Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Hover windtunnel It will start when you plug it in and wont turn off with the switch you have to plug it in and unplug it to get it to work.
  • 2 more comments
  • Anonymous Nov 03, 2008
    It will start when you plug it in and wont turn off with the switch. You have to unplug it to shutoff.
  • Anonymous Dec 24, 2008
    PLUS now my switch won't work at all. arg.......
  • Anonymous Jan 09, 2009
    MY BELT ON THE WINDTUNNEL ULTRA KEEPS COMMING
    OFF. AND IT IS VERY HARD TO REPLACE. I'M NOT STRONG
    ENOUGH TO PULL IT ON THE BIGGER ROLLER SO I HAVE
    TO CALL ON MY NEIGHBOR. IS THERE AN EASIER WAY?
  • Anonymous Mar 31, 2014
    on/off switch not working.plugging it in and unplugging it is how i turned it on and off. now that no longer works. it does not turn on when plugged in anymore.
I had the same problem with the Hover windtunnel. All I had to do was remove the two screws holding on the handle and then pull the handle off pulling horizontal to the ground. Then I manually turned to swith off. Check it to make sure the switch was working and then put the handle pack on with the swith in the off position and all worked ok.
Posted on Dec 11, 2008
  • 148 Answers
Replace the switch.
Posted on Nov 11, 2008
I have a hoover windtunnel upright vacuum, It will not shut off and I have to unplug it to do so. If I take apart the upper handle and manually flip the internal switch it works just fine, only when using...
This is a common problem with this machine. The switch has too much resistance to be turned on and off with the switch button and rod. If you put in a new switch, ( # 28161075 ), your problem should be fixed.
Mar 23, 2011 | Vacuums
Windtunnel bagless vaccum model uh6000 on/off switch no longer working, must plug/unplug unit to use. Can switch be replaced?
Yes they can be replaced and are relatively easy to fit. In my opinion, Hoover are one of the best vacuum manufacturers when it comes to obtaining spares and you should have no problem getting one. I did a (very quick) search and this switch apparently fits all Windtunnel Hoovers:
http://www.sweeper-city.com/howiswkit.html
If this doesn't look like your switch, I suggest calling the supplier to verify which part you need for your model. If you'd rather get one fitted for you, any competent appliance enginner or an authorised Hoover service centre should be able to obtain and fit the part easily. I wouldn't pay more than $20-25 in total as they take about 5-10 minutes to fit, max.
Nov 04, 2010 | Hoover Vacuums
My hover windtnnel self propelled vacuum wont pull itself ,why
your self propelled vac has its own belt,or have your transmission checked.
Oct 19, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Wont shut Off
its the power switch, hoover has had that problem for years. I'd take it to a vac repair shop, sometimes the wires that connect to the switch get burnt as well and should be replaced.
Sep 16, 2009 | Hoover U6630-900 WindTunnel Bagless...
I have a Hoover Windtunnel model U5462. Plugged in, turned on, it popped and then no power at all. Not circuit breaker in house. Does the unit have a fuse or something similar?
does it have a headlight and does it work? if so then unplug the vacuum and turn the brushroller by hand a few times.then plug it back in,if it works then your motor might be bad.you can try to spray a little wd40 into the switch then.work the switch back and forth a few times first to get the lubricant worked in to the switch .try to turn it on now.see if you have any cuts in the cord.also see if the cord is pulled out of the vacuum .if so you might have a wire unplugged inside the base of the vacuum
Apr 23, 2009 | Vacuums
Hoover dual windtunnel model U8149-900 series Y 12.0
this model has 4 brushes to replace. they are connected by gears
they have a bad habit of stripping so get all 4
after you pull off the bottom plate there will be retainers on the outside ends
Nov 30, 2008 | Vacuums
Hover mach 4 vaccum
usually caused from being plugged, so first find the plug and clear it. The motor has an automatic reset, should restart after about 30 minutes, if it continues to shut off, there is still a plug.
Dec 12, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
127 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
