Question about Tektronix Refurbished Phaser 560 Color laser printer -29119
Tektronix Phaser 560 Printing Problem with Mac Leopard
I've had a Phaser 560 for 2-3 years and just upgraded my computer from a Mac Powerbook with OSX Tiger to a MacBook Pro with OSX Leopard. I installed the 560 drivers on the MacBook, but I'm having trouble printing some pdf documents. Different things are occurring.
Sometimes the page(s) won't print at all and I get a error print out starting out with something like:
ERROR: undefined (COMMAND TYPE: nametype)
OFFENDING COMMAND: OZCJTD+Garamond-Book*1 "OZCJTD+Garamond-Book*1" (or some other font name)
Then some more stuff about OPERAND STACK; DICTIONARY STACK; and EXECUTION STACK with some entries after each.
(I've changed fonts in the doc, but it doesn't seem to make a difference.)
Other times I'll print a range of pages and some of the pages will print ok, but others in the range will be missing text, or will print as a "mirror" image.
Any thoughts on what I need to do? I really don't want to buy a new color laser printer. I've been really happy with the 560 up until now.
5 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Posted on Jan 15, 2009
SOURCE: Phaser 740 Printing Cyan only
The problem is usually caused by a faulty imaging device, specifically a bad cleaning blade.
Occasionally this error can also be caused by a sticking cleaning blade clutch.
In this case the grease that was used to lubricate the part becomes gummed up and the moving parts begin to stick and don't move freely as they are supposed to. This is especially common on these printers if they are not used heavily or have sat for long periods between uses.
Sometimes you can free up this gummed up grease by running the solenoid diagnostics several times over. You do this by turning off the printer and then powering up while holding buttons 1 and 3 on the front panel display. Button 1 is the exit button.
This will put your printer into service diagnostics mode. Page through the diagnostics menus until you come to the clutches and solenoids menu. Here you need to hit the start button, then scroll through till you see the test for the cleaning blade. Press start to run the test.
Let this test run for about an hour then hit the stop button and turn off and restart your printer.
If your printer is printing normally again then the sticky clutch is your problem and you will eventually need to remove it and clean off the old grease and relube it. I recommend a high quality lithium grease.
If your printer does not print correctly again after doing this test, then chances are that your cleaning blade on your imaging unit is bad and the imaging unit will need to be replaced. You can generally find them on ebay for a reasonable price.
This problem applies to both the phaser 560 and 740 models. The imaging units on both these printers are also interchangeable. So if you have a phaser 560 you can use an imaging device from a 740 and vice versa.
Posted on Feb 09, 2009
prashanthcl
  • 460 Answers
SOURCE: Ricoh printer printing error: undefined offending command: mz
it is a logic card problem. so pls checked it from service center.
Posted on Aug 25, 2009
  • 23 Answers
SOURCE: Hi I have a TEK Phaser 560 Printer that displays Error 32
There's a solenoid under the control board that actuates a stop for the cleaning blade shaft. The open cell foam the factory used to quiet the noise deteriorates with time leaving a sticky residue from the double sided tape.
Pick all the residue off and clean both the solenoid shaft and the metal plate. If you're concerned about noise, put some electrician's tape on the plate. But you might be going in for that falling off down the road. :p
Posted on May 12, 2010
  • 165 Answers
SOURCE: whenever i try to print
Send the font information for each page in the PDF file when you print.
For Adobe Acrobat Professional 9:
1. Choose File > Print.
2. Click on Advanced.
3. Choose Postcript Options.
4. Under Font and Resource Policy, select Send for Each Page.
In Adobe Reader 9: try this 1
3. Under Font and Resource Policy, select Send for Each Page.
may or may not work try it
Hopefully this will be helpful to you all
Posted on Nov 20, 2010
How can i get free 10.5 for powerbook?
it will run slow, but you need to search for "OSX.10.5.6.Leopard.PPC.G4" on tpb or ebay / craigslist
Jul 28, 2014 | Apple iBook 12 iBook G4 1.33GHz,...
I have Mac OS X 10.5.8 need to upgrade to 10.6
The PowerBook G4 line was the last generation of the PowerBook series, and was succeeded by the Intel-powered MacBook Pro line in the first half of 2006. The latest version of OS X any PowerBook G4 can run is Mac OS X Leopard, released in 2007.[
Your computer is too old.
Mar 18, 2014 | Apple PowerBook G4 Mac Notebook
I HAVE AN APPLE POWERBOOK G4 I PURCHASE FROM EBAY IT IS CURRENTLY RUNNING MAC OS 9 ,HOW CAN I UPGRADE TO OSX 10 ?
Hi Bobby
You will need to get an OS X installation DVD. Try eBay.Don't go for anything lower than 10.4 (Tiger)10.5 (Leopard) and 10.6 (Snow Leopard) should run fine on this machine.Don't bother with 10.7 or 10.8
Jan 05, 2013 | Apple PowerBook G4 Mac Notebook
I have imac. and i want to change his operating
Yes it is very easy to do as you are running a Mac with Intel Processor. You have Mac OSx Leopard with updates 1,2, & 3. To upgrade to Mac OSx Snow Leopard you must buy the upgrade. Go here: http://www.apple.com/macosx/ On the top right click (Buy Now) You will have to pay $29 which is a bargain. Once you get the upgrade on CD simply follow the directions for the simple upgrade. I did the same thing when Snow Leopard came out. It is well worth the $29.
May 29, 2010 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
I use a Mac G3 Wallstreet Powerbook with OSx. Does OSX talk SCSI?
It will only read devices connected unless there is a problem with the scsi port. Also be aware early scsi needed termination to be read.
Apr 08, 2010 | Apple Power Mac G3 Desktop
QuarkXpress 7.0 clips picture "at back" when printing
Sir,
Check these 2 links
Link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Apr 20, 2009 | QuarkXPress 7 Full Single User Mac/Win...
Upgrade macOSX 101
If you have OS X 10.1.5, you would have to do a fresh install of 10.5 because you can only upgrade to 10.5 from 10.3, anything before you would have to archive your data and do a clean install.
Mar 12, 2009 | Apple PowerBook G4 Mac Notebook
MBox 1 Compatibility with new Macbook Pro Unibody and OSX 10.5.6?
unfortunately any pro tools application below version 7.4.2 is not compatible with leopard and I don't think you can use mbox 1 with the universal mac I may be wrong but I wanna say I tried a while back and even garageband wouldn't find it anymore but you can check for sure by going to the applications folder then open the utilities folder in there is an application called "Audio Midi Setup" and you can select the mbox in there if you see it but if not there is no patch or driver that I know of to get it working unless you upgrade pro tools which if you do upgrade I suggest getting mbox 2 and getting LE with it
Mar 12, 2009 | Digidesign Mbox External Sound System
Phaser 560 "Jam at A"
Are there small pieces of torn paper on the rolls anywhere... Had that happen
Mar 18, 2008 | Tektronix Refurbished Phaser 560 Color...
138 people viewed this question
Top Tektronix Office Equipment & Supplies Experts
k24674
Are you a Tektronix Office Equipment and Supply Expert? Answer questions, earn points and help others
