Dell laptop wont power up looks like its starting ok then shuts down. Power is on at transformer (green light)
  • 52 Answers
It looks that the laptop has a main problem.
Try this:
1. turn on the laptop
2. press immediately the F8 key.
3. If you press o.k. the F8 key, it should open a menu.
4. go to open laptop in error mode, or something like this.
5. press intro and wait until the laptop continues loading.
6. When loading is finish, go to start, programs, accessories, system tools, restore system
7. restore the system to a previous stay.
evelasco
Posted on Oct 21, 2008
I have a dell inspiron 570 when I turn on the dell it starts to power up then shuts down with in 3 to 5 sec , but when I wiggle the power supply plug to the mother board it trys to power up again only to...
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 28, 2013 | Computers & Internet
Shut off and wont come back on, help.
Does the power adapter have the green light lit? If so, does the computer flash any lights when you press the power?
Mar 01, 2011 | Dell Studio 1555 Notebook
When i push the power button, inspiron 1525, it turns
try this.... go to start | run | control
go to power options
on the advanced tab there will be a option called
"when i press the power button on my computer"
select the "shutdown" option
click apply and ok
then try shutdown your machine using the power button
Dec 22, 2009 | Dell Inspiron 1525 Notebook
Dell D600 Power Up Issue
there is a short circuit onnthe laptop motherboard usually it's power ic's that are next to the power socket that block the power from going to other parts so you should change those ic's
Sep 08, 2009 | Dell Latitude D600 Notebook
I have a dell dimensions 5100 C and I was using it one day and it all of a sudden shut down. Now when I go to turn it back on the amber led light on the power button flashes, and will not power up....
You need to listen carefully to those beeps they will tellyou in a moment where to start looking for any problem
They are listed in your manual but if you dont have that then they re listed on the dell websiteunder the support section Q and A.
Aug 21, 2009 | Dell Computers & Internet
Dell inspiron 5160 wont start
It sounds to me like your Laptop over heated... I cannot be for sure But I would get your Motherboard check because it sounds like its shot.
Mar 18, 2009 | Dell Inspiron 5160 Notebook
No power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
Inspiron 9200 cannot power up.
Start by checking the power supply with an ohm meter for the correct output, however, this is generally a problem with the battery or a memory chip. Start by removing the battery and starting up on the power supply only. Dell batteries are notorious for causing a no start. Then try removing the memory and try one chip at a time in both slots. If none of these work, then I'm afraid you have a failed system board component, and you will probably want to take it in for a professional diagnostics. Also, you can find a diagnostics light codes list for your machine at Dell's support site.
Aug 06, 2008 | Dell Inspiron 9200 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
