Question about Sony Handycam DCR-TRV280 Digital Camcorder
"reinsert tape" message
Every time I insert the tape, the screen says "Reinsert the tape" as an error message. It is loading the tape fine, but when the camcorder is turned on, it just flashes that message. We'd appreciate any help you can give. Thanks, Ken
  • 6 more comments
  • jj-me Mar 12, 2008
    i have the same problem same camcorder help i was rewinding a tape and then i pressed play and it said reinsert the tape and i did and it said reionsert the tape again and again heellpp
  • Anonymous Mar 14, 2008
    same
  • faisal khan Apr 12, 2008
    same problem
  • Anonymous Apr 15, 2008
    it gives a message of reinsert tape
  • Anonymous Mar 29, 2009
    Same problem. I've done a google search and a LOT of us with Sony recorders have the same problems. Different users, different models, but same problems, and simular error code displayed.
    The smack it has often worked. But that is more like curing a symptom, and not the cause. But hey, as long as it works I suppose.
  • K8tt Apr 03, 2009
    Can't believe it. Same "reinsert cassette" message. I whacked the camcorder on it's side a couple times and now it works.
  • hamid_parsi Apr 05, 2009
    Every time I insert the tape, the screen says "Reinsert the cassette"
  • Laurarose May 20, 2009
    the whack is clearly NOT working for me... HELP! any other suggestions!?
I can't believe it. I tried hitting the camcorder on the battery side, directly on the battery with the palm of my hand and it worked for about 5 seconds. THEN I hit it against a wood table on the battery side and it is now working. I guess my first hit with the palm was not hard enough.
Posted on May 15, 2009
Yes I have the same problem with mine it happened a few days ago, I'm pretty sure it's moisture condensation, but when this happend to me before, it came back within hours. This time it didn't. So I think I might take it to a shop to get it repaired because it's still under warranty
Posted on Aug 17, 2006
I thought it was crazy too, but I fixed the problem by hitting the battery side of the camcorder with the palm of my hand. I'm going to by a new camera as soon as I can dump all my tapes from this one, but heah... at least it's working again.
Word.
Posted on Jun 01, 2008
I have had the same problem. Every time I turn the camera, it immediately beeps and displays Reinsert The Tape. I searched the Internet and found that everyone who has had this problem solved it by hitting the battery side of the camcorder with the palm of your hand. I thought this was crazy. But it's not. It worked for me. I had to smack it twice and I turned it back on and it's working!!!!
Posted on May 23, 2008
I have a sony dig 8 trv340 and am receiving an error code of c31:42 what does this mean?
In DCRTRV430 Camcorder, the C:31:42 error message is a Self diagnostic display. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camcorder. In C:31:42, the issue is with the tape and the tape mechanism.
I suggest that you remove and reinsert the tape to check if it helps. You may also try inserting new tapes in the Camcorder. Please remove the battery and/or power cable, connect, and perform operations from the beginning. You may also try resetting the Camcorder back to factory default after removing the tape.
To Reset the Camcorder, perform the steps below:
? Please open the LCD screen to locate the RESET button.
? To reset the Camcorder, press the RESET button using a sharp-pointed object.
? Please make sure that the Camcorder is turned on while pressing the reset button.
Also, try turning off the Camcorder and remove the battery pack. Then move the 'Power Switch' of the Camcorder to the ON position
for 1 minute. After about 1 minute, move the 'Power Switch' to the OFF position.
Now reinsert the battery, turn on the Camcorder and check whether it is working fine.
Thanks.
KenSolutions
FixYa
Oct 23, 2010 | Sony Video Cameras
Reinsert cassette - After inserting a cassette the on screen message reads as follows "reinsert cassette" a further message C:31:23
when ever to get this kind of message just try to fwd the tape mannualy, or just make sure tht when u are rew. the tape dont rewind tht completely....
Jan 04, 2010 | Sony DCR-TRV285E Digital-8 Digital...
make sure the camera internal battery is charged. using the ac charger plug the camera in for 24 hours. if the internal battery is dead then you will need to turn it in and have it replaced. that is why is says reinsert the tape
Apr 05, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
HDR-HC1 Sony camcorder- reinsert the cassette error message
Bill,
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
Mar 07, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
The screen that says reinsert the cassette.
Tht means the recording protector tab of the tape is on, check the tape, most or f the time there will be a plastic piece tht can be broken off if u need to prevent any thing from recording on it, try covering the hole with a piece of adhesive tape and try recording
Nov 04, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony Handycam Digital 8: won't accept tape
I was having the exact same problem with my sony handycam. I actually came across this website looking for the answer and noticed many people having the same problem but there was no solution to it.
I just happened to go to the sony website and decided to watch the tutorial on setting the camera back to the factory settings. It actually fixed the problem! I don't know if this will work for everyone or even how long it will work, but I figured it was worth a try. Good luck!
Cassette loading error 31:23
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Nov 18, 2007 | Sony Handycam DCR-HC96 Mini DV Digital...
Reinsert tape message
I got the dreaded reinsert tape message today and i thouht that my video taping days were over. i then made my way to this page and saw this. whack it three or four times and it will work. at first i thought what a load of crap but i tried it anyways... being really mad at the time, i showed my camera no mercy. i took out the tape and gave it 4 hard hits with my palm, put the tape back in and it worked. thanks alot, this works
i
Aug 11, 2007 | Sony CCD-TRV138 Camcorder
Reinsert cassette error... cannot record via tape
What error message is it giving to you ?? as this will be a good indication of fault.You have tried all the usual things to try by the sounds of things,
May 14, 2007 | Sony Handycam DCR-HC46 Mini DV Digital...
Sony Handycam DCR-TRV280 Digital Camcorder Logo
526 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
