Question about Swintec 7040 Typewriter
Letters only partially there
The letters when typed on paper are only partially there, I took the wheel out and put it back in but now it will not spin correctly. Any suggestions? I have replaced the ribbon and that did not make a difference.
  • 31 Answers
Hi kehres,
Is there anything slightly pressed from the keys in the keyboard? the Capslock or Shift Key?
If you took the wheel out, ensure that it is places again correctly.
Posted on Oct 21, 2008
Cutting of bottom of letters
Really, you have a typewriter?
You stop typing before you reach the end. If it is the electronic type with a display, you need to set the paper size to the size of paper you are using.
If you are using a computer and word processing program, again, set the paper size.
Oct 01, 2015 | Office Equipment & Supplies
Typewriter spaces the letters wrong and types the wrong letters
how to install and set the daisy wheel correctly onto the typewriter
May 22, 2013 | Brother GX-6750 Typewriter
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
My typewriter (Brother GX-6750) does not print correct letters
look for bent or broken spokes on daisy wheel .turning unit off for 20 seconds and back on should reset the daisy wheel home position. probably the daisy wheel.
Oct 26, 2009 | Brother ML-100 Typewriter
Wrong letters are printed
The Daisy wheel is probably in wrong..reinstall it until it spins to the home position. Its either that or an adjustment to the print wheel motor.
Oct 07, 2009 | Swintec Office Equipment & Supplies
Have the same problem. Wheel does not line up with keys
You have to loosen the screw on each side of the carriage that holds the silver guide and move it away from the font wheel. The factory adjustment is to put in 2 pieces of paper and adjust to be snug. Take out the paper and it should reset properly.
Jul 20, 2009 | Brother GX-6750 Typewriter
TYPING II IN PLACE OF LETTERS
the mark you are seeing is the print hammer hitting the paper. remove the ribbon. corr. tape & print wheel. turn on the typewriter. close cover let it home it's self. open cover put in print wheel. close cover let it nome. put in ribbon close cover. try typing if marks are still ther. you will need a new print wheel. if working then put in corr. tape or if you are better at spelling then me you will not need it
Jan 21, 2009 | Smith Corona Wordsmith 200 Typewriter
Different letter appears from the one i've typed
Sounds like the wheel is out of alignment. I had this problem with the one I recently purchased for my daughter. Release the tension on the ribbon and head. Pull the wheel cartridge out and line up the letters. Put the wheel back and reapply tension. Repeat until it is aligned. Took me a couple tries to get it working, but its working and seems to be stable.
Nov 07, 2007 | Brother GX-6750 Typewriter
Correction Tape
Check the way the correct tape is installed. I have seen people twist them around the guide backwards and the correction material is facing away from the paper. Also can you see the correction tape lifting up?
Aug 13, 2007 | Brother GX-6750 Typewriter
Swintec 7040 Typewriter Logo
87 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
