Question about HP Photosmart D7260 Printer
Scanning or faxing
Can I fax or scan with this machine?
No, you cannot
Posted on Nov 04, 2008
SOURCE: scanner seems to jam when faxing, scanning or coppying
Same problem. Out of waranty.
Posted on Apr 08, 2008
rakeshpramod
  • 234 Answers
SOURCE: HP Officejet 6310-all-in-one won't fax or scan
Does the All-In-One say Sanner failure...?
Try the steps mentioned bellow
Remove both the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector.
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing a test page or make a copy
Good Luck
Posted on Sep 22, 2008
  • 144 Answers
SOURCE: HP C6180, File is too large to send after scanning
Hi
You may check the resolution of the scanned picture,lowering down the resolution to some extent will not damage the quality of the scanned image,also it will lower down the file size to great deal and this should help you send the fax without any issues.
try it and get back to me for any assistance
thanks
Techbuddy247
Posted on Aug 07, 2009
SOURCE: "TX Function Not Completed"
how can i send e-mail from canon 2016i
Posted on Sep 27, 2010
micromatikal
  • 2777 Answers
SOURCE: The fax function on my Canon ImageCLASS MF4370dn
This is very strange indeed. Does it still receive faxes just fine? Have you tried just placing the paper on the platen and seeing if it will scan / fax that way? It sounds like a feeder issue, but can't be sure just yet.
Try that and let me know.
Thanks
Tim
Posted on Sep 30, 2010
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
I have a HP Laserjet 3015 fax machine connected to a phone line but not a computer. When I send a fax or make a copy a dark vertical line appears on each page. Incoming faxes print with no line. I have...
The fax scanning unit/encoder is dirty.
The fax scanning unit is like a camera. It take a picture of the document.
The glass plate is dirty and you may purchase a FAX CLEANING SHEET.
Officedepot
http://www.officedepot.com/a/products/470251/Office-Depot-Laser-Printer-Cleaning-Sheets/
or similar product to clean out the dirty area.
The dark strip is cause by semi-dry wipe out correction ink.
Give your unit a good cleaning and let me know.
Jul 08, 2010 | HP LaserJet 3015 All-In-One Printer
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
the key will glow green.
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
The machine starts scanning the
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
Dial the fax number.
If you press Black Start, the
machine starts scanning the first
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Scanner
Try updating the drivers. Take this link to Hp and either enter model number and then operating system or let Hp detect your hardware and select drivers.
http://www.hp.com/#Support
Aug 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer works fine, but when scanning to copy or scanning to fax a line appears right down the middle of the either the outgoing fax or the printed copy. This when using the feed from the top of the...
If it only happens when you copy or fax, as opposed to 'printing"...clean the scanner glass -both the main glass and the narrow **** glass on the left side.
Please rate me.
Mar 31, 2009 | Dell 1815dn All-In-One Laser Printer
Fax is received is very dark and almost unreadable
You can try using the menu to lighten the fax, but if all received faxes are dark, you may be experiencing a weak scan light. try making a copy instead of fax (which essentially is a fax printed to yourself) if also dark, its certainly your scanning imager that's failing. If that's the case I would recommend replacing the entire machine. Parts are expensive, and its a difficult to service part yourself. Also you may find that toner costs alone may pay for the replacement machine over this unit.
-Good Luck!
-FW
Jan 05, 2009 | Sharp Office Equipment & Supplies
Faxing/scanning from AIO 964
throw it in the dumpster and buy a new one
Mar 03, 2008 | Dell Photo 964 All-In-One InkJet Printer
No Scan Options Error Message
Vista?
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly. Solution Scan documents using Windows Fax and Scanning or Paint. Scanning with Windows Fax and Scanning
  1. Click the Start (c00845897.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File and then click Scan .
Scanning with Paint
  1. Click Windows .
  3. Click Accessories .
  4. Click Paint .
  5. Click File and then click From Scanner or Camera .
  6. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the printer. link to above info from HP
Dec 11, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP Photosmart D7260 Printer Logo
21 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
