Question about Sony KP-61XBR48 61" Rear Projection Television
Does excessive heat inside of projection tv cabinet cause elect arcing
Sonykp61xbr48 catches fire. Fire invest.stated origin to be inside the tv cabinet.Any expert advise would be apprec.!!!This should not be happening on a $6000.00 tv.
    President:
  • 3,130 Answers
If you have a cerification that the sony burned and caused a fire Nice law suite. But the japs have lots of attorneys and unless you settle you wont see a dime for at least 10 years maybe more. Been through this with a freind with sony. They dont give two hoots if you lost everything!! Its a shame but dont give up and take chump change and report this to every single news that you possibly can!!! Good Luck
Posted on Jul 25, 2006
Why did it catch on fire?
Any flaws in the painted surface on the inside of the unit will cause a spark and that generates heat. Examine the surfacecor any exposed metal. You have to use special paint to resurface the inside.
Nov 15, 2015 | Microwave Ovens
What are the benefits of buying fire proof filing cabinet?
They protect all your critical documents and others items you want to store in the cabinet in the event of a fire. Most large and many smaller businesses use them.
If you have irreplaceable materials that are critical to your business or your private business and finances you need a fire proof cabinet for critical storage.
Nov 13, 2015 | The Computers & Internet
What could cause temp light to flash on a panasonic projection tv
More than likely it could just be *DUST* build-up on the vent openings which vetilate the cabinet body. Or excessive *DUST* build-up on the motherboard in the base of the cabinet. Dust like this makes it hard for the components to disapate heat!
Mar 01, 2015 | Panasonic Televison & Video
My Samsung 50 inch DLP tv just started acting up. I have a good picture but at the bottom of the screen is a blue box that says "check the No. 1 fan". Then after about 5 minutes, the tv will shut down
I am not familiar with your Samsung 50" DLP, BUT.... The alert message implies that something is WRONG with the "No. 1 Fan." I suspect that it has QUIT WORKING altogether, and after a certain period of operation the TVs internal temperature builds up to a point where the heat becomes dangerous, either to the components, or even possibly becomes a fire hazard.
The shutting down is probably a self-protective function to prevent any more overheating which would seriously damage internal components exposed to the heat, or worse, cause a fire!!!!
Unplugging is good as it allows the system to cool down, BUT to continue use without repairing the cause of the fan failure, is dangerous!!!!
Either get your TV into a QUALIFIED REPAIR SHOP, or get a qualified PROFESSIONAL out to the TV.
IF the problem is not corrected, the TV could be irreprably damaged, or could catch on fire, neither of which is good!!!!!
Jan 10, 2015 | Samsung Televison & Video
Dryer making squeaking noise, what causes this?
The squeaking could be coming from the idler pulley on the motor, the drum rollers or a worn drum seal. It is not a good idea to spray the rollers with WD-40. The WD-40 will attract lint that will build up and could catch on fire inside the dryer cabinet. A bad drum support roller or any other squeaking component inside a dryer cabinet will normally need to be replaced.
Aug 29, 2011 | Maytag Neptune MDE6700A Electric Dryer
I hooked up wires as described. I smell elecrical
If the dryer has been sitting for a while, that may just be dust or lint that has gotten stirred up inside the dryer and ended up on the heating element. This is normal and it will go away. This often occurs after the dryer has been moved or cleaned.
However, just in case, you may want to review your power cord installation one more time. The following link explains:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Verify your installation paying particular attention to how to you have terminated the Ground and Neutral wires. Make sure the terminals are tight and not loose. Loose connections can cause arcing and excessive current which results in burned wiring or melted insulation. If it is correct, make sure you don't have any heavy accumulations of dust or lint inside the dryer cabinet. If the odor does not go away within a day, stop using the appliance and let me know. I hope this helps you.
Dec 05, 2009 | Estate EED4300SQ Dryer
Samsung DLP HL-R5667W lamp won't fire. Changed lamp & ballast and still won't work. Fans are working fine, color wheel good. Lamp door switch good. When I power on, I hear ballast buzz like it's trying...
Was the replacement lamp the same part number as the original as there are different arc gaps for different lamps and the wrong arc gap will cause the lamp not to light. Since the ballast is powering up the lamp should light if the baalast is matched to the correct arc gap of the lamp being used.
Nov 27, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Oven touches cabinet inner wall of cabinet. Fire hazard or not?
The rear of the oven has approx 3" or better insulation you are ok
Jan 17, 2009 | Cadco OV-250 Electric Single Oven
My tv pictures keeps flashing
Modern sets have certain protective circuits to avoid catching fire.
The clicking you are hearing is probably from a relay that is part of this protection or could be caused by high voltage arcing; either condition is not in the realm of a do-it-yourself repair.
Sorry-
Aug 24, 2008 | RCA Scenium M50WH187 50" HDTV
Jul 25, 2006 | Sony KP-61XBR48 61" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
