Question about Dishwashers
My ariston LSI 61 water pump is on all the time and the left hand program on top of the door is flashing
  • Anonymous May 12, 2009
    same as above, anyon know what to do?
I had the same problem and sure enough there was water in the bottom of the machine. I mopped this out and ran the machine again and saw that water was dripping down. This was cured by tightening the nut that secures the lower spray arm in place to the inner floor of the machine. It had come a little loose and a quick tighten solved the problem
Posted on Dec 20, 2014
    New Friend:
The tray under the machine is filled with water and needs to be emptied
Posted on Jan 03, 2009
  • marina
    marina Jan 21, 2014
    e dove si trova il vassio sotto la macchina per poterlo svuotare come faccio?
Hi, I have an Ariston LL64 model dishwasher that doesn't complete a wash cycle. It gets so far and stops with the "crystal care" light flashing. Any ideas? thanks Barry
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If not the pump must be checked for clogging.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Aug 03, 2011 | Ariston Technologies LL64WNA Built-in...
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 | Dishwashers
LITE FLASHES 4 TIMES
4 flashes indicates a blocked pump. this can be sorted without taking the dishwasher out.
first remove the kick board,
take off the wooden door.... just loosen all the screws on both sides and door should slide down and off, this gives you more room to work.
remove the bottom panel of dishwasher....4 hex head screws
you will then see the pump in front of you, left hand side
empty the dishwasher with a cup....get as much water out as possible
twist the pump clockwise and it will come off, remove blockage and put back together again.
look out for the tab on the pump you have to push down in order to twist off.
hope this helps.
Feb 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
My dishwasher doesnt start
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
Apr 22, 2009 | Ariston Technologies LL64WNA Built-in...
Ariston dishwasher
i have a brand new ariston ll-64 and the wash cycle won't start and two flashing lights
Feb 09, 2009 | Ariston Technologies L63 Free-Standing...
Tecnik DW2677
check your water intake- i had the same issue - a leaky fitting wasn't supplying enough water to the dishwasher. had exactly the same symptoms you describe. fixed the leak, reset the dishwasher & it's working fine.
Oct 29, 2007 | Tecnik TDW2677 Built-in Dishwasher
Ariston LL64 doesn't start
4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position).
Jun 23, 2007 | Ariston Technologies LL64WNA Built-in...
Dishwashers Logo
715 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
