Question about Panasonic CT-27G33 27" TV
Continuous low whistling or thin buzzing noise
When tv is turned on there is no picture, the screen is black and there is a whistling sound that only stop when the tv is unplugged.
    New Friend:
  • 163 Answers
The whistling sound is the horizontal oscilator and beliveme you need a tech...good luck...
Posted on Jul 25, 2006
  • hector delacruz Jul 27, 2006
    I agree but whent the power supply sound is a creeap sound not a whist sound as he say....and yes I work with that model that mainly comes with vertical problem, thats the our dayly bread....
    President:
  • 3,130 Answers
The high pitched sound is an indication that theres a short most likly in the Hi voltage sweep section or power supply and with out the proper training you should not even take off the back as there are no user replaceable parts inside of these sets. All the parts are soldered in and you can not look at them and see that they are bad.. its almost like when your check engine light comes on you look but what do you see without a computer to read the on board computer vto see what the problem(s) are. Take the set into or call a pro to assist you with this repair. good luck
  • Larry  Dillon
    Larry Dillon Jul 25, 2006
    sorry dude its not the horizontal oscilator. Its the main Power supply as its a smps . These power supplys make a loud high pitch sound if theres a short in another ccircuit. Maybe you dont know about these type of power supplys??
SOURCE:
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
I turned my television on then it made the tv frame made a noise!and now the screen is black except for this thin line across the middle of the screen which is display the picture
Most likely the vertical oscillator circuit has failed. As CRT televisions have gone the way of the dinosaur, my advice to you is to give a fond adieu and invest in a new TV.
Nov 05, 2015 | Televison & Video
Hi I'm having an issue with a Sony TV model KDF-E42A10 when I push power button it makes this buzzing sound and it sounds like a fan noise then turns off by itself and it has no picture the screen displays...
Is it 3 sets of 2 buzzes about 15 seconds apart ?
---This is a bad bulb or an improperly installed replacement
or a continuous buzzing ?
----This is a Power Supply Unit going-bad or failed. The louder it gets the harder it is working....eventually it will fail. Ensure there is proper ventilation around your TV.
Nov 15, 2014 | Televison & Video
Purchased Toshiba Regza 32AV615DB December 2010. On several intermittent occasions sound disappears and continuous buzzing noise takes over. Picture still on screen. Only way to rectify is turn TV off...
Sound carrier frequency are quartz locked in all modern TV. Your TV's sound freq: seems to be drifting. In the station tuning setup it will ask you Region ( Country ) Have you chosen correctly ?.
Mar 09, 2011 | Toshiba Televison & Video
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Occasional 'whistling/whining' from back of TV
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Jan 30, 2007 | Bush WS6671 28" TV
No sound and no picture.
Look for the vertical output, it should be a 7 pin transistor located on the defection board, meaning the board with the highvoltage transformer on it. Should be on a heat shield standing up(black)
Nov 02, 2006 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
204 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
