Sanyo dvr v100e has various problems.Formats disc records but willnot play back recording on some of the discs
I had the exact same problem and fixed it easily, if you would like me to instruct you on how to repair the unit just email me on- todd1981@hotmail.co.uk
I will not go into detail now because you asked this question a year ago and maybe you no longer have the DVD player or the problem.
Cheers, Paul
Posted on Jul 20, 2009
Cant get pre-recorded disc's to play in my recorder it comes up with the message "this disc will neither play or record" any ideas?
hello,
the reason the recorder comes up with the message "this disc wont play or record" simply is that the format of the disc is not compatible with the player.
1. check the format of the recorded disc,
2. and check the formats the recorder can play to confirm this.
take care
Jun 03, 2010 | Sony RDR-VX420 DVD Recorder/VCR
Sanyo DVR-V100E DVD recorder +VCR - will this model record any terrestial digital channels?
It does NOT have a built in freeview tuner. You would have to connect a Freeview box to one of the scart sockets and set it to record from the AV channel the box is connected to.
Oct 06, 2009 | Sanyo Televison & Video
Can't record anything....dvr won't recognize blank
Not sure, but could be as simple as switching to a dvd-rw disc. Not all recorders recognize all formats.
Mar 16, 2009 | Televison & Video
Where can i get dvd discs for my sanyo dvr v100e
You can get them just not in stores they typically only carry the latest and greatest.
I have done some searching and found a few resources to get them fairly cheap as well.
http://search.ebay.com/blank-dvd-2x_W0QQfkrZ1QQfnuZ1QQfsooZ2QQfsopZ32QQkeywordZblankQ20dvdQ202x
http://www.onlinesupplystore.com/Product.asp?id=71801&ADTR=7
Hope this helps, thank you for stopping by Fixya! Please leave a positive rating if this solution has helped.
Mar 16, 2009 | Sanyo DVR-120
Sanyo dvd v100e will not record onto dvd
As in most dvd or cd players for that matter, there is a switch that is made when a dvd or cd is present. After the disc is loaded and the door closes, it makes this little switch inside the player/recorder. Another cause of this problem is that the lens that actually reads the disc is just gotten to the point that it is too dusty to read and therefore it say there is no disc. To solve that problem I take the cover off (just a few screws readily seen), and I first blow out the dvd player with a can of clean compressed air with a small straw attached. There will be sufficient dust in there after three years to notice once the compressed air hits it. After the dust settles, you can see the little laser lens in the carrier where you put the disc, clean it with a q-tip dipped in isopropyl alcohol, then turn the q-tip around and dry the excess off the lens. With the cover off load the disc and make sure as well that it starts to turn. The dirty lens would have kept it from starting to turn as well since it could not see the disc there to begin with. This should get it to work. Good luck and God bless.
Jan 09, 2009 | Televison & Video
Cyberhome DVR 1600 DVD
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
Dvd player will not play back after recording , says unknown data or empty disc
The dvd player is not actually recording to the disc. It first records to a "hard drive" on the DVR. when the recording is complete, the user must request that the DVR downloads the recording to the disc. Since I do not know your brand and model # I cannot really instruct you further.
Ch
Jul 29, 2008 | Televison & Video
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
Cyberhome 1200
I have a cyberhome 1600 dvd recorder and I need a code to program it to my bell remote but can not find any codes for the cybehome. can someone help with the codes
Nov 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
229 people viewed this question
Top Televison & Video Experts
Electro Med Services...
