The printer was on, placed a sheet of paper on to make a photo copy, loaded the paper tray and pressed Start copy in black - not colour. A message appeared on the screen to say "Turn power off, the on again" C4EB8401 After turning the power on and off, unplugging the unit, on re-starting, the message continues and will not allow me to copy or print. Please let me know what to do as this matter is urgent.
    Genius:
  • 2,120 Answers
If it is an HP machine, the scanner system has gone bad. This is a known issue by HP.
Unless it is under warranty, it is uneconomical to repair.
Posted on Oct 21, 2008
Replacement Printhead for lexmark Impact S305 purchased, fitted/installed with no successful outcome?
After you changed the printhead, even full cartridges need some time to fill up the head. So just copy a newspaper, put in a normal sheet of paper, and tell the printer it is a Photo, with Photo paper. It then will press the most ink.
If one of the colours start, it could take a complete A4 photo, before all colours are coming through.
I assume you did install the new head correct and not something else was defect before you started to change the head anyway. Because when something else was defect in the first place, a new head won't change that.
Sep 12, 2014 | Lexmark S305 IMPACT LEXS All-In-One...
Printer is not printing the black colour when i load the paper from the rear slot...
Hi
try printing a "Nozzle check" to confirm that both your black cartridges are working ok. One cartridge - the smaller (photo) one is used for printing photos on glossy paper. The second - bigger cartridge is used on plain (copy) paper. Sounds to me like your smaller (photo) black cartridge is not working. It's either empty or may need "Cleaning" or "Deep cleaning". In case you don't know...Nozzle check, Cleaning etc utilities can be found on "Maintenance" page in "Printer properties".
good luck
Lumir
www.inkbank.com.au
Mar 07, 2014 | Canon PIXMA MG5320 All-in-One Printer
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    Black ink is not dispensing right
    Clean the print head then print a demo sheet.
    1. Verify that inkjet paper is loaded in the paper trays.
    2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
    3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
    4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
    If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
    http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
    Nov 15, 2010 | Kodak ESP 5 Printer
    Red light on steady
    If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
    If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
    May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
    Lexmark x1240 All-In-One Printer Control Panel
    Hi
    This is the description of printer control panel
    green button-START COLoUR COPY BUTTON.....place a documnet on scanner glass...press this button..u would get colur copies of the document
    Black button-START BLACK COPY BUTTON.....place a documnet on scanner glass...press this button..u would get black copies of the document
    white button on the left hand side-paper feed button..to load paper into the paper feed tray
    white button the right...not sure:)....i guess it should be the scan button....
    all the best
    Apr 02, 2009 | Lexmark X1240 All-In-One InkJet Printer
    How to copy with Epson SX 100 pleaae?
    first of all on the printer.then place the document to be copied (the orignal)on the scanner glass.then press the option button copy on the printer.then press in which mode you want.if you want the document to be copied in colour press the colour button on the printer.if you want the document to be copied in black press the black button on the printer.and place the blank paper in the paper tray ,thats all.
    Feb 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
    Error inkcartridge
    Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
    Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
    Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
    Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
    Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
    Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
    Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
    Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
    Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
    Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
    Error Message: Scanner unit open -- > close the scanner unit
    Solution: Carefully close the scanner and press it down until it clicks securely into place.
    Error Message: Scanner error -- > See your documentation and call service if necessary.
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
    Error Message: Printer error -- > See your documentation and call service if necessary.
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
    Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    My kodak easyshare5300 is printing black picture
    Hi-
    If your product is still within the warranty period from KOdak then you can call them up for some step by step troubleshooting to help you with your problem and as well they can replace the printer if defective.
    Try this first
    Calibrate your printer, then print a demo sheet.
    1. If paper is in the photo paper tray, remove it.
    2. Load photo paper into the photo tray.
      1. Fan the paper to keep the sheets from sticking together. IMPORTANT: Do not overload the photo tray.
      2. Load a maximum of 20 sheets into the photo tray, with the Kodak logo facing up.
    3. Calibrate your printer.
      1. Press Menu.
      2. Select Calibrate Printer, then press Start.
      3. Wait for your printer to print the calibration sheet.
      4. Place the calibration sheet face down on the scanner glass.
        • For the 5300 AiO printer, place the sheet on the front right corner of the scanner glass.
        • For the 5500 AiO printer, place the sheet on the left rear corner of the scanner glass.
      5. Press Start.
      6. Wait until "Calibration complete. Remove calibration page from scanner glass. Press OK to continue." appears on the LCD display.
      7. Remove the calibration sheet from the scanner glass, then press OK.
    4. Print a demo sheet.
      1. Disengage the photo tray by sliding it towards you until it stops. When the photo tray is disengaged, the main tray is active.
      2. Select Print Demo Page, then press Start.
      3. Wait for the demo sheet to print.
    Then call them if issue Persist at these numbers:
    In the U.S. and Canada: 1-800-421-6699
    In Australia and New Zealand: 1800 793 895
    Thanks for using Fixya!
    Jun 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
    Help Epson CX3200
    I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
    May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    196 people viewed this question
    jasbo
    jasbo
