CORCHO PROPANE INFARED WALL HEATER PROBLEM
Hi I have a Corcho CK-18 infared wall heater that has a problem, it worked fine last year but this year when I lit it only one side will heat up completely. it has 2 bricks in it, 1 is small and the other is large, the small one will turn bright orange like it is suppose to but the large side will only get about a 3rd as bright, I have taken it apart and made sure that the pipes and orfices to the bottom part was clear, could it be a control valve problem or could it be something else, any help would be very grateful, thanks Terry
2 Suggested Answers
SOURCE: can not get the bricks to light on my empire corcho
I have the same htr in Mich. & have worked on gas htrs.for many years.
Does the flame go out when you let go of the button to lite it?
If it does, then the thermocouple is bad.
If the flame stays on, but goes out when you turn the dial,
the gas regulator is bad.
Probably a little more expensive to buy new then to fix it.
Michael.
Posted on Nov 22, 2009
Pilot lite will not stay on when I release the igniter pressure knob REH-18-N wall heater!
IS there gas? YES ok. So if you can get the pilot lit, but when you let up on the button it goes out. Few things to check. On some heaters the manf. install a safety switch to drop the pilot out if its not venting or if its over heating.
Jan 01, 2017 | Heating & Cooling
Burner for corcho wall moont heater model number ck30t3lt
Search Results
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with ...
    www.efireplacestore.com > ... > SunStar Heating Products Space Heaters
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with Manual Controls ... For added convenience, you can mount this heater on a wall or have it stand on ...
    Tech Video: Wall Heater Maintenance - YouTube
    ? 3:33
    https://www.youtube.com/watch?v=8eglHvyNV3U
    Oct 19, 2010 - Uploaded by FMIPRODUCTS
    How to clean the Vent-Free Wall Heater burner's & pilot. ... Fix Mr Heater Vent Free Pilot Problems - Part ...
    EMPIRE CORCHO UNVENTED GAS HEAT
Dec 14, 2015 | Heating & Cooling
The pilot on my sunstar corcho wall heater won't stay lit
Try cleaning the gas tube with a pipe cleaner and insure the flame is in contact with the thermo coupling.
Dec 09, 2013 | Desa International Heating & Cooling
DUAL HEAT PROBLEM
the passenger temp adjuster is at fault.
Dec 21, 2009 | 1994 Buick Park Avenue
HOW TO LIGHT PILOT ON EMPIRE CORCHO WALL HEATER MODEL R 15
I have tried to light my empire wall furnace by pressing the button and I have the gas on and it won't light
Oct 17, 2009 | Reddy Heater RLP100 Portable Forced Air...
Corcho Model CH30t-2 panels won't stay lit
HI it sounds like the fire cement between them needs replacing you can buy this at home hardware or heating supplier this should stop the flame down the middle , it stops air getting in and it will burn better , hope this helps you ?
Jan 10, 2009 | Heating & Cooling
Empire wall furnace won't stay lit after addional tank added.
Air in gas line? Bleed the gas line and try again. Make sure tanks are on.
Nov 27, 2008 | Empire GWT-25 Wall Mounted Panel Heater
Wall heater new 07, worked great all last season, turned on this
there could be something stuck in the pilot assembly since you added a new tank to system. Check to make sure flame is hitting thermalcouple. Can you wait for a repair man to come and take pilot assembly out and clean. He will also replace thermalcouple. If you can't wait and you feel comfortable with taking pilot assembly out. Turn gas and electric off to unit then pull cover panel off. Pilot assembly is held in with two screws. Take tube off of gas valve and take off thermalcouple line off gas valve too. take out pilot assebly. Once you have it out take gas line off bottom of pilot assembly. There is a orfice in side make sure you can see through the orfice. You can also clean thermalcouple with a wire brush or sand papper. Reinstall pilot assembly make sure all fittings are tight. turn gas back on and light pilot. If everything looks good turn power on. Turn heat up run heater for a few minutes then turn heater down and let sit to see if it will stay on.
Can not get the bricks to light on my empire corcho
Michael.
Nov 20, 2008 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
83 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
