Question about Craftsman Garden
Gas line routing on a craftsman weedwacker
I need a diagram for re installing a gas line on a craftsman weedwacker,
model. # 358.798441
  • 1 more comment
  • ufo4 Jan 28, 2009
    DON`T KNOW YET , IT`S TOO COLD TO WORK ON IT---ufo4
  • ufo4 Mar 25, 2009
    I,ve been so buisy that I haven`t tried it yet. I`ll let you know how it turns out when I try it.------UFO4
  • ufo4 May 26, 2009
    I FINALLY GAVE UP AND TRASHED THE CR
    AFTSMAN AND BOUGHT AN ECHO.THE GAS TANK WAS UNDERNEATH.------UFO4
hunter19_46m
  • 7482 Answers
SOURCE: 17" 32cc gas weed wacker
Hi pmbaugardne...
Please take time to rate me
Posted on Sep 19, 2011
rycgl
  • 1545 Answers
SOURCE: craftsman 21cc weedwacker, need fuel line diagram
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Aug 20, 2010
Testimonial: "this was very helpful and i thank you very much."
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
#1 Taper
  • 1040 Answers
SOURCE: need gas line routs for a craftsman weed eater
The longer, (and sometimes smaller of the two), fuel line goes from the carburetor to the tank with the fuel filter attached to the end, inside the gas tank.The other line, ( sometimes larger), goes from the primer bulb to just inside the gas tank, about a 1/2 -1 inch inside with coupling attached to the end. Coupling keeps line from pulling out of tank.
Jim
Posted on Jun 11, 2009
SOURCE: I have Craftsman 17" Weedwacker and need fuel lines
Hey jncsurf, I had to buy fuel lines last week. I called the local sears parts store, and gave them the model number. They had a rather generic bag with the correct diameter lines. Just cut to the approximate length.
But now I have a problem: I didn't note which lines went where when I pulled the lines off. Could you tell me where does the line from the primer bulb go: top or bottom barb on the carb? Thanx.
Posted on Jun 22, 2009
How to repair rope pull in craftsman weedwacker gas trimmer model No. 316.791940"?"
If you go to searspartsdirect.com an enter the model number for your weedwacker if will show you a diagram of how to remove the rope pull. Hope this helps.
Sep 26, 2016 | Craftsman Garden
Craftsman weedwacker model 316711970
If you go to searsparts.com and put in your model number it will show you a drawing of your weed wacker. Not sure of what you are looking for. Hope this helps.
Jul 09, 2015 | Craftsman 29cc 4Cycle Straight Shaft...
Craftsman owner manuals
If you go to searspartsdirect.com and put the model number in it will show you a diagram and on the page is a offering for the owners manual.
Jun 26, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
Craftsman 25 cc Weedwacker
Look for air leaks in the gas line and around the carb , a bad gas cap will not let any pressure build up. It could be that too. Check also the fuel line and filter inside the tank. replace if needed.
www.ereplacementparts.com has parts for craftsman or the online Sears Stores.
Nov 01, 2017 | Craftsman Garden
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
The fuel line in the tank connects to the nipple. It then goes into the small hole in the tank and then the fuel line from the carb connects to the nipple. This line is the line that is attached to the body of the carb, not near the plate.
Jan 18, 2012 | Homelite Consumer Products 4.0 Amp, 13 In....
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Jan 18, 2012 | Garden
How do I upload the manual? I want to see how to load the line
Hi and welcome to FixYa, I am Kelly.
Craftsman manuals are avalable for all models on this site:
http://www.managemylife.com/mmh/owner_manuals
You must have your model number
Note the model numbers on this page:
http://www.managemylife.com/mmh/owner_manuals/search/product_type.Line%20Trimmers:Weedwackers,%20Gas?query=27cc+Craftsman+trimmer
Once you enter your model number you click on "Get Manual" and then save as to your computer.
Thanks for choosing FixYa,
Kelly
Aug 07, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
1,885 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
