Question about Sony Xplod XM-554ZR Car Audio Amplifier
Quick question about the power
I have the 12volt live wire connected to the car battery, and a remote wire connected to the aux power supply.....THe amp works and everything is fine. My question is, when the car is off, the power light (green) is still on. IS IT SUPPOSED TO BE???...the reason why I ask is because, me being a moron, spliced the live 12v wire from the battery to both terminals (REM & 12v), of course the amp worked fine, but overnight it completly drained the battery ( had to get a new battery), I dont want the same thing to happen again. thanx
  • 631 Answers
The remote turn on terminal on the amp needs to be connected to a switched power source. Typically, it's the remote turn-on/power antenna wire on the head unit. If your head unit doesn't have such a control wire, connect the remote turn-on terminal to a wire that's controlled by the ignition switch.
It's VERY important to fuse all of the wires properly. If you're unsure of the proper fuse for a given wire size, read pages 14 and 16 of the Basic Car Audio Electronics site.
Let me know if you have any other questions.
Posted on Oct 21, 2008
No you will need your separate remote wire connected to either the back on you deck or to a source that completely cuts off with the car. Your battery is always powered you amp needs a cut off source to tell it to turn off when the car is off.
Posted on Dec 02, 2008
Alpine cda 9807 in yukon xl
hi david, check out the connection of the yellow and red wires on the back plug. yellow must be connected to a direct battery positive line(continuous positive), the red must be connected to a live wire from the ignition switch OR from a point that is +12v live once the car is started(switched positive). also make sure that that the ground connection is a direct good connection to the body of the vehicle!! make sure that the remote wire(blue) is insulated if you not using an automatic aerial or external amplfier. good luck.cheers.
Sep 08, 2013 | Alpine CDA-9807 CD Player
My amp doesn't turn on but all wires are plugged in. I tested it right before I bought it, it's grounded to a bolt in the chasis. What could be wrong?
If you have a voltmeter or a 12V trouble light, check to see there is 12V at the remote terminal when everything is on. The remote wire coming out of the head unit cant supply a lot of current (usually around 1/2 amp). even a quick short to ground on the remote wire can render it useless.
Jan 30, 2013 | Rockford Fosgate Punch P5002 Car Audio...
CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK THRU TRACK POWER - WHAT IS PROPER WAY TO HOOK UP RED AND BLACK WIRES? LIONEL FASTRACK
Track power is not recommended for this uncoupler. Use an aux fixed supply of at least 10 to 13VAC for the supply. You have to move a jumper on the bottom of the track to do this. Then there will be four wires needed. Two for the aux power (hot and common) and the other two which go to the pushbutton switch.
Note: Same goes for Lionel FasTrack Remote switches. Run the switches from a 10 to 12 VAC aux supply. There is a jumper you remove on the bottom of the switch to connect an aux supply.
Apr 27, 2011 | Lionel 12020 Fastrack Remote Uncoupling...
Is the cerwin vega 3200 MPLIFIER SUPOSE TO BE CONNECTED TO ELECTRICITY?
your amp requires a 12volt power wire from the battery, a negative wire grounded to the car body, a remote wire that connects to the radio or fuse box, rca jacks from the radio, and speaker wires from amp to speakers. hope this helps. please rate 4 thumbs up.
Jan 21, 2011 | Cerwin Vega Vega 3200 Car Audio Amplifier
Does it work in my house
This radio requires 12volt DC power and a suitable antenna.
It will work in your house if it is
A)connected to a suitable 12volt DC power supply with the wires the right way around (connecting the wires the wrong way around even for a moment will blow the in line fuse and the radio will not work until the fuse is replaced and the wiring is corrected, never bypass the fuse or fit a larger rated fuse).
B) connected to a suitable antenna.
If you like in a area where there are few CB radio users then the radio may work but there may be nobody for you to talk to. The local geography and how high up you can get the antenna will make a large difference to the range. The range will be much larger if you live on top of a hill than if you live at the bottom of a valley.
Dec 27, 2010 | Midland 1001Z 40-Channels Base CB Radio
My 2000 ford focus (waggon)trunk wont open with the remote or the dash switch
check the actuator for the trunk release with 12volt power supply if it work you have an open wire or short to battery or short to ground.
Mar 23, 2010 | 2000 Ford Focus
How to
Please follow the following instructions 1)Use a wiring harness equipped with an adapter plug for faster connection and installation.Disconnect the car battery while installing electronic equipment.
2) Make a note of the wire colors and connect the power supply wires to the DEH-45DH as follows:
Orange wire to the constant 12Volt
Yellow wire to the switched 12Volt
Black: ground wire
3) Connect these wires to control display functions on the DEH-45DH:
Attach the gray wire to the wire marked control panel illumination.
The brown wire connects to the dimmer.
4) Make the front speakers connections following this color scheme:
Left front positive (+) tan wire
Left front negative(-) Gray
The light green wire connects to the positive (+) terminal of the right front speaker.
Connect the dark green wire to the negative (-) terminal of the right front speaker.
5) Make these rear speaker connections:
Brown wire to the left rear positive (+) terminal
Yellow wire to the left rear negative (-) terminal
The dark blue wire attaches to the right rear positive (+) terminal
The light blue wire connects to the right rear negative (-) terminal
Hope this helps
Thanks
Smith.
Sep 09, 2009 | Car Audio & Video
Amplifier doesnt cut off with car, battery dies every time
I assume you are speaking of the car battery, and it gets drained when the ignition is turned off.
Your problem is you have connected your system to the wrong power connection. Automobiles have wiring lines that supply power all the time, to other parts of your vehicle. You need to find a power connection, preferably from your fuse box, that stops supplying power when the ignition is turned off. This will also help provide a back-up fuse incase of any other problems you might incur.
Sep 09, 2009 | Dual TOA IP-600D Channel, 400W Power...
What color is what for the radio wires i have like a atapter
your car should have an ISO connector, all newer radios also have ISO connectors, one for the 8 speaker wires and one for the power block, they cannot be connected wrong.
If on the other hand some muppet has chopped off the connectors instead of using a proper converter connector then you should reinstall new ISO connectors.
You will need:
A 12v test light or a multimeter set to 120vdc
some masking tape to make labels and a ped to mark the labels.
A quick test to establish the correct wires is.
using your 12volt test lamp or multi meter, find a wire that is live when ignition is off, this is your +30 live, now switch on ignition and find one that is live, this is your+15 live, now switch on the lights, is there another live? this is your lights or dimmer wire. with the lights and ignition on connect the live lide of your tester to the +30 wire and find one that is earth, (you should be running outof wires by now anyway, this si your earth or ground wire.
The speaker wires will probably be seperate and if you have a bunch of 8 wires, that's them.
you will find there is a prime color and another with the same color but with a trace, so make into pairs, ie, red and red/white, green and green/white etc.
using a 1,5v AA battery touch each pair very briefly in turn, the corrisponding speaker will 'pop', mark up front left etc.
There ya go, all sorted.
Mar 07, 2009 | 1987 Mercedes-Benz Mercedes Benz 190 Class
HOW 2 INSTALL A AMP IN MY CAR?
First make one wire your ground wire by screwing the end with a connector into the frame of your car trunk, on bare metal, then connect your remote wire to a fuse that is only on when your car is on. then connect the 12volt wire to the postive side of your battery with a connector. depending on the size of your amp, the gauge wire you need will vary. On your 12volt wire you may need to place a fuse in between where it connects to your battery and your amp to insure that the power will be shut off when the fuse blows instead of blowing your amp if something were to happen.
Mar 21, 2008 | Car Audio & Video
Sony Xplod XM-554ZR Car Audio Amplifier Logo
106 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
