken cable... if some of these give you positeve result change it.... good luck
Posted on Jul 25, 2006
More than likely it is a faulty door interlock. Banging the door is causing it to work again for a while but it will haave to be replaced.
Posted on Jun 05, 2007
    President:
  • 1,294 Answers
Check to see if contacts are secure from plug in wall to wherever. Caution plug must be pulled out from wall socket before checking.
Posted on Apr 12, 2007
4 Suggested Answers
SOURCE: whirlpool calypso washing machine
Buy a new machine. We purchased ours from Sears 4 years ago, thank goodness we purchased the extended warranty, as Sears has been out numerous times to repair. In January 08, Sears replaced the pump only after they forced us to sign a waiver before they would even touch it, because my washing machine sits in a drain pan and they didn't install the drain pan. We signed the waiver (I need my washer) and the tech destroyed the drain pan and my my floor, basically she forced me to give her permission to do so. February 08 the extended warranty expired, June 08 the pump quit working again and Sears only warrantys part replacement for 90 days. BTW - the previous Whirlpool calypso model and Kenmore had a class action suit against them. Sounds like the newer models owners should do the same. Sears techs even told us to get rid of it. We bought a new one from Home Depot...
Posted on Jun 19, 2008
futureloginn
  • 734 Answers
SOURCE: Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Posted on Dec 10, 2008
    jsrock516
    • 5911 Answers
    SOURCE: washing machine starts, fills and then stops
    This problem is usually attributed to a lid switch malfunction. The lid switch is mounted under the washer top casing on the right hand side. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If the lid switch is broken, the following link explains the steps necessary to replace it:
    http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
    A replacement lid switch may be purchased on line at searspartsdirect.com. Just type in your model number and look under the "Top and Cabinet" heading for item number 11. The lid strike will be listed as item 20.
    If you do not wish to purchase parts on line, use the part numbers provided and go to your nearest appliance parts retailer. These are standard parts they should have in their inventory.
    If you have questions, or if you require additional assistance, please let me know. I hope this helps you.
    Posted on Jan 21, 2009
    Wife ran machine with water turned off and the power stopped, no lights at all, and will not come back on. I have tested and have power to the control panel. Is there a fuse or something that might be
    Heater element probably blown. This provides a resistance but goes open cicuit if not heating water as tem. goes up too high or the thermoststat has blown check both
    Nov 03, 2014 | Bosch Washing Machines
    Stops cycling intermittantly
    Any advisory lights on, e.g. bin full? Clean all sensors and make sure dump valve isn't letting water gradually drain out
    Apr 04, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
    I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
    Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
    Jun 05, 2011 | Fisher and Paykel (IWL12)
    Machine will not spin or drain water.
    I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
    Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
    Have kelvinator smart drive 503, water won't run
    I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
    Jun 16, 2009 | Fisher and Paykel GWL11 Top Load Washer
    Loss of power on LG WF-T652A
    I have the same problem as you. Machine was stopping intermittently in wash cycles - usually near spin/drain and sometimes just wouldn't turn on. Now it won't turn on at all...
    Jun 22, 2008 | Washing Machines
    Whirlpool AWM029 Front Load Washer Logo
    156 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
