Question about Delphi SKYFi3 XM Radio Receiver
Downloading instructions Delphi SKYFi3 unit
I have been trying to find instruction on downloading a few hours of XM radio to the unit. Neither the manual or XM web-site or other site are helpful with obtaining step by step or logic instructions. I've had the unit for three months and still can't get it to work other than in the car. FRUSTRATED.
  • matpatta Feb 15, 2009
    1. I purchased my skyfi3 from xm radio on 12/22/2008, I tried to hook-up the unit at that time all I got was "checking media " now it's 2 months later I called xm radio technical support we got the unit to work by pressing the up volume and the mode button at the same time, this reset the radio. It worked for one or two days now the reset process isn't working at all. Is their a solution or do i have a bad unit also is their a toll-free number for Delphi as xm radio warranty is only good for the first 30 days thanks
    Problem Solver:
  • 5 Answers
You can't download Xm programming, like you can from itunes, where you get a song in 3 or 4 seconds.
Do you mean record music? You must record realtime, either while listening or while the unit is idle in its cradle.
It's easy. while listening to the radio in the cradle (press mode repeatedly to get to Live XM mode), then press the center (play/pause) button.  the menu will pop-up, select Record.  It will give you the option for Song, Channel, and Session.  Just chose one of the first two and press the button.  You should see a microphone appear at the top of the screen.  It's recording.  Follow the same steps to stop the recording.  Setting up a recording session is self-explanatory once you get into that screen.
Posted on Dec 19, 2008
Problem with the Delphi SKYFi3 XM Radio Receiver UNIT LOCKED UP WILL NOT COME ON OR GO OFF
Common problem with SkyFi3 units. You have to press the Volume UP button and hold it while you press the POWER button; this will 'reboot' your radio, then you can try it again to get it to go off.
You will need to update your firmware on the radio using the baby USB cable and the unit plugged into your computer WITH the battery recharged FIRST. Also, go to the www. xmradio dot com website and download the SkyFi3 FIRMWARE update. Then you need to download the "firmware update" into your SkyFi3. If this doesn't fix your lockup problem, you need to call DELPHI customer support, and they can tell you one more 'master reset' method. After the firmware update, it might take 2 or 3 'restarts'. Again, press and hold the Volume UP and PWR at the same time to reset a 'locked-up' SkyFi3. Regards, John
Oct 01, 2010 | Delphi SKYFi3 XM Radio Receiver
How do I use a new MicroSD? Unit locks up when Checking Media
First of all, suggest using an SD card of 2GB or under. Second, firmware update. Here's the details: This is a common problem with SkyFi3 units. You have to press the Volume UP button and hold it while you press the POWER button; this will 'reboot' your radio, then you can try it again to get it to go off.
My Delphi skyfi3 xm radio has stopped working, It seems to be in a freeze mode with the channel and signal strenth showing good but I am unable to command it to change. I have tried holding down the...
Hi
Hold down "power" and "volume up" at the same time to do a reset. You need a 'firmware update' from the Delphi website. Also, you can call Delphi for help too.
What you need to do is simultaneously hold the VOLUME UP button as well as the MODE button. This will reset the unit.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 20, 2010 | Delphi SKYFi3 XM Radio Receiver
I have a XM delphi skyfi3 and I can record songs and listen to the radio portion fine. However, I cannot play my recorded music back on the my music mode, regardless of whether the xm is in the cradle or...
You must have a subscription and listen 'live' 8 hours a month, or it doesn't let you listen to recorded content anymore (thanks to the RIAA and their royalty fees to XM)
Jun 27, 2010 | Delphi SKYFi3 XM Radio Receiver with Car...
Skyfi3 stuck in Detecting SD Card mode - tried popping SD card in and out a few times - that didn't work. Tried pressing the Mode button and the volume plus and nothing. Tried to XM Firmware Update and...
8GB card is a SDHC card, and these units were designed to read SD cards. At a glance, you would think it shouldn't make a difference, but data is stored differently on SDHC because of expanded capacity than SD cards. I, too, learned the hard way; purchased storage card before researching "processing" capabilities of the Skyfi3 units.
Your card should work fine in a Cell phone or other devices specifically designed for SDHC cards. Hope you get some use out of it.
Feb 18, 2010 | Delphi SKYFi3 XM Radio Receiver
Delphi skyfi3 display blank. manual power only briefly...
try plugging the DC adapter directly into the buttom of the SKYFI3 - do you still get some sort of a power warning?
Jan 20, 2010 | Delphi SKYFi3 XM Radio Receiver with Car...
Delphi SkyFi3 Battery WIll Not Hold Charge
You can buy a whole radio for as little as $30. I would even call XM and tell them you're going to cancel because your radio died, and they might sell you one if you guarantee to stay with them for a year?
Aug 02, 2009 | Delphi SKYFi3 XM Radio Receiver
Trying to update firmward on Delphi SKYFi3.
when it gets stuck scanning. Press (volume up) and the (mode) button both down for a few seconds. when you release the two buttons this will turn it off and back on in few seconds.
Mar 20, 2008 | Delphi SKYFi3 XM Radio Receiver
Delphi SKYFi3 XM Radio Receiver Logo
454 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
