Panasonic CT-26WX15 26" TV Logo
Neil Lazarow Posted on Jul 25, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Intermittent blue circle on display
I have a Panasonic CT-26WX15 set, and sometimes there is a circular area of the screen with a heavy blue tint. It does not seem to show up on all channels, and is not there when playing DVDs. Any ideas?
Anonymous
Level 3:
President:
  • Master 3,130 Answers
  • Posted on Jul 25, 2006
Anonymous
Master
Level 3:
President:
Answers
3130
Questions
5
Helped
1649716
Points
8439
Yes this is certaintly a strange one, as you say not all channels have it?? Ok lets try to narrow it down a bit. Do you have cable or satallite ? Is the cable or sat. connectected through the video inputs or does your TV have to be on a certain channel? ok and you say its not there when your watching a dvd? The only answer here is that you have a problem with your cable or the sat system, as the channel stays the same on whatever channel your watching while on the cable, so if you have a problem with some and not others , Your TV dosent know the differance from one channel or another, as its always on the same channel on the tv . So what does this tell you?? Theres a problem with the sat or cable reciver! Cant be the TV as I said the TV doent know the differance from one channel to another as it always stays on the same channel. Sounds like you need toi have cable come in to check the impedence and signal streinth.. now if your sying thast the tvs on locals and some do it and others dont ?? then theres outside interference causeing this problem? Good luck
LED TV has a a blue tint, would could be the issue?
Either the source or the input devices have not been set up correctly with your TV.
My Hitachi 65F59A has a blue tint picture all the time? How do I Resolve this? Thank you
you would need to use your display settings to change the tint. There might be a tint or a hue option that you can press with the display settings. Thank you.
1helpful
Panasonic DVD-S35S is playing DVD's heavy green tint on Panasonic Plasma HDTV TC-P50S30
The DVD should be checked on a different set to make sure that it is the problem.
Television will not turn on when switch is activated
Disconnect power cord from the outlet. Remove back cover and replace fuse 6.5A 125V.
5helpful
My Panasonic HDTV will not turn on
Mine did the same thing. Did you find out what to do?
1helpful
Normal screen is white background, but lately I am getting a blue tint that clears up sometimes and sometimes not. Please advise
Try hooking up another knowng working monitor to the computer and see if the blue tint comes back intermittently.
If it still comes up then you know your video card is the culprit. If the blue tint goes away then you know the original monitor is bad.
Line across middle of screen.
The line of color is due to a failure in the vertical circuit. The main suspects are the vertical Ic AN15525A and/or capacitor c308 220uf@35volts
If you have the capacity to do so, you should check the other electrolytic capacitors in the vertical circuit which are USUALLY located near the vertical IC in most cases
you can purchase the part at
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5760279&smodel=CT32SL15N
or mcm electronics
I used your advice today about replacing the fuse Thank you!
Gonna need a little more info than that - - - I get nearly 3000 emails a day and I'm not sure what page we're on...
Bill
Color problem
Replace D805 (?) Thermistor for permanent fix, manually
degauss with coil is temporary........T.
Dark area on screen
If it's a circular area you might be delaing with magnetism. Check the menu and there should be a control for geomagnetic correction and adjust accordingly.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
