Question about Kenmore 63012 Electric Dryer
Kenmore Elite Heavy duty 63012102, spins no heat
How do I get to heating element to see if that is the problem? Is the element easy to replace if this is the problem. Checked breakers did not solve the issue. What else could it be and would it be advisable to get a tech here instead of doing it ourself?
    Genius:
  • 1,122 Answers
No,you can do this yourself,remove the back panel,you will see the heater box,at the top you have the heater box fuse,next one down is the thermostat,and under that is the 2 terminal that go to the hearter,if you have a omhs meter you can check everything out,it might only be the fuse at the top of the heater box whick cost $2.00 at your local appliance parts store,please let me know how you make out and if i can help somemore-mike
Posted on Oct 21, 2008
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
No heat
I can be several things, but most common is a burned out heating element. This can be tested with an Ohm meter.
Mar 15, 2014 | Kenmore Dryers
I have a series 90 heavy duty electric Kenmore dryer. I think the heating element has gone out. Is this an easy fix. Dryer still works just doesnt get hot to dry clothes.
If The front panel is one assembly then the element is on the back behind the cover, if there is a small panel on the bottom ending about where the door starts the element is behind that panel on the right hand side. In either case it if fairly easy to get to. Also check the two thermostats on the heating element. Both should have continuity. If either one is open replace them both.
Jan 31, 2011 | Kenmore 62802 Electric Dryer
I have an electric Kenmore Heavy Duty Plus dryer that runs fine just blowing cold air.
It sounds like your dryer's heating element has gone bad. They are somewhat easy to replace if you are somewhat handy. You may have problems finding one but most can be found at an appliance or hardware store. Good luck.
Jan 20, 2011 | Dryers
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Mar 17, 2009 | Kenmore Dryers
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer shuts off
If the venting is clogged this will happen. And that is a good thing because it is a safety measure built in to prevent fires. There is a thermostat that can tell when your dryer is over-heating,(usually caused by clogged venting by lint) and this devise tells the heating element to turn off so as not to create a fire. Clean out venting, inspect thermostats and element, replace if neccesary. You may only have to clean out the venting.
Nov 27, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 63012 Electric Dryer Logo
121 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
