Question about Nokia e65 Cellular Phone
E65 3G problem
each time my E65 is connected to a 3G network it never turns off the light. How to fix this problem?
Thank you
Hello, I have Dynex Dx-ebusb WiFi adapter, my Laptop has operation system -Windowls 7. Every time when I try to connect some network, I have a limited access to this connection. Maybe i don't have...
It sounds like you don't have the correct security (WEP/WPA) key. if you are trying to connect to your own network, I need more information. if you are trying to connect to someone else's network, please stop, it's illegal.
Feb 23, 2011 | Dynex Wireless-G USB 2.0 Network Adapter
Kept on getting "not connected"
Hello. If you are using a hardwired connection (cat 5 Ethernet cable) and if your wireless is still turned on, you might be seeing the notification that you are not connected to a wireless network.
If this is the case then the fixes would be:
1 Turn off the wireless switch. (recommended)
2 Turn off network connection notification in the network settings.
Good luck
Jan 31, 2011 | Computers & Internet
Hello, i have a hp notebook which code 31 error on
http://support.microsoft.com/kb/932520
Microsoft says to Ignore the problem, and the adapter will continue to work correctly. If the message is really annoying maybe you can try turning off IPv6.
Control Panel\Network and Internet\Network Connections
right click your network card>properties
uncheck the IPv6 box
that'll turn off IPv6-then just disable the adapter driver
Feb 23, 2010 | HP Pavilion dv6000z Notebook
Hello :), One day I turned on my computer and my network connection shows up limited connectivity now every time I turn on my computer it my internet connection shows up limited connectivity. I've tried...
if you are getting limited connectivity.. double click on network icon on task bar and go to support tab and click on repair..it will work.. if its not working give the ip and dns and default gateway manually.. not DHCP
Dec 31, 2009 | Microsoft Windows? Vista Home Premium...
Dell Optiplex 260 Went Mute On Network
Some cables can be ok on test but one of the wires can be loose inside the cable and it will prevent pockets to be sent out and received but will test as ok. not that often but i have seen it before.
Dec 10, 2009 | Dell OptiPlex GX260 PC Desktop
The internet light is off all others green on the 5100 modem. Also, very slow internet and hard to go to various webpages. Will this correct itself over time or is there a quick fix?
You can try resetting the modem to factory condition.
Turn off the modem from power
Disconnect the modem from the computer
Turn on the modem
Press the reset button using a pointed object, (a toothpick or a pencil)
Wait for all the lights to flash green then release the button
Reboot your computer
Connect the modem to your computer
Everything should work fine.
If the problem persists contact the service provider.
Thank you for choosing Fixya
Oct 12, 2009 | Efficient Networks SpeedStream 5100 Modem
CAN'T CONNECT TO WIRELESS PRINTER AFTER VPN TUNNEL CONNECTION
Check the IP segments. Your printer & your machine would be falling in the same IP segment as your job network. Change the IP segment of your pc & printer.
Sep 01, 2009 | Arris SURFboard SBG900 Wireless Router...
Wireless Connection Problem
Hello, Have you installed all "chipset" drivers? also look in device manager if you see any question marks
Jun 26, 2009 | Acer Aspire 5610-2089 Notebook PC (ACER...
My toshiba satellite 350
go into the bios setup utility at startup and makes sure your wireless network card is listed and enabled. go to control pannel, device manager, and see if it is listed in the network netvices, it will have a yellow exclimation mark if faulty, try updating the drivers. a red x if it is disabled, you can enable it from here, if it is not listed you probibly have a faulty network card, hope it helps
Jun 23, 2008 | Computers & Internet
Nokia e65 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
