Question about Studio Projects C1 Professional Microphone
C1 Microphone noises
Lately, as I try to record with my C1, there are sudden noises, rustlings, then the sound may disappear completely, then come back with more unexpected noises - I have checked the cord, and tried my old microphone which works fine, so it must be the C1 - What to do?
  • Anonymous May 21, 2009
    Pretty much the same, noises, and output goes way down. I wonder if SP can fix it for less than the cost of a new one ($200.00)...
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi mikat296
    You say you checked your other microphone, was it a condensor also?
    regards
    robotek
    Problem Solver:
  • 13 Answers
This is a common problem with less expensive condenser mics, due to contamination on the circuit board or capsule there can be some leakage current which makes noises and can cut off the sound entirely. SP should be able to fix this for you for not much money.
Posted on Nov 30, 2008
C1 not working
Sounds like your Phantom power supply may be defective. To be safe, 1st try moving AC plug for Phantom supply to another outlet as sometimes "sharing grounds" can be a problem. If this doesn't help, try using another phantom power source ...many PA mixers have built-in phantom power. If the buzz disappears with a new one, it will be a filtering issue (capacitors) with the old phantom supply.
Apr 19, 2014 | Behringer C-1 Microphone
I Purchased behringer c1 u microphone and I want to record my singing with karoke..Problem is that when I connect laptop with speakers my singing volume is coming louder but sound of background music is...
You need a mixer. Connect the microphone to the mixer and also the background music. That way you have separate control of volume for the voice and the music.
The background noise can come from different sources. One of them is from the laptop itself, if the laptop is noisy to begin with.
Mar 14, 2014 | Behringer C1U Microphone
Sound noise feedback during recording
Noise can be a big problem when trying to record into a computer. Reducing and canceling out noise using several simple techniques will help increase recording quality and increase your satisfaction with recordings. Solutions range from complete room overhauls to simple changes in the placement of the microphone and other objects in the recording.
Use a stabilized microphone to reduce vibrations. Many hand-held or headset microphones will pick up on vibrations and movements from the user. These vibrations can carry over into the recording and reduce the quality of the recording. Using a microphone stand or stationary microphone will reduce noise while recording. Mic stands will help increase recording quality and off a possible solution that requires very little financial investment. Set up a designated sound room that is set away from the rest of your home. The farther the recording area is from windows and doorways, the better. Windows allow very small amounts of noise to filter in from the outdoors and create white noise in the recording. Hang blankets on the walls around the recording station and use many rough objects in the recording room. Sound travels in waves that bounce back and forth between smooth objects. Blankets and other rough objects will help reduce sound vibrations. These additions to the recording room will reduce ambient sounds from both the room and outside the building by blocking sound waves from bouncing back and forth in the room. If you can make a considerable investment in the room, there are several acoustic products on the market than help nearly eliminate echoes and outside noises. Install software that filters out unwanted sounds and echoes. Many computer applications exist that use programs to increase the quality of recordings and reduce the ambient noise levels in a recording room. Software is used to reduce echoes and feedback in a recording studio. Several free applications can be used to achieve the desired effects when recording. A program called Audacity is one of the most effective software packages that can help reduce noise in recordings. http://audacity.sourceforge.net/ Software can also be used to reduce electronic humming and other white noise that can be picked up during a recoding session. Buy a high-quality microphone with noise and echo cancellation. One of the best investments that a recording specialist can make is a high-quality mic. The microphone itself can reduce many unwanted noises and echoes in the recording room by filtering the actual sounds that are recorded.
b>
Jan 15, 2013 | Computers & Internet
Sound noise feeback during recording
b>
Jan 15, 2013 | Logitech Webcam
Sometimes my AKG Perception 420 won't record properly, when played back it sounds like white noise with the faintest sound of what i'm trying to record in the background
All microphones have a signal to noise ratio. Basically defined as the level of desired sound to background noise (unwanted sound). Microphone phones also have self noise which should be considered when choosing a mic. There will be noise in every mic, some more audible than others. Condenser microphones require phantom power (48V). This can be supplied by mic prea
mps, mixers, and similar equipment. *Note that phantom power (mic pre amps) must be on or engaged, this can be specific to different types of equipment.
Troubleshooting:Has your microphone been dropped or exposed to moisture? Internal damage to your microphone will be hard to assess but this could possibly be the issue. Inspect the microphone cable, check for damages. Try using a another microphone cable-- preferably a new one. Next to check would be your mic's power supply. Make sure all connections are made properly (mic to cable to power supply). If you are using a mixer or pre amp with multiple inputs, test the mic on each input. (You should test by making recordings and comparing with each change to isolate possible causes). Also test the mixer or pre amp by slowly sweeping the input gain feature while recording an audible source such as singing into the microphone. Typically next in the audio recording chain would be your DAW (digital audio workstation) or computer, but problems with noise most likely precede this.
I could possibly provide more useful information if I know your exact setup.
Provided that you have your equipment setup properly, the microphone or mixer/preamp could possibly be damaged/malfunctioning. I suggest taking your equipment to a trusted repair shop, or if still under warranty, returning to the manufacturer for repairs or replacement.
Hope this helps
Apr 05, 2011 | AKG Perception 420 Microphone
Countryman mic getting a noise like a white noise generator sounds but it comes and goes. What can I do about it?
Serious crackle or noise is a different problem, but a lesser, rustling crackle is very common with these mics. If you aren't looping the cable close to the mic, you will run into issues.
What you have to do, is put a small, 1/2' loop in the cable, making sure that the looped part of the cable is touching the initial part of the cable. Affix them so they stay that way throughout your performance/production. The closer you get the loop to the mic, the better.
As a test, take the mic, hook it up to equipment and listen on headphones. Start handling the mic, mainly by rubbing the cable, or rub the cable with various fabrics, listening for the rustle. Then put the loop in it and do the same thing. It is amazing how much more quiet it becomes. Try it with the loop half way down the cable and handle the cable above and below the loop. you can hear the rustling above the loop, but not below.
This model HAS to have that loop for quiet audio.
May 30, 2010 | Countryman E6 Ear Professional Microphone
The mic does not record stereo anymore. when playing back a stereo works fine but when recording in stereomodus only the left channel records, the right channel seems to record silence/noise
This Mic is not a stereo Mic. If you're using a windows computer, check your sound control panel to see if the mic wasn't suddenly set to two channel device.
Sep 30, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Microphone suddenly stopped working
Try uninstalling and reinstalling your sound card driver. Also do the same for any software that has anything to do with your sound card. If this diesn't work, try restoring to a point before you had the problem. If you is usb and one is standard then it has to be soundcard or software, more then likely it's a driver issue.
Aug 12, 2009 | Computers & Internet
Audio problem in our Sony TRV38 handycam..Please help!
I am not sure if you can use an external microphone on that model (check your owners manual) but that would be the first thing to try. If it records OK using an external mike, then the problem is with the internal microphone.
Mar 17, 2008 | Sony Handycam DCR-TRV38 Mini DV Digital...
Disabled internal mic on toshiba satellie A200
I've just had this problem and fixed it.
Right click anywhere in the "Recording" tab of your sound options. (the place where you disabled this mic) and click "show disabled devices".
Then simply enable it. Hope this helps.
Feb 11, 2008 | Computers & Internet
Studio Projects C1 Professional Microphone Logo
333 people viewed this question
Top Studio Projects Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Studio Projects Audio Player and Recorder Expert? Answer questions, earn points and help others
