Question about Kenwood KDC-7009
Face plate wont move
When I press the eject button to slide open the face plate,showing the CD (insertion) slot nothing happens
  • bgexpress Jun 26, 2008
    I touched something and the face locked up.I just both the car with this receiver and don't have any remote.How I can open the face?
    President:
  • 3,130 Answers
First check the power fuse as well as the stanby or always on fuse. then if that does not work Try to disconnect the power and standby line and let the unit reset . This should be done for at least an hour or so.. Good Luck
Posted on Jul 25, 2006
My CD is stuck in my Toshiba Satellite A505D laptop slot, with no hole near the Eject button.
Look on the cover on the tray near the eject button. Should be a tiny hole.
Get something like a straightened out paperclip and insert it in to the hole and push firmly but carefuly. It's an emergency eject for a stuck tray.
Feb 07, 2012 | Computers & Internet
I can not get the cd to eject. When hitting eject it acts as a pause or play button. This Valor cd player is installed in my SUV. Thank You
If you can power on the unit, and press the eject button still, then this how-to should work for most standard in-dash units. (There is also a tiny black button behind most face-plates on aftermarket stereos that you can press with the end of an opened-out paper clip, should your eject button not work.)
Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '0206790666+7733764704+1640266093+5860073694+9503394424+9665908481+3607312525+8962074949+8941458308+0371618899+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; if(fromsearch) document.write(''); else{ document.write(''); } //-->
Steps
Method 1
  1. Take a blank/useless CD (such as AOL free trial CD's, you can get them in a plethora of amounts in Best Buy) and place it about 1 inch deep into the slot.
  2. Press the 'Eject' button and gently wiggle the CD around. If this doesn't work, repeat and try to get the blank CD below the the jammed CD, and gently pry the target CD upwards.
  3. Sometimes, unusual amounts of pressure may be on the unit, behind the dash itself. Have a professional or a friend that you trust remove the dash unit and try steps #2 and #3.
Method 2
  1. Get a 1 inch to 2 inch wide putty knife and wrap tape around it with the sticky side of the tape on the outside of the knife. Use a strong tape like Gorilla tape for best results. The knife is typically tappered so that if you wrap the tape tight enough it will not slide off the end
  2. Get a piece of paper and stick it to one side of the knife. Trim with scissors. You now have a thin sticky knife you can slide into the CD player opening.
  3. Insert knife into CD player with sticky side down trying to get it to go on top of the CD that is stuck. Press down gently to get the tape to stick to the CD.
  4. Gently lift up and pull the knife out. Hopefully the CD will come with it. You might try hitting the eject button if it doesn't work the first time...
Method 3
  1. With the heel of your hand, slam it into the front of the CD player.
Method 4
  1. This method worked only after I pressed the eject button which resulted in the CD not ejecting at all or only becoming visible a very little bit - too little to grab with fingers or pliers.
  2. Get a stiff plastic "card" - like a drivers license but a bit thinner. Put double-sided scotch tape on one side of the card, near the edge of one of the two narrow ends of the card.
  3. Get a thin-stemmed flat head screwdriver (short is better).
  4. With the sticky side of the card facing down, stick it into the **** ABOVE the stuck CD. You may have to use the screwdriver to ensure the card goes in above the CD and does not stick to the CD until after you get 1/2 to 3/4 inch of the card in above the CD.
  5. With the card still in there, insert the thin flat screwdriver ON TOP of the card and gently press down on the card. This causes the tape on the bottom side of the card to stick to the top side of the stuck CD.
  6. Remove the screwdriver and then slowly pull the card out. The CD should come with the card.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/joseph_f4ed739f62995525
Mar 08, 2011 | Valor DV-169
I've a DELLXPS M1530. I'm trying to eject a CD, wont come out
I do believe that there is still a small hole by that slot, that you can insert a straightened paper Clip into, and keep pushing until you feel/hear a slight, click, keep pushing gently and the disk should soon appear. IF you cannot do that the DVD will be removable by taking out the fasteners underneath the laptop,, and sliding the DVD out. for repair of replacement.
Mar 04, 2010 | Dell XPS M1530 Laptop
Just installed an XDM7615 Dual stereo and the face plate won't detach. Can anyone help? The manual says there is a button behind the face when it's in the 'eject' position but pushing this button does...
There are 2 very small screws on the back of the face plate that need to be removed. Once these are removed, you may then remove the face plate.
Feb 10, 2010 | Car Audio & Video
I got a Alpine cda-9851 cd player today. I popped the face plate off to see where the cd goes in, but theres not a slot for it! Do i have to have a 6 disk changer for it?
this is a motorized deck. just press the eject button and it should open. the eject button should be on the lower right hand corner of the face.
Dec 10, 2009 | Alpine CDA-9851 CD Player
My disc drive won't eject.
If there is CD/DVD stuck inside:look for a small hole on the face of the drive and insert a paper clip, and press a bit, the drive will open.
If that does not do the trick, look for an icon on the systray (where the clock is shown) . It represents a square inside which there is disk.The tooltip (bubble) should read Optical Drive Power (on or off). If you click on it it shows a two item menu Power On Power Off with a tick mark near one of them. Click Power ON.
Hope it helps.
Sep 07, 2009 | Gateway Computers & Internet
I dont ehere the cd goes
Press the eject button (lower right corner) and the face plate will drop down, showing a cd slot.
May 31, 2009 | Alpine CDM-7861 CD Player
Face plate won't open far enough to insert a CD
try to hit slowly the faceplate in the left side until its open
Mar 08, 2008 | Pioneer DEH-P80MP CD Player
Car cd changer
yes. open it up and find the small motor that performs the eject process. Then turn it by hand to eject the magazine.
Jun 13, 2007 | Kenwood KAC-729S Car Audio Amplifier
Flip Down faceplate is stuck.
I have the same problem, and all my problem was is that one of the wheels were out of place. You can see these white gears at the bottom left and right. Just stick something in there and push it back in place. It should just snap back in.
Mar 16, 2007 | Dual XD-7500 CD Player
Car Audio & Video Logo
146 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
