Question about Toshiba Satellite M35X-S109 Notebook
Toshiba M35X how do I change from battery mode to AC power?
  • Toshiba Master
  • 2,794 Answers
Just plug the correct ac adaptor into an electrical outlet.  This will recharge your battery as well.
Posted on Oct 21, 2008
Notebook will not power on when on battery, but will run on the battery after it boots
Booting process take so much current from the battery. If the battery is not capable of supplying enough current to boot up, this may happen. Replace the battery with a new one. the present battery inside it will have insufficiant current for first boot up.
Mar 10, 2012 | Toshiba Satellite M35X-S149 Notebook
Hi guys my Toshiba m35x s149 fell 2 feet to a wooden floor.The battery meter shows power of 63% but upon removing the power cord it switches it off.Tried another battery same response.when all is off( no...
I would think that the internal battery connections have been damaged from the fall. They may only need re-soldering. Any drop on to a hard surface from almost any height can damage your laptop.
Apr 18, 2011 | Toshiba Satellite M35X-S149 Notebook
Power goes out whwn I unplug ac adapter
ther must be a short in the plug, get it checked before something goes really wrong
Jun 01, 2010 | Toshiba Satellite M35X-S311 Notebook
I have Toshiba M35X satellite series. The problem is my laptop starts being late after it is turned on. And the other problem is the battery can be charged only up to 52%. After that the laptop will urned...
First, this may be an issue of old battery. The m35 is a rather old model, so it's no wonder if the battery fails to load at all. Second, your laptop may be suffering from the Maxim chip problem. During the time of m35, a lot of other laptops had this same problem with this Maxim chip that caused all kinds of weird problems with both Toshiba and HP models such as the m30, m35, m115, A65, A75 etc, and the HP NC6000, NC7000 and NC9000 series. It's a long story, a long explanation on how to repair the dead Toshiba m35 laptop. Take a look at the post for symptoms and solution, and don't forget to leave a comment if you find it helpful.
May 20, 2010 | Toshiba Satellite M35X-S163 Notebook
Toshiba m35x-s349 turns on but does not boot
check battery power. Lots of times laptops won't boot if the battery has gone down to low. Probably has just enough charge to turn the machine on but not enough charge to boot the machine.
Nov 09, 2009 | Toshiba Satellite M35X-S349 Notebook
Battery problem
all laptops are capable of running strictly on ac power. if your battery is not charging it sounds like time to get a new one.
you can get one here:
Sep 14, 2009 | Toshiba Satellite M35X-S161 Notebook
Satellite m35x-s309
This can be a few things. first try and cold start it.
1. Take out the battery leave it pluged in. hold the power button for 5 sec. then release. turn on system normaly once in windows shut down. replace battery. turn back on. that should work.
2. You have a bad driver problem trying loading into safe mode hit F12 and select safe mode if it loads with no problem then it could very well be a driver or software problem
3 if nether of them work then you have a hardware problem which could be causing overheating.or just a device going bad.
Jun 29, 2009 | Toshiba Satellite M35X-S309: M35X-S309...
Will not recognize AC POWER, Running from Battery only- now battery is dead.
The adapter might be faulty
Check the adapter with multi-meter, the voltage reading should be slightly higher than the voltage output that is printed on the label on the adapter.
May 02, 2009 | Toshiba Satellite M35X-S311 Notebook
Toshiba Satellite M35X-S109 Notebook Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
