Question about Kitchen Appliances - Others
Mastercraft Wet Sharpener; Model No 55-3504-4
How can I access an instruction manual for a Mastercraft Wet Sharpener; Model No 55-3504-4.
The Motor Type is 120V AC
The Speed is 170 RPM (no load)
Thanks Lou.
  • ldtjwil Nov 18, 2008
    looking for a manual, or instructions on changing the grinding wheel
I just purchased one of these machines - also without the manual (seems to be a recurring problem with Mastercraft).
I phoned Mastercraft's toll-free number (1-800-689-9928) and they apologized and said they'd mail me a manual.
Have the model # handy, and be prepared to stay on hold for awhile (took me almost 30min the 1st try, maybe 10min the 2nd).
Hope this helps.
Posted on Nov 25, 2008
  • Tyler P
    Tyler P Nov 15, 2014
    Go to www.kingcanada.com the same sharpener is there under KC-4500S Manual and parts list can be downloaded
I too, was looking for an owner's/instruction manual. I called the 1-800 number and went right through. The girl was very helpful and said she would have it emailed to me ASAP.
Posted on Aug 30, 2012
Misplaced my power supply for my 1950x pencil sharpener and can`t find the output or polarity labeled on the thing?
I have the same sharpener. Input is 120v AC 60Hz 16W which is what comes out of the wall in USA.
Output is 12V 800mA and the polarity is positive in the inside of the plug. I'll try to attach a photo to this post.
misplaced-power-supply-1950x-pencil#solution-section-kjptrdwcwv032w1lziamb525-3-0.jpg
Mar 02, 2014 | Boston Acoustics Mighty Mite Electric...
Someone cut the plug from a 230V Craftsman Compressor and wired on a 120V plug and plugged it in. What type of damage could have occured?
You should be okay. It just ran at half speed while it was on. If had been the other way around (hooking up 120v motor to 240v socket) that would have killed the motor.
Jan 30, 2013 | Pool & Spa
My jet wet sharpener runs backwards after the switch was replaced
Remove the switch and swap the wires on the terminals, whoever hooked them up crossed them.
May 08, 2010 | Jet 708015PK Jssg 10 Slow Speed Wet...
I have a Maytag Neptune TL. The machine is working normally except it's not able to fully extract the water out of the clothes. When the full cycle is complete the clothes are still dripping wet. I have a...
We are talking about FAV6800A or FAV9800A TL correct?
If so you need these links the Service Manual and parts look up; here is the Service Manual for reference. Sears Parts Direct for reference.
If your machine completes the wash cycle with no error code such as ND (No Drain) and there is no visible water in the bottom of the wash basket when you remove your wash load then I would do this test.
Take the next wet wash load that is dripping wet and lets do a Quick Spin Test in Service Mode. During this test test the FAV6800A LED display model will step thru the RPM (revolutions per minute) or goal is to ensure the machine will spin the wash basket up through all Spin Cycle RPM ranges. Any RPM range above 99RPM’s will be shown with a (.) dot after the two numbers displayed i.e. 350RPM will show as 35. 550RPM will shoe 55. And so on.
I’m and owner of the FAV6800A and I’m not sure what the LCD display of the FAV9800A will display.
Enter into Service Mode;
Page 14 of the Service Manual; below I have cut and paste the instructions.
Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the control beeps.
Now go to page 14 and enter this front panel key pad press to start a Quick Spin Test and see if the machine with that wet clothes load will spin the wash basket to 850RPM.
Quick Spin Test
While in Service Mode, press the Hand Wash
key to start a Quick Spin Test.
Quick Spin test steps are as follows:
1) Lock the lid.
2) Spin to index speed 90 rpm and hold for 60
seconds. Pump drains machine.
3) Spin to index speed 150 rpm and hold for 6
seconds.
4) Spin to index speed 350 rpm and hold for 6 seconds.
5) Spin to index speed 550 rpm and hold for 6 seconds.
6) Spin to index speed 700 rpm and hold for 6 seconds.
7) Spin to index speed 850 rpm and hold for 6 seconds.
Pump out.
8) Coast down to 0 rpm chimes 3 times.
Hit the Off button to get out of service mode.
If the machine spins the wash basket to 850 RPM then we need to start looking further. What are your results?
You can check the flow rate of the drain system by again entering Service Mode and turn the Drain Pump on in service mode. I would (hand fill) place 5 gallons of water in the machine and turn on the drain pump see page 16 for Board Output Test.
Enter Service Mode and press the Delicates key. You are now in Board Output Test now press the Presoak key and the Drain Pump will turn on. If your machine pumps out the 5 gallons of water in 60 seconds or less I would say your Sump Cap, drain line connection from Sump Cap to input to the Drain Pump, Drain Pump and discharge line are all working as designed. If the Machine takes greater then 60 seconds to dump the water then you need to start troubleshooting for a drain line restriction or Drain Pump issue…...Rich
Apr 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Chainsaw lubrication
Use regular bar oil available almost everywhere, not motor oil.
Jun 30, 2009 | Electric Chainsaw Sharpener
Black & Decker model 4300 manual
Here's a link to a downloadable .pdf manual for your sharpener that will give you pages and pages of instructions to make those dull bits history.
Enjoy!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 14, 2009 | Drills
Kitchen Appliances - Others Logo
2,030 people viewed this question
Top Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
