Question about Samsung VP-D103i Mini DV Digital Camcorder
Lcd problem When I turn my camcorder on, whether it's in record mode or playback mode, there are thick grey lines across the lcd, in front of the picture. This happens with every tape and on the tv also. Also, are my tapes that I have tried to play ruined now?
  • 1 more comment
  • yksg Apr 05, 2008
    my Lcd show the picture and blank and blak lcd
  • ichie May 26, 2008
    When I turn my camcorder on, whether it's in record mode or playback mode, there are thick grey lines across the lcd, in front of the picture. This happens with every tape. Please help.
    chuks
  • Anonymous Mar 30, 2014
    grey bands when playing back in lcd
    Problem Solver:
  • 5 Answers
I had this problem with my camera. If it was the same problem as I had, I had to get the mainboard replaced due to a couple of burnt out chips.
Posted on Sep 18, 2008
I had the exact same problem with my Sony TRV22. I knew it wasn't the tape or the screen because the gray lines appeared on all tapes and on the capture screen in FCP. I followed the advice above and rewound the tape to the beginning, the end and back again. I suppose this does get the heads back into alignment or something because now the gray lines are gone. Much relieved.
Posted on Jun 23, 2007
Ok i had this problem with my sony, managed to find the solution but don't remember the link. happened after i put a dusty tape in to see what was on it. the solution was to wind the tape fully to the end and back, after a few times of winding the lines disappeared, also changed the format from LP to SP after someone also suggested this. it seems the tape heads were out of alignment and doing both the above managed to sort things out
Posted on Jun 02, 2007
  • 1,476 Answers
Sounds like you have either a problem with the CCD block or on the mainboard where the encode/decode section is. If it is the CCD block it is defective or you have a loose or dirty connection on the ribbon cable from the CCD block. In record mode you are seeing the video E/E, which means you are looking at the video from the CCD block which has passed through the mainboard. That would explain the lines on the viewfinder. When you playback a tape you are looking at the recorded signal, but it also passes through the mainboard. It is not clear whether the tapes you are talking about playing were pre-recorded previously (prior to this problem) and played previously, with no lines present. If they were recorde previously, played back previously with no lines, and not re-recorded. They should be OK provided the problem is not tape damage. Since you say that all tapes do it, I would think it is not tape damage. The best place to start, to sort out the problem, would be to locate a known good camcorder and try your tapes in it. If they play fine the problem is on the mainboard but after the record circuitry, ie. only in the playback circuitry. If they have the lines the problem could still be on the mainboard but also could be the CCD issue I talked about. This is a tough problem to isolate and will take a good repair tech. If you are not familiar with troubleshooting camcorders you will need to locate a reputable and experienced repair facility. First you should do the test I mentioned on a known good camcorder as this will help a repair tech make a diagnosis. If there are no repair shops in your area here are several which offer free estimates: http://www.camcorderrepair.com or http://www.videotech.com or http://www.videoonerepair.com Good luck.
Posted on Jul 25, 2006
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Dec 09, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Grey horizontal lines during playback on camcorder
yes change the tape and also use a head cleaning cassette to clean the cam. chaminda from Sri Lanka
Jun 25, 2009 | Canon MV750i Mini DV Digital Camcorder
Grey lines across video display
pls rate me WELL if i have helped u !
Regards
Zohail
May 20, 2009 | Canon ZR200 Mini DV Digital Camcorder
Canon zr200
The heads are dirty, purchase a soft head cleaning tape and run it for 25 secs.
Dec 26, 2008 | Canon ZR-950 Mini DV Camcorder
LCD screen had two grey lines
I recently had the same problem. All I did was buy a Head Cleaner, followed the instructions, and now my camera works fine. It only cost me A$12 and I bought it from a shop specialising in digital video cameras. I hope this helps.
Sep 02, 2008 | Sony Handycam DCR-TRV460E Digital...
Grey lines across the screen
Does this happen on all dvs tapes? If so then it is a problem with the head reader of the cam, but if only one tape, then that tape is either has quite an old recording on it or the tape is damaged.
Jan 12, 2008 | Canon ZR200 Mini DV Digital Camcorder
Panasonic PV-GS500
I had the same problem but without the needing cleaning message on my Pana PvGs12, weird as it sounded, I stopped it but left it on and gave it a whack on my palm and then tired playing it again and it fixed it. But I have heard it may also need professional head repair and that it may be out of alignment too? Try switching from doing it in the camera mode and or in the playback mode. I'd also try the reset button.
Dec 16, 2007 | Panasonic PV-GS500 Camcorder
Not recording clear.
Hello, please try to playback these new recordings on some other Camcorder. If you experience good picture on the borrowed Camcorder it means that the video head is (partly) damaged. In order to cure this the video head is to be replaced. Please contact the Authorized Sony Service or the technician with the best references. Best regards, Arpi
Apr 18, 2007 | Sony Handycam DCR-TRV250E Digital...
Samsung VP-D103i Mini DV Digital Camcorder Logo
199 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
